Old 01-29-2014, 12:30 AM   #1
DAMotorsports
Drives: 2013 Scion FRS "Raven"
RacerX Upper Control Arms Review
We have been busy lately but when contacted by @DesertFrs (Jose) about the RacerX Fabrication's rear upper control arms ( @racerx1715 ) and if we would perform the install we couldn’t resist. We talked about which arms they had available (bushing or spherical joints) Jose chose the spherical joints. The parts came in and we did the install today. This will be our first impression (pros and cons) of the arms from install and how they changed the vehicle.
Upon removing the arms from the box we noted RacerX really did their homework. The welds looked amazing, joints moved freely and the spacers had a great fit. We then started the install. We took the time to take photos during the install as you will see at the bottom of the write up.
Install:
After jacking up the car and removing the wheels, we started removing the stock upper control arms. Toyota/Subaru used thread locks on the bolts so it took a bit more effort to remove. Once you loosened the bolts, the arm comes out without a problem. We compared the two arms side by side. RacerX did a great job at matching the mounting locations and curve to the stock arms. When we installed the RacerX arms, the inner mounts installed without a problem. Not the same as the knuckle end. Due to the coating on the knuckle we had to use a dead blow hammer to install the joint. This was the fun part, as the only way to set the camber is to remove the joint, make the adjustment, than reinstall. We took the time to take some camber readings before removing the stock arms, we started with 3.5 turns from max camber which is same as stock. We than had to remove the joint, to make the adjustment. To do this we used a hammer and a short poll to get the joint out. Once removed we tightened the joint 1 full turn and reinstalled. Our second attempt was spot on. 1 full turn showed a .5 degree change in camber.
After setting the camber and reinstalling the wires for the ABS, we noticed the stock bracket does not line up. We had to bend the inner mounting tab straight so we could install the bolt. Thats when we noticed a second problem, the mounting location is too high and puts the ABS wire in a location that could contact the chassis. Not a major problem as long as you bend the bracket to make some clearance (we contacted RacerX and they are going to look into a solution for this error). Install the wheels and repeat on the opposite side. RacerX really took the time to make sure their arms were a perfect match. During the install of the second side, we repeated the joint install with the same amount of turns and did not have to remove the joint.
After returning the vehicle to the ground we began the alignment. Unlike a lower control arm the toe did not change much and the wheel was still centered within the fender well. We set the car to -2 degrees of camber and 1/16” toe out.
With the alignment completed we took the car for a test drive. We expected an increases in road noise from the spherical joints but to our surprise the car sounded as if we never changed the arms (test drive was completed with the rear seat down). Just another sign of the quality work from RacerX.
Pro's:
1. Quality craftsmanship
2. Easy installation (even without instructions)
3. Everything needed to perform the install is provided
4.Design allows for easy replacement of the spherical joints if needed
5. Does not upset the toe like a lower control arm
6. Made in the USA
Con’s
1. ABS bracket fitment (we are sure this will be addressed)
2. The joint at the hub is a tight fit, requiring a hammer to install and remove. Not much of a con as we would rather have it tighter then looser. It’s nothing like the stock fitment.
3. Needs to be installed by someone with the ability to align the car during the install
4. Not alignment shop friendly. Due to the joint needing to be removed, there will be only a few select shop that will align your car. Those that do may charge extra for the time needed to make the adjustment.
With experience in racing and having tested several custom fabricated arms (on different platforms) RacerX arms a front runner with their quality control, everything from spot on fitment, great welds and easy install. Topped off with great customer care and a product made in the USA. We would recommend RacerX rear upper camber kit to anyone wanting the ability to adjust the rear camber.
****Disclaimer****
These are Double Apex Motorsports (DAMotorsports) views and findings on RacerX rear upper control arms. We do not work for or have any claim to RacerX and their product. Our only desirer is to help provided information about RacerX. Thank you for reviewing this thread and we hope this information assists you in your selection.
DAMotorsports is offline   Reply With Quote
The Following 10 Users Say Thank You to DAMotorsports For This Useful Post:
Black Tire (04-01-2015), Calum (01-29-2014), DesertFrs (01-29-2014), DriftEightSix (01-30-2014), F1point4 (01-29-2014), Jeff@Racer X Fab (01-29-2014), normancw (01-30-2014), RehabJeff86 (02-02-2014), Sithspawn (01-29-2014), SuperTom (07-01-2025)
Old 01-29-2014, 12:42 AM   #2
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Thanks for the detailed write-up. These look like a great bit of kit. I may have to pick up a set.
F1point4 is offline   Reply With Quote
The Following 2 Users Say Thank You to F1point4 For This Useful Post:
DAMotorsports (01-29-2014), DesertFrs (01-29-2014)
Old 01-30-2014, 06:18 PM   #3
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
Nice write up. Just thought id add, apart from a performance standpoint, These arms give a ton of clearance when dialing in negative camber as opposed to the lower arms. The RacerX uppers tilt the top of the wheel inwards while Any lower arm kicks out the bottom of the wheel giving the same angle but not as much fender clearance
SLICVIC is offline   Reply With Quote
The Following User Says Thank You to SLICVIC For This Useful Post:
DAMotorsports (01-31-2014)
Old 01-30-2014, 07:33 PM   #4
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Finally. I greatly prefer adjustable UCAs over LCAs. Too bad I don't track the BRZed anymore.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
cdrazic93 (06-15-2015), wparsons (01-31-2014)
Old 01-31-2014, 11:51 AM   #5
DAMotorsports
Thank you @SLICVIC! This is the reason we advised the owner to order the UCA's. He had some rubbing with his setup and after adding some camber he is in love with both the look and how it handles. If your are planning a static drop look and need more clearance this is the best option.
The Following User Says Thank You to DAMotorsports For This Useful Post:
SLICVIC (01-31-2014)
Old 01-31-2014, 12:47 PM   #6
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
I dig that solid outer ball joint. Are the inner joints solid/bearings too? (can't tell buy the angle of the pic). Looks true race quality (reminds me of long-travel desert/baja truck control arms)
fooddude is offline   Reply With Quote
Old 01-31-2014, 12:49 PM   #7
wparsons
wparsons's Avatar
It's also great that it doesn't mess with toe settings when changing camber too!
flickr
Old 01-31-2014, 12:59 PM   #8
fooddude
Sux tho to read that it's still hard to adjust for a general alignment shop. I can see how that'd hard with the inner bushings; but from the pics, it looks much easier since the adjustment is on the outer joint instead ..they shoulda designed it so you don't need to remove the joint and so u can just adjust it while it's on the arm still..u sure you need to remove the joiny from the arm to adjust? ..it looks like it was designed to be easy from the internet pics (but I guess you'd have to see it in person).
Old 01-31-2014, 03:05 PM   #9
wparsons
wparsons's Avatar
^^ Space reasons I would bet, to make it adjustable without removing the arm from the knuckle you need a piece of threaded rod that is threaded left on one side and right on the other, then a jamb nut to keep it from spinning once you're happy with the setting. It's nothing hard, but it would take up a lot more space and from the look of the arms there isn't any room to accommodate it?
flickr
Old 02-06-2014, 03:12 PM   #10
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
off topic from the product in question, but what alignment tool are you using?
supramkivtt2jz is offline   Reply With Quote
Old 02-16-2014, 02:20 PM   #11
Jeff@Racer X Fab
Drives: Subaru BRZ, Toyota MR2 Turbo
Update for Rear upper control arms.
Robert was nice enough to contact us after the installation and voicing his potential concern with the brake line bracket that is connected to the upper control arms. We have not had any issues to date with the the brake line contacting the chassis, but to be proactive we changed the fastener bracket at the back of the upper control arms. This updated design will lower the brake bracket about 1" lower away from the frame and provide additional clearance.
Thanks for the write up!! We always appreciate feedback.
Jeff@Racer X Fab is offline   Reply With Quote
The Following 2 Users Say Thank You to Jeff@Racer X Fab For This Useful Post:
Hyper4mance2k (04-02-2015), Koa (04-02-2015)
Old 10-30-2014, 11:27 PM   #12
Frs123
Frs123's Avatar
Drives: Raven
How do you adjust these Uca to get negative camber? Sorry I'm just a little confused.
Instagram: erik239
Frs123 is offline   Reply With Quote
Old 10-31-2014, 11:00 AM   #13
Jeff@Racer X Fab
No problem, When we build the control arms we have the rod end threaded out. When installing the arm the rod end will be threaded into the weld insert further providing negative camber. Make sense??
Old 10-31-2014, 12:20 PM   #14
mid_life_crisis
Drives: FR-S 10 #103 AT
An advantage to their approach is that, should the jamb nut work itself loose, the assembly can only move so far. There is no danger of the thing working itself loose while flying around a track.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Racer X Fabrication: Upper rear control arms, in stock/ready to ship!! Jeff@Racer X Fab Brakes, Suspension, Chassis 25 01-24-2014 12:42 PM
Adjustable rear upper control arms??? Supermassive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 09-29-2013 10:17 AM
Oem rear upper control arms Jhon19lopez Brakes, Suspension, Chassis 1 08-25-2013 10:01 PM
GTSPEC rear control arms & toe arms review Jesse Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-23-2013 04:20 PM
Upper control arms for bulk camber JordanWho Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 06-18-2013 12:40 AM
