Old 01-31-2014, 04:58 PM   #3067
swift996
swift996's Avatar
Originally Posted by xjohnx View Post
seems like most people suggest just putting some teflon tape on the threads.
How do you get those rear elbow bolts off, I'm going to get a different set of allen keys but mine via a socket and extension had no chance.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 01-31-2014, 05:02 PM   #3068
xjohnx
Grip>Slip
xjohnx's Avatar
allen keys. the long handled ones with a wobble head and the regular length ones with the wobble head.
like these:
Old 01-31-2014, 05:04 PM   #3069
xjohnx
Grip>Slip
xjohnx's Avatar
although we took the elbow off when the blower was already off the car. we reinstalled it after we remounted the blower.
Old 01-31-2014, 05:10 PM   #3070
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Originally Posted by CK_Bladesmith View Post
Upon receiving my inter cooler kit, I noticed they included a whole bag of those bolts just in case any broke. They will probably send you some for free more than likely
The first thing I noticed when I took mine off was how cheap those bolts were. They work but it wouldn't be a bad idea to switch for some higher grade bolts.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 01-31-2014, 05:15 PM   #3071
calispec
calispec's Avatar
Thanks, just looked over the parts bag and they put a bunch in there.
Also both of my plastic fittings move around like the wind blowing, it looks like they included some replacement ones in my part bag, although plastic again. Any suggestions on sealing them? I don't want them on too tight where they could snap.
Yeah. I added Teflon and probably got another full rotation out if it. You have to take the middle brass elbow out to give enough room to twist the plastic elbows. Still tight a few thousand miles later.
www.GT86Mounts.com
Old 01-31-2014, 05:32 PM   #3072
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Innovate Supercharger Owners Topic
Does anyone else get a bit of hesitation upon normal acceleration around 3-3.5k? I seem to be getting a bit while under normal/ increased throttle. Maybe the charger is just transitioning from bypass into boost?
Edit: I've never had a supercharged car so maybe it's just the transition between the bypass valve on the back of the charger going from open to closed.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 01-31-2014, 05:50 PM   #3073
calispec
calispec's Avatar
Smoother than a baby unicorns bottom.
www.GT86Mounts.com
Old 01-31-2014, 06:33 PM   #3074
NickFRS
Drives: 2013 Asphalt FRS
This saddens me. Radiums owner approached me in 2012 to use my car for development then it was rear ended and they never pulled through since my car was in the body shop.... sad.... I would have all the radium goodies... Still have the business card and letter that he left under my window
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 01-31-2014, 06:54 PM   #3075
xxscaxx
Drives: 2013 SWP BRZ
@xjohnx - install meow!!
xxscaxx is offline   Reply With Quote
Old 01-31-2014, 06:57 PM   #3076
CSG David
CSG David's Avatar
Originally Posted by Calum View Post
That doesn't look like an over torque to me, it just looks like a cheap bolt. Can you get a picture up close and personal with the break.
Also, @ZDan and @CSG David I'm guessing this is within your realm, what's your opinion.
Just going down the line of thought really off the top of my head since I'm running around like a headless turkey getting some errands performed:
Looks like low grade bolts that can only hold very low torque values (captain obvious). Also the heat can cause the bolts to weaken (highly unlikely). I'm not familiar with that particular location right now (brain clogged).
What is the fastener material? Will have to look at the vibrational frequencies that can possibly cause the cap screws to back out as well. Other plausible case to reduce potential galling and torquing the bolt head is add some form of anti-seize (Permatex anti-seize?).
Old 01-31-2014, 07:37 PM   #3077
xjohnx
Grip>Slip
xjohnx's Avatar
Should be going on after I get home from the VCU/Richmond game tomorrow afternoon (tipoff at 11AM ESPN2) </shameless plug>
Old 01-31-2014, 09:21 PM   #3078
wrxgoose
WUB WUB
Drives: 2013 Firestorm
yes, i figured it was something to do with the tune. mine's usually bogging (just how it feels to me) around 2.8-3.2k rpm.
also: i'm trying to search for a manual tensioner (yes, i spelled it wrong before on purpose) so that i won't have to worry about that part, and there's also a little bit of wiggle in my idler pulley too. these are probably 2 of the big reasons i keep losing belts.
wrxgoose is offline   Reply With Quote
Old 01-31-2014, 09:27 PM   #3079
DriftEm
DriftEm's Avatar
lol you got me, I thought Manuel was a brand btw, Mt tensioner wiggles too
Sent from my SAMSUNG-SM-N900A using Tapatalk
DriftEm is offline   Reply With Quote
Old 01-31-2014, 09:55 PM   #3080
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Finally wrapped up this car today!
What a blast to drive!
This dyno was on E62, so there's more to come once our ethanol selection gets better!
Auto Trans
Innovate Non-Intercooled
Flex Fuel
Borla UEL
Perrin CAI @Raceseng Lightweight Pulley Set
Deatschwerks 450cc Injectors
Full Blown 270 Pump
Perrin Over Pipe
HKS Legamax Cat Back
@moto-mike Tuned
Built by Pure Auto
Pure Automotive is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
