Old 06-29-2012, 10:34 PM   #57
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
You can't really speak in generalities when it comes to race fuels and engine management systems these days. Typically old school leaded race fuels have very different specific gravities and end point temps. This usually means you put it in your tank and the tune becomes richer. You make power by leaning out the afr beyond what you can run on low octane and you advance timing beyond what you could normally run.
With unleaded race fuels usually its the same afr when you start but again you use the same strategy as the leaded fuel.
Now oxygenated race fuels are the rage and they can run leaner when filled in the tank and because they cary oxygen it will make more hp with no tuning...about 4 to 6%. These fuels make more power on the rich side vs. The lean side so they can sometimes have really good results on a factory tune.
Engine management systems vary in their ability to advance timing by sensing knock. Subarus have a abnormal amount of ignition advance available on top of the base timing map along with an agressive nature to seek knock and then back the tune off. This is why we sell so many engines Other more logical ems systems only have enough learning to take advantage of say 93 octane.
It has already been said but the only way is to either log the timing curve or put it on the dyno with race fuel and wait for it to learn.
Element Tuning is offline   Reply With Quote
Old 06-30-2012, 09:28 PM   #58
Evil86
Evil86's Avatar
Drives: Monkey-butt red FR-S
How long does it take the ECU to adjust to a higher octane (91 to 93). I autox and I want to use 93 for events.
Evil86 is offline   Reply With Quote
Old 01-30-2014, 09:41 AM   #59
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
I'd like to know what kind of power increases could be had from race fuel WITH a tune.
Would it be similar to, or better than, what we're seeing from E85 cars?
@rice_classic
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 01-30-2014, 10:49 AM   #60
Deathreaper
Drives: 2013 Scion FRS
FRS is sensitive to anything under 93 it seems but i'm uncertain as to how much benefit there would be 93+ octane (on a stock car):
If you can't read french here are the results
Octane/hp/ft-lb
89/155/136
91/160/138
94/166/140
http://burn-out.ca/en/content/scion-...ne-test%C3%A9s
I know it doesn't compare 93 with 94 (or anything significantly above that). I wouldn't be surprised if the ECU can squeeze out a bit more timing on stock with race gas. But from reading this article I doubt there would be much power gains:
http://wot.motortrend.com/lights-cam...-s-339785.html
Deathreaper is offline   Reply With Quote
The Following User Says Thank You to Deathreaper For This Useful Post:
Clipdat (05-30-2014)
Old 01-30-2014, 02:16 PM   #61
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
@rice_classic
Drift Office might be a better one to seek out as he might have done this back to back.
I'm not a fan of E85 and have no intention of putting it in any of my vehicles, race car or otherwise, thus I have no data of my own.
PRO86 | WTCC | STL
Old 01-31-2014, 03:42 AM   #62
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
Octane/hp/ft-lb
89/155/136
91/160/138
94/166/140
im pretty sure the computer will take advantage of the higher octane fuel. how much advantage? we will see... it adjusts for octane lower than 93 im thinking is should do the same for higher octane. ive only put 93 in my brz but i will put in race fuel for a track day and see what happens.
NYCsubaruBRZ is offline   Reply With Quote
Old 05-30-2014, 12:51 PM   #63
poptopclk
Drives: Scion FR-S 10 Series
This is a copy & paste from Jackson Racing RE: our cars & running on the track
It could be that they use a different engine tune and superchager for their opinion
However, they seem to know alot about our engines & racing
100 Octane (R+M/2) Unleaded Fuel -
It is important to run fuel designed for abuse at the
track. Even stock FA20 engines should run 100 Octane when at the racetrack to ensure
consistency and reliability. The additive packages in 91 Octane fuel are designed for
emissions and shelf life, while 100 Octane is designed for the high cylinder pressures and
full load/throttle conditions you will experience on the racetrack. When at the track, we
REQUIRE running a minimum of 50% 100 Octane fuel. We highly recommend running
75-100% 100 Octane when at the track."
poptopclk is offline   Reply With Quote
The Following User Says Thank You to poptopclk For This Useful Post:
Old 05-30-2014, 01:14 PM   #64
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Tank after tank of e85 around town and at the track...,could not possibly be any happier
Car runs great
Wanting to build out this motor next
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 05-30-2014, 06:15 PM   #65
steve99
Drives: FT86
From my experience with the 86/BRZ which is not extensive , it seems to work like this
Standard/stock ECU programming and ignition advance mapping expects 93 octane to run the full timing advance available in the standard maps and hence obtain maxium performance (with standard mapping)
93 USA = 98 RON
91 USA = 95 RON
If you put less than 93 (or some even some variants of 93) then the ECU will start to detect knock and based on the severity and frequency on the knock events it will retard the ignition timing by reducing the value of a parameter called the IAM (Ignition advance multiplier). This may reduce from say 1 to 0.8 will will reduce the knock control ignition advance by 20% across the entire RPM/load range. Rearly bad fuel can result in IAM falling to 0.2 or even zero, at zero only the timing the the base timing map would be applied, no knock control advance added.
Their are two main ignition advance tables,
Base timing table and the knock control timing table the total ignition advance is the sum of the two (plus/minus other offsets due intake air temp , coolant temp ect)
The Base timing is always used then the knock control timing is added
Total timing = Base timing + (Knock control advance timing * IAM)
Their appears to be no facility in the tables/mapping to further advance the timing if greater than 93 octane fuel is used. However some blends/brands 93 fuels especially in Canada seems to exhibit knock, which can reduce the IAM and hence lower performance.
Once you IAM is at 1 which happens with decent 93 fuel their is no further advance options available to the ECU. (unless you remap/change tune maps)
Knock control is a continuous learning process and once the ecu detects no knock for a couple of minutes it will start to move the IAM back towards 1 and restore your full timing advance, ie when you fuel up with a better quality fuel.
Conversely if the knock events continue the ecu will keep reducing the IAM (hence reducing ignition timing & performance ) until the knock gets down to a level "acceptable" to the ECU programming.
Fuel trims are also continuously learned and adjusted, their appears to be no benefit in "resetting the ecu" other than to clear fault codes. The ECU will to the extent of its learning capacity and fuel/ignition mapping learn changes in fuels ie 91 to 93 or E10 non E10 fuels
further explanation here knock control
http://www.ft86club.com/forums/showp...09&postcount=1
info on fuel trims and open loop closed loop modes
http://www.ft86club.com/forums/showp...59&postcount=1
Old 06-01-2014, 10:33 PM   #66
nomad
Drives: frs
Torco Accelerator
Originally Posted by hav0c View Post
Since there are lots of knowledgeable folks on this thread.. I've got a related question about 91 vs 93 octane. In CA only 91 is available except for a very few places. I've considered adding about 3 gallons of 100 octane to the 10 gallons of 91 in the tank. This would bring up the avg to 93 or so.
Any benefit to this?
Since it would be mixed going forward, I'd just periodically add some more 100 when I pass that gas station. If it's not done right I could see the octane rating going well above 93 (and also wasting money on too much 100) ..
I'm not as concerned with performance as avoiding any kind of knock and forcing the ECU to relearn the 91/'low octane' thats being used on a regular basis.
I use Torco Accelerator to bring up the octane number. Adding 16oz Torco accelerator to a full tank of 91 gas and the car run way peppier and smoother. I'm running OFT stage 1, and on 91 gas the Advance multiplier fluctuates like crazy, sometimes drops to 0.5. When I add Torco accelerator to 91 gas the Advance multiplier always stay at 1
nomad is offline   Reply With Quote
Old 08-19-2014, 07:56 PM   #67
solus
Drives: 2014 Scion FRS (Ultramarine)
Bringing a thread back to life....
So, any issue with running 9 gallons 91 octane mixed with 1 gallon a 100 octane to get 92 octane (or 2 gallons 100 octane to get 93)? boosted with tune for 92 octane...
solus is offline   Reply With Quote
Old 08-19-2014, 09:58 PM   #68
fantah
fantah's Avatar
Drives: 2013 BRZ Premium Black
No Issue at all. I use 92 day in day out. and 100 for RallyX then switch back to 92 after. Only reason to go higher octane is to reduce knock to keep the Advance multiplier at 1.
I noticed that when I ran rally at 92 only my multiplier would go down to .8 after a run, putting in the higher octane helps the car be happy at full throttle
If you're not racing or doing anything special there's no point.
fantah is offline   Reply With Quote
Old 08-19-2014, 10:57 PM   #69
Pete156
I like to eat!
I find my boosted 86 feels considerably more powerful when I add two and a half gallons of Trick 101 to the 92 E0 in the rest of the tank. Probably brings octane up to around 94 and would really like to see the difference on the dyno (Perhaps next time I go to Drift Office we can test it). I have run 3 or 4 tanks like this thru the car, but generally do this when autocrossing and see no change in fuel consumption.
Pete156 is offline   Reply With Quote
Old 08-20-2014, 10:43 AM   #70
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
I generally run 100 or 105 when I go to the track with the turbo. It feels pretty damned good.
FrX is offline   Reply With Quote
Race spec Modified2006 Scion FR-S / Toyota 86 GT86 General Forum 39 11-10-2011 04:50 PM
Toyota FT-86 to Race in VLN Race @ Nurburgring this Weekend! First Photos! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 329 10-16-2011 08:51 PM
Mazda MX-5 GT Race Car...WOW Mouse Other Vehicles & General Automotive Discussions 9 03-31-2011 02:02 AM
what/who do you race Abflug Off-Topic Lounge [WARNING: NO POLITICS] 33 09-03-2010 02:13 PM
