Old 01-31-2014, 05:33 PM   #15
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
Considering they're making a similar style strut tower brace..I highly doubt that the dual catch can setup they offer would interfere. Why would they design a product that didn't work with another they offer?
Zach3794 is offline   Reply With Quote
Old 01-31-2014, 05:37 PM   #16
trigger happy
Bang Bang
trigger happy's Avatar
Drives: 2013 Raven FR-S
I wanna see installed pics :-)
Raven 6MT//Injen CAI//VDS UEL//Invidia N1//OFT//ST Coilovers
trigger happy is offline   Reply With Quote
The Following User Says Thank You to trigger happy For This Useful Post:
OICU812 (01-31-2014)
Old 01-31-2014, 07:42 PM   #17
xjohnx
Grip>Slip
xjohnx's Avatar
Tomorrow hopefully
Old 01-31-2014, 10:15 PM   #18
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
I have an air oil separator connected on my crank case vent on the drivers side head and oil reservoir for the AVo turbo kit. Any benefit from adding a second can on the PCV line?
Sent from my HTC One using Tapatalk
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 02-01-2014, 10:35 AM   #19
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
I've been holding out for these and I'm glad I did.. They look fantastic! I guess I know where my tax return is going
kask2_6.0 is offline   Reply With Quote
Old 02-01-2014, 10:40 AM   #20
Stevo22
Stevo22's Avatar
Drives: GR86
Mine are coming on Monday!
Stevo22 is offline   Reply With Quote
Old 02-01-2014, 10:56 AM   #21
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
I think it's time I ordered one
Carlitoz3 is offline   Reply With Quote
Old 02-02-2014, 02:03 AM   #22
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Assuming with Super Bowl Sunday I'll need to wait till Monday evening to read up on thoughts of this kit from those that have got em anxious as I have their page with this kit bookmarked!
Old 02-02-2014, 10:55 AM   #23
welllam
Drives: STi
Any group buy discount?
Sent from my SM-N9005 using Tapatalk
welllam is offline   Reply With Quote
Old 02-02-2014, 11:00 AM   #24
protpibe
protpibe's Avatar
Eager to hear if these work with hood struts
The Following User Says Thank You to protpibe For This Useful Post:
OICU812 (02-02-2014)
Old 02-02-2014, 11:42 AM   #25
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I thought the PCV side was more critical to do first as it catches the majority of blow-by? Being turbo I'd imagine you'd really want both cans...
Radium kit looks nicely done, but I plan to order a second Radium catch can for the crankcase side, fabbing up the mounting and hose runs myself for much easier access with as short a runs as possible like I did for the PVC side.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 02-02-2014, 05:05 PM   #26
protpibe
protpibe's Avatar
I thought they were both for crankcase ventilation, except the passenger side has a valve that only opens under positive pressure (PCV) from crank case to intake manifold. The other 2 breathers are still ventilating, except that they are always open.
As for the PCV, my understanding is that a boosted application will push open a PCV valve backwards and pressurize the crank case since it's connected to the intake manifold after the turbo and will see positive pressure. The drivers side crank case breather is connected to the intake tract pre-turbo and will see negative pressure. I'm installing a check valve inline between the PCV and intake manifold and maybe another catch can if others agree that there is benefit.
Old 02-03-2014, 12:55 AM   #27
welllam
Drives: STi
I thought thName:  uploadfromtaptalk1391406764033.jpg
Size:  138.9 KBey were both for crankcase ventilation, except the passenger side has a valve that only opens under positive pressure (PCV) from crank case to intake manifold. The other 2 breathers are still ventilating, except that they are always open.
This is what vortech has done. This should be inline with your idea.
I asked Crawford if this is necessary because I have bought their AOS. The feedback was no needed because they are boosting over 20psi but yet the stock pcv is holding fine.
Old 02-03-2014, 12:57 AM   #28
whataboutbob
AutoX-10/10ths every run
Mine will be here tomorrow.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
xxscaxx (02-03-2014)
DIY | Radium Catch Can | Video | Full Technical Info Dezoris DIY (Do-It-Yourself) Guides 233 01-07-2020 02:12 AM
Catch cans: what are you running? Apex Chase Engine, Exhaust, Transmission 144 08-14-2014 07:17 AM
Rev Works Vented Catch Cans - Need Your Help on deciding color options!! Rev Works Engine, Exhaust, Transmission 20 02-06-2014 12:53 PM
cusco catch cans difference Silverdub Engine, Exhaust, Transmission 15 04-23-2013 09:17 AM
AVO Inlets, Injen Intakes, Cusco Catch Cans, All In Stock! RallySport Direct Engine, Exhaust, Bolt-Ons 3 10-05-2012 12:39 AM
