Old 01-31-2014, 07:23 AM   #1
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Emissions After Tune
I want to keep everything nice and legal here. If I get a tune after fitting intake and headers what happens to emissions? Does the extra power that comes from a tune come at the expense of increased emissions or does a proper tune take care of power and emissions?
Old 01-31-2014, 10:38 AM   #2
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
if you aren't getting a catted header then the tune is the least of your concerns...
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 01-31-2014, 10:57 AM   #3
CaptainSlow
CaptainSlow's Avatar
Emissions are cut by catalytic converters. If you eliminate any of them, you will have trouble with your emissions. Generally, a tune will increase fuel usage, which may raise your emissions levels a bit in the process, but, for the most part, a properly functioning cat will scrub out most of it (especially an OE cat...high flow cats might have more of an issue because they are more open and, consequently, less effective at removing the harmful stuff)
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
The Following User Says Thank You to CaptainSlow For This Useful Post:
Captain Snooze (01-31-2014)
Old 01-31-2014, 12:02 PM   #4
wparsons
wparsons's Avatar
No emissions tests are done at WOT, so a tune changed only for WOT itself shouldn't change the emissions output of a car during testing conditions. If it increases emissions at WOT or not will depend on how rich or lean it was before the tune as well as after. A well tuned turbo car will be running richer than a good NA tune, so they'll be worse for emissions.
Some tunes actually give better mileage (and possibly emissions) at part throttle, but you could just tune WOT and leave part throttle stock.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
Captain Snooze (01-31-2014), suaveflooder (01-31-2014)
Old 01-31-2014, 12:04 PM   #5
CaptainSlow
Or, flash back to stock for the emissions test. Although I'd do it a few days before, because I think tunes tend to be a bit on the rich side until they learn all the various parameters again. I could be wrong on that, though.
Old 01-31-2014, 12:45 PM   #6
jamesm
you could probably improve emissions in closed loop just by having more accurate fueling calibration, though i doubt it matters much. i know i picked up some MPG as my closed loop tuning got better.
Old 01-31-2014, 02:42 PM   #7
arghx7
Drives: car
Is this more like a technical question about how emissions are effected from aftermarket parts and tune, or is it a "if I do x mods, will it cause me to fail this required test in my locality?" question?
And what exactly is the emissions test that the vehicle would undergo? Some places it's idle tailpipe and then two steady state speeds on a dyno. Some places it's just idle. Some places they just look for a trouble code and your diagnostic monitors' readiness. Some places have absolutely zero inspections.
The Following User Says Thank You to arghx7 For This Useful Post:
Old 01-31-2014, 03:45 PM   #8
Captain Snooze
Drives: Red Herring
It is a
"So what actually happens? In brief, the car is driven onto the dyno. The gas probe is exposed to air and zero'd. (Calibration of the system has to occur frequently and this is done using an expensive test gas.) The probe is inserted in the exhaust, and the driver is required to place the car in gear and then watch the PC screen. On the screen a narrow 'road' unfolds. The speed of the test car is represented by the location of a small car-shaped symbol on the screen - it's the driver's job to make sure that the on-screen car always remains on the road. The road angles upwards when the car is required to accelerate, alters to being horizontal when the speed needs to remain steady, and dives downwards when the speed of the car must do the same. On the screen the car is coloured green if it's on the road; if the driver wanders off, it turns red. Too many "high speed excursions" will see the test classed as invalid - only a small number of excursions are allowed."
http://www.autospeed.com.au/cms/A_05...ntArticle.html
Catted header is on the shopping list.
Old 01-31-2014, 04:42 PM   #9
arghx7
Drives: car
It is a
There is a dynamic test to 90 km/h. From dodgy memory it is not steady state.That is, there is acceleration involved but I do not know/remember the details.
Is that the drive trace above? Wow I'm surprised you would have to pass a transient test like that. Is this a cold or a hot test? You could definitely fail that test if the standards are strict enough. The biggest risk would be failing CO due to different enrichment, or failing NOx due to changed AVCS tuning. Or the cat(s) are going to degrade prematurely because the tune caused accelerated thermal degradation of the brick inside.
If it's a cold test any change to the exhaust besides a muffler or catback could make you fail, if the standard is strict enough. You'd be surprised how hard it is to tune an engine for cold starts.
Old 01-31-2014, 04:44 PM   #10
Captain Snooze
Drives: Red Herring
Hot.
Old 01-31-2014, 04:53 PM   #11
arghx7
Drives: car
Really there are two main risks then. 1 is that, over time your cat would degrade due to the tune and you would fail--but even then you probably won't see it on a hot test. The second risk is that you would fail CO due to enrichment from closed loop delay changes. That depends how heavily the engine is loaded down and how strict the standard is. Closed loop delay has a big effect on CO emissions.
Just to clarify, when I say the cat would degrade... it's not something you would be able to easily see in the real world. From my experience catalyst degradation can mostly be picked up by controlled lab tests. The "catalyst efficiency" check engine light is pretty generous. It only comes on when the emissions are way over standard. And I have no idea how strict the OBD regulations are in your area, so half your diagnostic monitors may note even work.
Old 01-31-2014, 04:55 PM   #12
CaptainSlow
Again, is there an issue with just reverting to the stock tune for the test?
Old 01-31-2014, 05:00 PM   #13
arghx7
Drives: car
If all the hardware is stock, it should be fine if you just go back to the stock tune. If you've changed intake and relocated the o2 sensor and such, who knows? Test it and report back.
Old 01-31-2014, 05:15 PM   #14
Captain Snooze
Drives: Red Herring
Emissions - MD TheseColorsDontRun Mid-Atlantic 6 08-23-2013 07:06 PM
GA - Atlanta Emissions chuchutrain Southeast 6 07-12-2013 11:55 AM
Question regarding emissions. Fourskim Northwest 7 06-30-2013 05:23 PM
Emissions question with a ecu flash sw20kosh Engine, Exhaust, Transmission 2 04-08-2013 02:11 AM
Massachusetts Emissions ngabdala New England 3 11-26-2012 08:25 AM
