| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: MDX, Camry
FYI: Mileage left after the re-fuel light shows up ...
Our car has a gas tank of 13.2 gallon. Today I drove it 3-5 miles after the light is on, went to a gas station and put 11.6 gallon in. So there should be about 1.6 gallon left. With my gas mileage about 32 highway and 25 ish local, the minimum amount of mileage I have left is about 40 miles. Just FYI.
#2 |
Drives: None (yet)
The manual states that the fuel light comes on when approximately 1.8 gallons are left in the tank, so you're close! I'm thinking the target was ~50 miles of not-WOT driving.
#3 |
Drives: SWP BRZ Limited MT
There's been a few threads about this, it definitely does come on prematurely, mine comes on when there is about 2.5-3 gallons left.
#4 |
Drives: WRB Brz
I've gone approximately 50 miles after the light came on, all freeway. Needle was almost all pegged on E.. was scary.
| The Following 2 Users Say Thank You to hellyvin For This Useful Post: | Kuri (01-26-2014), tripjammer (02-05-2014) |
#5 |
Drives: 2014 DGM BRZ MT
There's usually more capacity than the published volume. Connecting hoses plus some design margin in the tank will get you another gallon or so.
I have a Mini Cooper S with a published capacity of 13.2 gals and I've pumped in over 14 gallons many times. I haven't discovered my BRZ's actual capacity yet... |
#6 |
Drives: 2013 FRS, 2024 Trueno
You can go below the E and still have the car run fine. Granted its advised not to do this as the fuel wont be in contact with most of the pump to keep it cool. Most I have filled up in this car was 13.1 gallons. I call that scary.
| The Following User Says Thank You to Shneegle For This Useful Post: | tripjammer (02-05-2014) |
#7 |
Hook 'em
I'm usually filling up with 10-11 gallons from the pump. The fuel light comes on way too early IMO.
#8 |
Using Torque app, mine's come on consistently as soon as it hits drops below 2.5 gallons = so right at 2.4, the light comes on.
Before switching over to E85 from 93octane (and vice versa), I drive my car up & down the street at the E85 station trying to run my tank as low as possible. I went 64 miles once AFTER the light came on. When I filled up following that, I got exactly 13.01 gallons into my tank (filled up until the auto-shutoff, then filled up slowly until the pump cuts off again). |
#9 |
#10 |
#11 | |
Drives: World Rally Blue BRZ Limited, MT
Man! I usually go 30 miles (all highway) after the light goes on and I thought that was a lot. hahaha. good to know that I could make it a bit further.
- World Rally Blue BRZ | Limited | Manual -
"Some guys think that having a better car makes them better than other guys, and those guys are right." -Top Gear |
#12 |
Drives: Gray.
I usually fill up the moment my needle goes below the quarter marker. Never seen the gas light and hoping to never do.
#13 |
Drives: Attitude
Checked this last time I filled up: ~1-2 miles after the light triggered, ~24MPH lifetime average. Filled up just over 10 gallons. You should EASILY be able to go 40 miles with the fuel light on, possibly upwards of 60.
#14 |
Wattya
Drives: 2018 Subaru WRX - Limited - 6MT
I just tested this on Friday night. I drove a good 55 miles after the light came on and when I went to top off it stopped right at 13.152.
| The Following User Says Thank You to BRZer86 For This Useful Post: | meeskee2 (01-30-2014) |
| Left Hand turn fuel starvation on WOT | Huehuecoyotl | Tracking / Autocross / HPDE / Drifting | 105 | 08-05-2021 07:12 PM |
| Mileage when you left the dealer? | neutral | Scion FR-S / Toyota 86 GT86 General Forum | 78 | 03-03-2020 12:27 PM |
| How many miles of gas is left after the light comes on? | nab335 | Scion FR-S / Toyota 86 GT86 General Forum | 30 | 08-24-2015 02:33 PM |
| Actual experienced real world fuel mileage MPG? | R8 | Scion FR-S / Toyota 86 GT86 General Forum | 88 | 07-24-2012 07:50 AM |
| Subaru shows courage to cut horsepower for fuel economy | [es vi: eks] | Engine, Exhaust, Transmission | 11 | 05-01-2011 02:02 PM |
