#2983 |
Ethanol mandate by our congress, all fuel at the pump has to have at least 10% ethanol in it.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
| The Following User Says Thank You to swift996 For This Useful Post: | RyanITV (01-29-2014) |
#2984 |
Grip>Slip
#2985 |
Grip>Slip
Might've found it, tossed a zip tie on the fitting that leads from the intake elbow to the brake booster, seems to be staying in the 12.3-12.7 range now at WOT. Hard to say for sure because the roads are a mess from the snow so WOT usually results in massive amounts of wheel spin. I'll keep my eyes on it over the next couple days until i get my first update on this tune from you.
| The Following User Says Thank You to xjohnx For This Useful Post: | DeliciousTuning (01-29-2014) |
#2986 |
Drives: Raven FR-S
I finally got all of the air out of the system and my coolant bottle is staying right at the full mark. Been horsing around with it all day (safely and only straight line pulls) and it's a blast!
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
#2987 |
I got my 72.5mm @Raceseng pulley. Looks great!
BTW - how do you guys bleed all the air out? Just turn the car on and squeeze the lines?
| The Following User Says Thank You to swift996 For This Useful Post: | Raceseng (01-29-2014) |
#2988 |
Drives: UK GT86
Pretty much, just keep an eye after driving too as that will move the air through the system. I reckon 2-3 weeks of driving will have all the air out the system.
.: Stealth 86 :.
#2989 | |
Grip>Slip
| The Following User Says Thank You to xjohnx For This Useful Post: | CK_Bladesmith (01-29-2014) |
#2990 |
Drives: Raven FR-S
Just a hot tip for anyone installing the intercooler...... Put the small hose that fits on the plastic 90 for the heat exchanger on first before you actually mount the heat exchanger. That line was an absolute bitch for me to get on....even with the heat exchanger out of the car!
| The Following User Says Thank You to CK_Bladesmith For This Useful Post: | swift996 (01-30-2014) |
#2992 | |
Grip>Slip
#2993 | |
Drives: 2013 Asphalt FRS
Get some snow tires!
2013 Sion FRS
2014 Subaru WRX 2014 Subaru XV |
#2994 | |
Drives: 2013 SWP BRZ
#2995 |
Drives: Raven FR-S
Must have missed it. I even bored one end out with a drill bit (by hand) and it still didn't help.
#2996 | |
I forgot to mention that to the Innovate rep, I will mention it. |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
