Old 01-29-2014, 12:40 PM   #2983
swift996
swift996's Avatar
Originally Posted by Ryan86 View Post
Are you mixing 10% Ethanol into your 93 ??
If I'm understanding 10L Ethan to 40l 93 pump?
Ethanol mandate by our congress, all fuel at the pump has to have at least 10% ethanol in it.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following User Says Thank You to swift996 For This Useful Post:
RyanITV (01-29-2014)
Old 01-29-2014, 01:23 PM   #2984
xjohnx
Grip>Slip
xjohnx's Avatar
@RyanITV @APS86 - Most of the jitter problems you're describing can likely be smoothed out tuning.
The Following 2 Users Say Thank You to xjohnx For This Useful Post:
APS86 (01-29-2014), RyanITV (01-29-2014)
Old 01-29-2014, 01:38 PM   #2985
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by DeliciousTuning View Post
Make sure you have no vacuum leaks after the MAF sensor. If you do this can cause the lean condition you are seeing. Otherwise send me some logs and I will review them.
Cheers,
William Knose
Might've found it, tossed a zip tie on the fitting that leads from the intake elbow to the brake booster, seems to be staying in the 12.3-12.7 range now at WOT. Hard to say for sure because the roads are a mess from the snow so WOT usually results in massive amounts of wheel spin. I'll keep my eyes on it over the next couple days until i get my first update on this tune from you.
DeliciousTuning (01-29-2014)
Old 01-29-2014, 04:20 PM   #2986
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
I finally got all of the air out of the system and my coolant bottle is staying right at the full mark. Been horsing around with it all day (safely and only straight line pulls) and it's a blast!
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 01-29-2014, 05:28 PM   #2987
swift996
swift996's Avatar
I got my 72.5mm @Raceseng pulley. Looks great!
BTW - how do you guys bleed all the air out? Just turn the car on and squeeze the lines?
Raceseng (01-29-2014)
Old 01-29-2014, 06:31 PM   #2988
Kodename47
Kodename47's Avatar
Drives: UK GT86
Pretty much, just keep an eye after driving too as that will move the air through the system. I reckon 2-3 weeks of driving will have all the air out the system.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-29-2014, 10:08 PM   #2989
xjohnx
Grip>Slip
xjohnx's Avatar
Or in my case (since we had to stop for 5 days right before we were about to finish things up), i just added more every 12 hours or so, by the time it warmed up enough for us to finish working no it we had about 2/3's of the fluid already in the system
CK_Bladesmith (01-29-2014)
Old 01-29-2014, 10:12 PM   #2990
CK_Bladesmith
Drives: Raven FR-S
Just a hot tip for anyone installing the intercooler...... Put the small hose that fits on the plastic 90 for the heat exchanger on first before you actually mount the heat exchanger. That line was an absolute bitch for me to get on....even with the heat exchanger out of the car!
The Following User Says Thank You to CK_Bladesmith For This Useful Post:
swift996 (01-30-2014)
Old 01-29-2014, 10:16 PM   #2991
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by xxscaxx View Post
Sweet man. I am going to order this too, said the 31st will be when they ship. I might wait though a week or two, I need to buy my injectors first
Just got my tracking number. Delivery expected this friday.
xxscaxx (01-29-2014)
Old 01-29-2014, 10:26 PM   #2992
xjohnx
Grip>Slip
xjohnx's Avatar
that line was clearly undersized for the fittings to which it attaches. When @civicdrivr and i have the bumper off to install the robispec radiator/oil cooler I will be replacing it with a properly sized hose.
Old 01-29-2014, 10:58 PM   #2993
NickFRS
Drives: 2013 Asphalt FRS
Originally Posted by wrxgoose View Post
stockers still. i'm doing gauges, then axles before i go to wider/stickier tires.
https://www.facebook.com/photo.php?v=10152192220034933
Get some snow tires!
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 01-29-2014, 11:12 PM   #2994
xxscaxx
Drives: 2013 SWP BRZ
If you would have read back a bunch of pages, I made mention of that.
xxscaxx is offline   Reply With Quote
Old 01-29-2014, 11:14 PM   #2995
CK_Bladesmith
Drives: Raven FR-S
Must have missed it. I even bored one end out with a drill bit (by hand) and it still didn't help.
Old 01-30-2014, 08:30 AM   #2996
xxscaxx
Its really cold here in NY so the line didn't want to move much, so I heated it up with my heat gun for a bit then I used some lube to shove it in there. I got it on just enough to feel comfortable putting the clamp on it far enough up on the fitting.
I forgot to mention that to the Innovate rep, I will mention it.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
