Old 01-19-2014, 10:33 PM   #57
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Originally Posted by Lithium View Post
I'm sorry you thought 12 gauge wire was difficult to work with, I actually suggested 18 gauge to 12 gauge wire for this project. Maybe I should be more specific next time. Glad to see you got the job done, congrats for accomplishing a difficult DIY!
The thing that made the 12 gauge hard to work with was that I couldn't easily twist the 2 different gauges together, at least the wire is heavy duty
Deathalo is offline   Reply With Quote
Old 01-20-2014, 09:52 AM   #58
modena
modena's Avatar
Drives: BRZ Limited WRB MT
To make the install a bit easier, solder the diode between your wires.
Just made one in about 5 minutes, (To take some pictures)
Shrink-tubed my cable from the headlight to the DRL's to make it look like a wiring harness.
(If you wouldn't know you might think it was part of the car)
A connecter on the DRL side will make it easy to disconnect when removing the bumper.
KartBoy SS | BlackVue DR550GW | Valentine1
GrimmSpeed MC Brace | GrimmSpeed Hood Struts
OEM Armrest | OEM STI Badges | 20% Tint
Rydeen duo | Halo's as DRL
Rexpeed Wide Mirrors
modena is offline   Reply With Quote
Old 01-20-2014, 12:03 PM   #59
Deathalo
I might eventually go back and do something like this, I was thinking of maybe using some connector pieces that I can crimp onto the wires. It works fine now, I'm just not happy with the sloppy job I did :P
Old 01-20-2014, 01:48 PM   #60
tr1x5tuh
The Original Super Saiyan
tr1x5tuh's Avatar
Drives: 2014 SWP BRZ
my buddy had to re tap the green wire because it was so short where he couldn't get to it. so we tapped a longer wire and it made life so much easier lol
To each his own, Agree to Disagree
tr1x5tuh is offline   Reply With Quote
Old 01-20-2014, 02:00 PM   #61
Deathalo
Actually, I think I might take some of the excess tape off and get one of these shrink wraps: [ame="http://www.amazon.com/gp/product/B000GARZT8/ref=s9_simh_gw_p60_d0_i5?pf_rd_m=ATVPDKIKX0DER&pf_ rd_s=center-2&pf_rd_r=1WE10JN650AKX1BYDK9J&pf_rd_t=101&pf_rd_p =1688200382&pf_rd_i=507846#productDetails"]Gardner Bender HST-999 Heat Shrink Tubing - Amazon.com[/ame]
[ame="http://www.amazon.com/Install-Bay-Heat-Shrink-Inch/dp/B0053PYAWQ/ref=pd_cp_hi_0"]Amazon.com: Install Bay Heat Shrink 1 Inch x 4 Foot: Car Electronics[/ame]
Do you think 1" is large enough to slide over the entire headlight harness? The solder should be pretty darn secure, it just looks so bulky and obvious with the tape on there, I'm thinking this heat shrink will make it much less noticeable that anything was fooled around with...
Old 01-29-2014, 09:02 AM   #62
tranat
tranat's Avatar
Drives: Subaru BRZ SWP Limited
Thanks OP!!!! I wanted these for a while now.
So I only had time to do the left side of the car, but the mod seem to be working already.
- Auto (night time): DRLs, HL, Boomerangs all turn on
The only problem is that
- Auto (day time): DRLs, but no Boomerangs
I'm curious whether this was a wiring issue I might have messed up on, or because I haven't worked on the right side yet?
Interesting point is that the DRLs on both sides seem to be working just fine (staying on all the time as intended) although I haven't even worked on the right side yet.
Can this be the reason why my boomerangs won't turn on with my DRLs? Thanks in advance.
tranat is offline   Reply With Quote
Old 01-29-2014, 10:22 AM   #63
TallTerror13
TallTerror13's Avatar
Drives: 2014 DGM BRZ & 2015 WRB WRX
@tranat how many diodes are you using per side?
Sent from my DROID RAZR using Tapatalk
TallTerror13 is offline   Reply With Quote
Old 01-29-2014, 10:40 AM   #64
tranat
tranat's Avatar
@TallTerror13
Only one diode on the left side. I haven't touched the right side yet, maybe later today if I get a chance
Old 01-29-2014, 10:51 AM   #65
TallTerror13
I think that you have the diode in the wrong spot from what you are saying. To me it sounds like you have the diode on the wire coming up from the DRLs and not on the wire for the boomerangs.
The DRL power wire and the boomerang light wire should be together, there should then be a diode with those two wires on the one side and then the boomerang power wire out of the harness on the other side.
Both DRLs are probably lighting up because they use the same power supply wire on the harness, so power to one is power to both.
Hope that helps.
Old 01-29-2014, 07:16 PM   #66
tranat
tranat's Avatar
Thanks @TallTerror13; will try this out this weekend.
Old 01-30-2014, 02:23 AM   #67
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Originally Posted by tranat View Post
@TallTerror13
you need to wire diodes both sides!
Inviato da mio iPhone usando Tapatalk
Trap63 is offline   Reply With Quote
Old 01-30-2014, 11:14 AM   #68
ericw2k
What if I installed the diode reverse?
I drive slow!
ericw2k is offline   Reply With Quote
Old 01-30-2014, 11:16 AM   #69
TallTerror13
The boomerangs would work with the DRLs but not work when they normally would.
Old 01-30-2014, 09:41 PM   #70
Lithium
Lithium's Avatar
Drives: like an asshat
Keep in touch, shot me a message if you have anymore trouble. please do both sides to eliminate the possibility of any feedback from another section of the circuit.
Lithium is offline   Reply With Quote
WTB Stock headlight projectors from retrofit OR a broken headlight official_george Exterior Parts (Aero, Lighting, Etc.) 3 12-02-2013 03:32 PM
Right headlight wont turn on Matt90 Issues | Warranty | Recalls / TSB 9 11-11-2013 03:56 PM
My turn. =( jonbonazza Scion FR-S / Toyota 86 GT86 General Forum 28 07-15-2013 02:57 PM
Voice Commands with new turn by turn in IOS6? jadewbj Electronics | Audio | NAV | Infotainment 0 09-21-2012 10:11 AM
