Old 01-30-2014, 11:33 AM   #113
SpeedR
First86 / boat thief
Drives: MKIV Supra
Originally Posted by 37 View Post
Drone can be judged by downshifting to 5th on the highway. Unless you've removed your cats or installed a cheap, obnoxious exhaust then you should be fine.
Have you plotted out the 5.71? It looks WAY too short, even with an auto trans. To closely match a 6MT with 4.67 in gears 1-2-3 you'd need a 4.9. You might only be focused on gears 4-5-6 and missing how short the first three will become. Don't overlook that as it's a major place where a final drive matters.
Realize that the 6AT in this car will have tall 4-5-6 gears no matter what you do. You either need a 6MT if you want all 6 gears spaced shorter or different auto gears. Shortening the first three too much just to shorten the last three means could mean you'll end up with a street car that's undriveable. You truly would be roasting tires and alarming yourself with a 5.71.
Here is a direct comparison of a 6AT + 4.9 (red) with a 6MT + 4.67 (blue): http://www.teammfactory.com/gearcalc...ission+1+%26+2
Take note of what happens at 4th gear. You can't fix that plot with a final drive. You need different transmission gears.
See above. Despite your username, don't go too insane.
I see no problem with the 5.26s on an auto, I think it will be more than drivable and should be a lot of fun with my tires.
Any thing I am missing?
SpeedR is offline   Reply With Quote
Old 01-30-2014, 11:36 AM   #114
SpeedR
Drives: MKIV Supra
red is auto with 5.26 on 245/40/17s
blue is stick with 4.56 (considered very nice gears for the stick) on OEM tires.
Old 01-30-2014, 02:29 PM   #115
37
degrees
37's Avatar
Drives: 6MT BRZ
Yes... you're missing a manual gearbox.
5.26 on auto sounds short but isn't far from 4.88 behind a manual. You won't know unless you try. I highly doubt anyone has gone that short on an auto.
37 is offline   Reply With Quote
The Following User Says Thank You to 37 For This Useful Post:
SpeedR (01-30-2014)
Old 01-30-2014, 05:03 PM   #116
SpeedR
Drives: MKIV Supra
I know I know this is my first auto ever and its not a bad one at all, but yes all my race cars have had manuals. That being said as a performance driving instructor I can tell you time on track is way more important than Auto vs manual.
If its a real race I ill just go get the SUP. LOL
On a serous note I thanks for your help/input and the links you provided in this thread very good info.
Old 01-30-2014, 05:13 PM   #117
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Meh, if only we could find a 3.73 diff in good condition right @Frs300?
Old 01-30-2014, 06:04 PM   #118
Frs300
Frs300's Avatar
Drives: Pile of junk
Im still looking for just the ring and pinion as well as the entire pumpkin
Frs300 is offline   Reply With Quote
Old 01-30-2014, 06:34 PM   #119
SmsAlSuwaidi
Boosted
If I get desperate about it maybe it might be time for an M82 with a welded diff
Old 06-29-2014, 12:55 PM   #120
Account Attempt No. 4
Account Attempt No. 4's Avatar
Drives: 2013 WRB BRZ Limited
Thanks @PantsDants
I'm a bit late to the party it would seem, but I'm trying to decide between a 4.56 and a 4.88 (from Weir Performance) on an MT for DD (with some tracking)
I was leaning to the 4.88, any input?
Originally Posted by Calum View Post
No it's not. - Yes it is. - It'll make 400 whp. - No, it'll only make 200 whp and break down all the time. - Oil temperatures!! - This will never happen. - But the other kit. - Turbo is better. - No, supercharger is better. - Rotrex sucks. - You suck. - Perrin said. - But Visconti said.
Account Attempt No. 4 is offline   Reply With Quote
Old 06-29-2014, 07:24 PM   #121
PantsDants
Drives: Scion FR-S A/T, Whiteout
Originally Posted by Account Attempt No. 4 View Post
Thanks @PantsDants
For a DD, I wouldn't go 4.88 with a manual. 65 mph in 6th will have you at ~3200 rpm. If you can live with that and the resulting mpg hit (and potentially increased exhaust drone), go for it, else the 4.56 will still provide a noticeable increase off the line.
As for the track, the gearing you would choose really depends on the track layout itself. Say you're topping out 4th in a specific straight now; if you shorten your final drive, you have to use 5th to go the same speed you were before.
PantsDants is offline   Reply With Quote
The Following User Says Thank You to PantsDants For This Useful Post:
Account Attempt No. 4 (06-30-2014)
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Final Fantasy jay4prez Off-Topic Lounge [WARNING: NO POLITICS] 66 08-25-2013 10:31 PM
Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode SteveH Other Vehicles & General Automotive Discussions 7 02-13-2013 12:08 AM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
