Old 01-30-2014, 06:43 AM   #1
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Pic Request: MPSS 245/35/18 on 18x9.5" wide wheel
As title states looking for some side on, angled pics of a Michelin Pilot Super Sports tire in 245/35/18 on a 18"x9.5" wide wheel. (Any brand just 9.5" wide)
I've looked around hrs several times to get an idea visually how much stretch this "looks" like with the MPSS tire and no luck. I know these specific tires run larger then most so I'm very curious to see, perhaps it doesent appear stretched being their nature? I don't know....
If you could share some close up side and angles shots with this combo if be gratefull indeed!! Many thanks !
Old 01-30-2014, 02:44 PM   #2
mfbmike
Drives: 2013 FRS, 2008 R32
@Sportsguy83 can help you with that
mfbmike is offline   Reply With Quote
Old 01-30-2014, 05:39 PM   #3
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Even with a MPSS, dont put anything narrower than a 265 on a 9.5. If you want to run a 245 get a 8.5 wheel
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 01-30-2014, 05:52 PM   #4
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Here's one example: http://www.ft86club.com/forums/showthread.php?t=23079.
And you might find some pics here. Someone else has the spec you're looking for, I just can't remember who or where I saw it (think it was a red or black FR-S w/ Enkei Raijins). Maybe it was in the Meaty Tire Thread.
Tagging @Beyer Subaru for his interest.
The Following 3 Users Say Thank You to switchlanez For This Useful Post:
Beyer Subaru (01-30-2014), OICU812 (01-30-2014), unsurety (06-16-2014)
Old 01-30-2014, 05:54 PM   #5
mkivsoopra
I have that tire on an 18x8.5 wheel ... at least you can tell what it's not gonna look like.
mkivsoopra is offline   Reply With Quote
The Following User Says Thank You to mkivsoopra For This Useful Post:
Old 01-30-2014, 06:53 PM   #6
OICU812
Just a dude
OICU812's Avatar
Curious why you say that? I'm asking not cause I want stretched look and I have seen a MPSS 255/35/18 on a 9.5" and I can't see why anyone would go larger at all to be honest as it looked meaty and fed right to edge square? I'm asking to see a 245 as a safety measurement for "clearance" and of course the look in general. Not a stance or hellaflush setup at all btw just wanting to make right decision is all. Thanks.
Old 01-30-2014, 07:16 PM   #7
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
Per TireRack and, by proxy, Michelin, the 245/35/18 should be used on a 8" to 9.5" wide wheel. Section width is 9.8". This tire on a 9.5" wide wheel is just about perfect.
sdemo is offline   Reply With Quote
The Following User Says Thank You to sdemo For This Useful Post:
Old 01-30-2014, 07:34 PM   #8
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
I went with 265's... don't see why not?
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 01-30-2014, 07:44 PM   #9
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
Check weight difference between 265 vs 245.
ApolloSki is offline   Reply With Quote
Old 01-30-2014, 07:47 PM   #10
Acree
Acree's Avatar
3 lbs.
Old 01-30-2014, 08:14 PM   #11
switchlanez
A reason to avoid 265/35 MPSS is it can have clearance issues with front suspension arms/firewall at full lock based on what I've queried from people with experience fitting tires on 9.5" wide wheels. It'll likely need front/rear fender rolls, e-brake shield trim, and rear bumper tab shave (all of which some prefer not to do). @DAMotorsports fit 275/35R18 and @ft86speedfactory fit 265/35R18 (both Hankook R-S3) yet I've read of a person rubbing with 255/35R18 MPSS on this forum. Offset (which seems to have an allowable margin of +40 to +43) and suspension settings play into finding that sweet spot of fitment.
The OP seems to have done his research and ruled out 255 and 265 MPSS.
The Following User Says Thank You to switchlanez For This Useful Post:
Old 01-30-2014, 08:29 PM   #12
OICU812
Just a dude
OICU812's Avatar
Exactly only 255/35/18 I'm seeing right now that is a regular fit would be the Conti DW which that may be fine again not 100%. I realize as switchlanez has said some folks have ran or do run larger. But I'm not wanting to play the risk & fuss game and also want to stay at -2 or less camber up front.
Old 01-30-2014, 08:30 PM   #13
OICU812
Just a dude
OICU812's Avatar
3 lbs.
That to me is a lot of weight. Wheels I'll be putting tires on are 17.4 lbs so I'd like the auw to be as low as possible even though their a street tire. By going this width it's just part of decision for me I suppose width is one thing but adding extra unnecessary mass on top of it is another to each has their own goals is all.
Old 01-30-2014, 09:11 PM   #14
sdemo
sdemo's Avatar
Funny when a simple request turns into a thread in which the OP has to justify everything they're doing / asking for...
OICU812 - you'll like the 245s. The wider you go, the more steering feel you lose and, at 200hp, 265s seem unjustified.
The Following 3 Users Say Thank You to sdemo For This Useful Post:
DanVIIIVI (02-02-2014), hotpanda1 (01-30-2014), OICU812 (01-30-2014)
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +38 kimchangil424 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 01-03-2017 06:00 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +30 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 179 11-20-2015 12:12 AM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x8.5 +47 / 18x9.5 +38 FML Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 91 06-13-2015 08:48 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x8.5 +38 / 18x9.5 +38 f0rge Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 01-16-2015 02:57 AM
Picture Request: Stock Turanzas on 8" wide wheels Robmilkshakes Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 02-17-2013 06:05 PM
