Old 09-11-2013, 04:59 AM   #1
Tech
Tech's Avatar
Drives: White MT GT86 with TRD extras
TRD Sports Gauges
If you have ever bought any TRD gear, you will know that they always come with instructions in Japanese. Well that's fine... if you are Japanese of course.
Fortunately, there are usually enough pictures included to get the job done, which is what I used when I recently fitted a set of TRD gauges.
Water Temp
Oil Pressure
Oil Temp
Contained in the Japanese text was the instructions of how to use the gauges. By that I mean there is a button under each gauge which puts them into different modes. The post will help you with the following.
a) Which wires to connect to.
b) How to display the different modes and clear the memory.
c) General pictures of the installation.
These gauges fit in place of the stock audio head unit. Since this car is mostly going to be used on track, I don't care that it has no audio. The stock head unit is a pile of crap anyway!
I will assume that you have mounted the gauges onto the face plates and run the wiring to the right places in the engine bay. The oil pressure and oil temp wires should end up near the oil filter and the water temp near the top radiator hose. The pictures included in the Jap instructions are clear enough to easily achieve this.
You also need to fit the adaptor plate under the oil filter to take the oil pressure and temperature sensors. Then cut the top radiator hose and fit the water sensor adaptor.
4 wires are used to power the gauges and I connected them as follows.
GAUGE WIRES > 86 WIRING LOOM
RED > ORANGE (+12V)
ORANGE > RED (ACC+)
YELLOW > PURPLE (ILLUMINATION)
BLACK > BLACK/BLUE (GND)
Assuming it is all installed correctly and there are no leaks, you can access the meter modes in the following way.
Each meter has it's own button. The gauges in NORMAL mode continuously monitor the condition they were designed for. If you press a button breifly, it will display the peak value the meter has reached at any point in time. The meter will return to nomal mode after 5 seconds. However, if while in PEAK mode, you press and hold for 3 seconds it will reset the peak value to zero.
While in normal mode, if you press and hold the button for 3 seconds it will display the warning level it is set to. This can be adjusted in increments by further pressing the button.
After 5 seconds of no activity, the setting will be saved and the gauge will return to normal mode.
If there is anything you specific you want to know, ask and I will do my best to answer.
Tech is offline   Reply With Quote
Old 09-11-2013, 09:12 AM   #2
GT86drifter
Drift Specialist
GT86drifter's Avatar
Drives: 180SX,GT86
good stuff!
GT86drifter is offline   Reply With Quote
Old 09-11-2013, 09:45 AM   #3
frs10
Drives: tezla
TRD everything!!
frs10 is offline   Reply With Quote
Old 09-11-2013, 09:48 AM   #4
R3d
Drives: White FR-S
what do you do for a radio now ?
R3d is offline   Reply With Quote
Old 09-11-2013, 10:43 AM   #5
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
Re-read
Eurasianman is offline   Reply With Quote
Old 09-11-2013, 10:57 AM   #6
kanundrum
Drives: 2013 Whiteout FR-S
I was looking into this but then saw pricing lol.
Old 09-11-2013, 11:01 AM   #7
DmkMedia
OctaneFix.com
Drives: '13 BRZ Sportech SWP/'07 Audi A4
I was about to say the same thing LOL
DmkMedia is offline   Reply With Quote
Old 09-11-2013, 11:05 AM   #8
kanundrum
If the Harness was long enough I am sure you can reroute the radio to the Blank Panel or the glove box
Old 09-11-2013, 08:51 PM   #9
Tech
Tech's Avatar
Originally Posted by frs10 View Post
TRD everything!!
Yes, this is a TRD86 model which you can buy in New Zealand. Not sure if they are available in all countries though. I am just adding on or two things that make it more track orientated.
Old 09-11-2013, 08:54 PM   #10
Tech
Tech's Avatar
Or just buy an ipod...
Old 01-30-2014, 05:40 PM   #11
Pvt AJ
Pvt AJ's Avatar
Drives: Toyota 86 GTS
How much s there much give in the wires to the gauge? id like to reach the A-pillar on the right hand side of the car (when sitting inside), would this be possible without further modification?
Pvt AJ is offline   Reply With Quote
Old 01-31-2014, 12:09 AM   #12
Pvt AJ
Pvt AJ's Avatar
Also whast size are the gauges? 60mm or 52mm diameter
Old 02-24-2014, 06:52 PM   #13
Tech
Tech's Avatar
Sorry for the late reply. I hardly ever check this forum anymore.
The gauges are 60mm and the supplied wiring from the sensors is very generous. I had to bundle it up with a cable tie. Can't say I tried getting it the the pillar, but I think there should be enough yes.
Individual gauge mounts also come with the kit, so you don't have to use the centre plate like I have. Therefore you could mount the 3 gauges on top of the dash where you want them and leave your stereo in place.
Old 03-30-2014, 04:20 PM   #14
Stealth Gt86
Stealth Gt86's Avatar
Drives: silver scion 10 series frs
did you make the mounting plate? I was wanting to do the same thing
2013 10 Series
2013 Raven FRS-sold
my old FRS boosted build http://www.ft86club.com/forums/showthread.php?t=31900
follow me on instagram- WeaponsFree86
Stealth Gt86 is offline   Reply With Quote
Cyberstork gauges ANREX Cosmetic Modification (Interior/Exterior/Lighting) 53 08-11-2016 06:07 PM
WTB: Gauges AtlasMick Engine, Exhaust, Bolt-Ons 2 03-29-2013 12:04 AM
gauges where the radio is? J-Money Cosmetic Modification (Interior/Exterior/Lighting) 7 02-05-2013 10:11 PM
GTS owners... difference between 'sports' abd 'vsc sports' button? UnLeasHer AUSTRALIA 5 07-26-2012 03:22 AM
Gauges CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 45 07-24-2010 06:26 PM
