Old 01-31-2014, 09:10 AM   #15
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Hopefully this tracking of your car isn't detected by the black box and the dealership voids your warranty.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 01-31-2014, 09:20 AM   #16
SpeedR
First86 / boat thief
Drives: MKIV Supra
1-go to an AUTO-X
2-go to DE event
3-repet 1 and 2 as often as you can
4-learn car control
5-start to have fun and be safe all at the same time.
SpeedR is offline   Reply With Quote
The Following User Says Thank You to SpeedR For This Useful Post:
Ganthrithor (02-05-2014)
Old 01-31-2014, 09:47 AM   #17
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
Maybe the OP did the same thing I did. I was coming into a turn, downshifted to 2nd, somehow hit the TC botton (seriously, I think the location is horrible! Especially for manual drivers), and the back end kicked out while I was giving a little too much throttle.
As others have said, with TC on, it is almost impossible to kick the back end out. I tried yesterday and almost broke my finger steering because the TC was actually on and I was expecting the back end to kick out, so I started counter steering. Conditions: dry roads, stock Primacy tires, cold weather.
The other day, it was 10 degrees Fahrenheit and my back end was sliding left and right after flooring it on a right turn. Luckily, I was able to keep the car pretty straight for the most part without issue. And this was with all the nannies on. Almost reminded me of torque steer, but with more control
Eurasianman is offline   Reply With Quote
Old 01-31-2014, 09:54 AM   #18
automatic
Drives: WRB BRZ
I've had the car slide for 2-3 with TC on....depending on how slippery it is outside.
Its possible that it slid for ~1-2 seconds on a rough shift before TC caught it, OP panicked and overcorrected.
automatic is offline   Reply With Quote
Old 01-31-2014, 09:58 AM   #19
ZionsWrath
Thanks
ZionsWrath's Avatar
So you slid with the TC on... I find that hard to believe, I drive with TC off all the time and barely get the car to loose the back end when driving... only time I got somewhat loose from 2nd to 3rd I hammered the gas and it was raining, but all it did was shimmy a bit.
It is possible. Actually I found it hard to correct with the TC on. I got into a slide, I pressed the throttle and the TC just killed everything I ended up stopped sideways on the off ramp.
The Following 2 Users Say Thank You to ZionsWrath For This Useful Post:
BentAnat (02-04-2014), Diode Dynamics (01-31-2014)
Old 01-31-2014, 10:00 AM   #20
Luis_GT
PROOF THAT TC IS DANGEROUS AND SHOULD BE REMOVED FROM CARS!
GODDAMN YOU GOV'MENT!
The Following User Says Thank You to Luis_GT For This Useful Post:
ftc~brz (01-31-2014)
Old 01-31-2014, 10:41 AM   #21
Tgionet
SPACESHIP
Tgionet's Avatar
Drives: BRZ Ltd 6MT WRB
If you actually correct the slide the TCS just seems to freak the fuck out and take the throttle away from you.
Tgionet is offline   Reply With Quote
Old 01-31-2014, 10:46 AM   #22
gily25
Drives: Silica BRZ 6MT
Maybe your next mod should be different tires...
Is this your first manual shift car? Sometimes when people are new to driving a stick they worry they aren't going fast enough for the next gear (car bucking or "dogging" from low rpms) so they accelerate too much as they upshift without realizing they're doing it. In a situation such as this, it was just a little too much acceleration for the terrain, had you been solidly in gear you would have eased back on the throttle when the slide first started (unless you were looking to drift). Keep this in mind next time it's raining, you may want to shift earlier to regulate your speed better.
gily25 is offline   Reply With Quote
The Following User Says Thank You to gily25 For This Useful Post:
Vincenttam (01-31-2014)
Old 01-31-2014, 10:47 AM   #23
thill
Are your back tires worn really bad? Otherwise, I am with others here, with TC on this seems really unlikely. I have driven my BRZ through some bad weather and could not make my car slide like that even if I was trying with the nannies enabled.
Old 01-31-2014, 10:49 AM   #24
Originally Posted by phloozy View Post
I was going to say the same thing. Doesnt matter how fast I am going, if I slightly slip my TC pretty much jams the brakes and is like "NO, NO, STOP IT!"
I've slid mine with the TC on (mind you I have an AT). The TC doesn't totally prevent it, it just helps correct it, in theory at least.
Heck, just this past Wednesday I managed to do sideways S-turns all the way down an on-ramp to I20 in Atlanta. Of course, there was about 2 inches of ice and snow on the ramp which helped!
Old 01-31-2014, 10:58 AM   #25
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
TC isn't god, you'll still slide if the reaction is big enough.
Old 01-31-2014, 11:02 AM   #26
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Based on the pic you posted, I'm going to guess it was due to balding tires:
Your local tire or auto parts store, maybe even dealership, should offer tire tread gauges for you. I have a card that has a yellow CAUTION zone and red REPLACE TIRES zone. Cost 99 cents and very handy. Couldn't find a pic of it since I got it years ago and it was probably discontinued but it works something like this:
If you find it was due to your tires, replace them ASAP before something tragic happens.
The Following User Says Thank You to switchlanez For This Useful Post:
amram (02-03-2014)
Old 01-31-2014, 11:20 AM   #27
CoupedUpSubie
Drives: 2013 BRZ Limited
Junk tires and hard shifting is what caused you to nearly wreck. Also if it hasn't rained in a while there is a build up of oils and other substances on the road. A bit of rain and they can get slick.
Go buy new tires, go to a driving school, don't drive like a madman.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 01-31-2014, 11:40 AM   #28
fitcious
this could of turned out much worst than the drawing of penises on your car.
fitcious is offline   Reply With Quote
Tracked Comparison: FRS and BRZ ajay BRZ First-Gen (2012+) — General Topics 23 03-25-2014 09:16 PM
Never trAcked my car Nd looking forward to it...help?!? Jonoraven93 Southeast 16 11-08-2013 04:11 PM
Guess who I tracked with sw20kosh Forced Induction 64 05-15-2013 07:59 PM
Tracked BRZ ajay BRZ First-Gen (2012+) — General Topics 10 07-03-2012 10:29 AM
BEWARE...Your car is being Tracked by the Guberment Scooby South Engine, Exhaust, Transmission 24 05-16-2012 10:47 AM
