| Mid-Atlantic DC, DE, MD, VA, WV |
#15 |
Thanks
#16 | |
Drives: 2013 FRS Whiteout
I think you're misinterpreting my post, that is stated in terms of price, not quality, as in, you're getting the best struts and springs for the same price as the worst coilovers. PS- No need to make insults, you don't know what you're talking about if you think I'm not familiar with these cars. |
#17 | |
Thanks
#18 | ||
Drives: BRZ and NA
#19 | |
Drives: BRZ and NA
One thing to also consider is your alignment. I had a decent performance/ street alignment done at AIG (I can get the specs when I get home if you want). But the big thing is that this car has zero camber correction from the factory. That means getting bolts/mounts for the front and bushings or control arms for the rear. I went with the OEM crash bolts for the front and I got the upper control arm bushings for the rear. The front bolts don't allow a *ton* of correction, but it's better than nothing, and they're stupid cheap. |
#20 |
Drives: GBS BRZ
I decided to go for it and got the springs and koni shocks: http://www.ft86club.com/forums/showthread.php?t=56879
Thanks for the advice! |
#21 |
Keep calm and drive on
Drives: 2013 WRB BRZ Limited 6M
Did you get camber bolts and/or LCAs? Curious if camber can be dialed back in with factory components and a mild drop.
#22 |
Drives: GBS BRZ
I had camber bolts put in, but no alignment yet. I don't believe things are off too much, but it's nice to be sure. I'll have an alignment done relatively soon. A little camber feels pretty good.
#23 |
Drives: BRZ and NA
Good pick up! Also, you won't be able to change the camber in the rear without upper control arm bushings or adjustable lower control arms. The crash bolts are the easy solution to get some correction in the front.
#24 |
Drives: GBS BRZ
Thanks! Your review/recommendation was key in my decision. I don't think I am going to go too far off of stock settings. I will post an alignment sheet when I get one done. Any recommendations for settings for something that will be 99% street use?
#25 |
Anorexic
Drives: 2003 Honda S2000 Suzuka Blue
#26 |
Drives: Gray.
I agree. I was simply comparing current costs without future rebuilds.
#27 |
Anorexic
#28 | |
Drives: BRZ and NA
I put a bit of toe-in on my rear to help with stability. You may want zero toe. |
| Eibach Springs | Astra^EC | AFRICA | 21 | 09-18-2013 04:03 AM |
| Eibach Pro-Kit Springs - NEW IN BOX | Canivideo | Brakes, Suspension, Chassis | 2 | 08-20-2013 08:44 AM |
| Eibach pro kit springs | ihaskrayon | Brakes, Suspension, Chassis | 7 | 07-17-2013 04:28 PM |
| $140 Eibach pro kit springs | mav1178 | Southern California | 2 | 07-12-2013 06:47 PM |
| FS : Eibach Pro-Kit Springs | Brandon86 | Canada Classifieds | 3 | 04-17-2013 12:46 PM |
