Old 01-30-2014, 06:43 PM   #141
frslee
Just drive it
Drives: 13' FR-S
I wouldn't shift from 2nd to 1st when the car is moving. If you're going to stop, then stop and put it in 1st gear. If the car is moving, stay in 2nd gear.
frslee is offline   Reply With Quote
The Following 2 Users Say Thank You to frslee For This Useful Post:
HunterGreene (01-31-2014), meeskee2 (02-06-2014)
Old 01-30-2014, 06:50 PM   #142
mfbmike
Drives: 2013 FRS, 2008 R32
Originally Posted by suaveflooder View Post
Same here. Haven't swapped fluids yet. Motul is on it's way though. We shall see.
motul won't change that.
as mentioned, 1st gear is really only to get the car moving. lol.
you can rev match into 1st but still...
mfbmike is offline   Reply With Quote
The Following User Says Thank You to mfbmike For This Useful Post:
suaveflooder (01-30-2014)
Old 01-30-2014, 07:54 PM   #143
trix202
Drives: '13 Fr-s
So motul seems like the go to since it works in the differential and transmission but is worse then oem in the cold?
If so then whats better then oem for winter DD in Canada?
trix202 is offline   Reply With Quote
Old 01-30-2014, 08:37 PM   #144
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
what about automatic transmission?
chenshuo is offline   Reply With Quote
Old 01-30-2014, 09:45 PM   #145
getbent
Drives: 2013 FR-S Blue MT
Flush every 30K miles with whatever Toyota/Scion/Subaru recommends.
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
Old 01-31-2014, 04:18 AM   #146
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Pentosin or Redline MTL for tranny. Motul gear 300 in diff is fine year round...
Old 01-31-2014, 08:31 AM   #147
HunterGreene
Hail Magnet
HunterGreene's Avatar
Sell your car and get a stick shift, you're obviously doing it wrong
It has priests in it?
The Following 2 Users Say Thank You to HunterGreene For This Useful Post:
Alltezza (07-11-2014), Tim_Asphalt_FRS (01-31-2014)
Old 01-31-2014, 12:55 PM   #148
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
no need for another snobby MT driver comment.
The Following 2 Users Say Thank You to chenshuo For This Useful Post:
chas3wba0 (01-31-2014), HunterGreene (01-31-2014)
Old 02-05-2014, 06:34 PM   #149
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
So, I want to change my tranny and diff fluid this month and I was going to go full Motul but after hearing about hard cold shifting I'm rethinking my choice. Now I'm thinking of Redline MT-85 :[ame="http://www.amazon.com/Red-Line-50504-Transmission-Transaxle/dp/B004D4URV6/ref=cm_cr_pr_product_top/186-2417182-7610908"]Red Line (50504) MT-85 75W-85 GL-4 Manual Transmission and Transaxle Lubricant - 1 Quart : Amazon.com : Automotive[/ame]
Do you think that's a good choice for the tranny or is the weight too low for our spec? I was also thinking of still using Mogul 300 for my diff, so if I bought 2 qts of each could I mix fluids by putting 2 qts of 85 in the tranny then top it off with the 90?
Deathalo is offline   Reply With Quote
Old 02-05-2014, 09:17 PM   #150
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Originally Posted by Deathalo View Post
So, I want to change my tranny and diff fluid this month and I was going to go full Motul but after hearing about hard cold shifting I'm rethinking my choice. Now I'm thinking of Redline MT-85 :Red Line (50504) MT-85 75W-85 GL-4 Manual Transmission and Transaxle Lubricant - 1 Quart : Amazon.com : Automotive
MT-85 is thicker than MTL, which several members are running in their transmissions without problems. I ran the MTL for a while without problems. Didn't like the way it felt so I went to Gear300. I wouldn't have a problem with trying the MT85 in my car, but I'm more likely to go with Pentosin the next time I change it.
Top it off with the Motul Gear300?
You could, but neither manufacturer is going to be OK with the idea of mixing someone else's oil with theirs. If there is a problem nobody will be able to help you without launching into a 30 minute diatribe about how they only have documentation on their own brand of oils. You could end up stumbling onto a mixture that does great things.
Top it off with redline MT90? Yes.
Top it off with redline 75w90 GL5? No.
Sellout is offline   Reply With Quote
Old 02-05-2014, 09:21 PM   #151
chas3wba0
chas3wba0's Avatar
Drives: Yes
Has anyone here tried just doing a flush and refilling with stock OEM fluid?
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 02-05-2014, 09:38 PM   #152
Deathalo
Pentosin is thinner than MT-85 right? I heard good things about it but I don't want to go out of spec really, hell I'm nervous about going down to 85 in the summer, it doesn't get crazy hot here.. I just want it to be ok on days bordering 100 F. I wonder if Motul's GL4/GL5 spec would mesh well with MT-85's GL4....
Old 02-05-2014, 10:34 PM   #153
Sellout
Mr. Cranky Pants
Sellout's Avatar
Yes, Pentosin is 75w80 like Redline MTL.
Old 02-05-2014, 10:57 PM   #154
Deathalo
Been doing more research and have seen some great reports on Pentosin in our gearbox, still a bit worried about it being so thin, but if people are reporting great use even in the high 90s then I might be inclined to switch to that. I also heard of people using a Redline cocktail of MTL and MT-90, but I imagine it wouldn't be too different from MT-85 and I heard Pentosin is just a better product.
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 07:55 PM
What transmission fluid are you using? Chillz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 04-06-2013 10:45 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
