Old 01-28-2014, 02:25 PM   #15
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by jamesm View Post
what size turbo is that? impressive numbers, but peak torque at 6500+rpm? damn...
great work as always.
FP used should put your mind at ease a bit...
The Following User Says Thank You to Sportsguy83 For This Useful Post:
jamesm (01-28-2014)
Old 01-28-2014, 02:34 PM   #16
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by PrimeMotoring View Post
Those are standard on the series 10
I suddenly want the series 10 FRS now...
Old 01-28-2014, 03:04 PM   #17
jamesm
Id pay them to remove them lol. Looks cheesy to me. To each his own I guess.
The Following 5 Users Say Thank You to jamesm For This Useful Post:
DaBrz (01-28-2014), ecko04 (01-28-2014), ericvanderwoodsen (03-18-2014), OrbitalEllipses (01-28-2014), Sportsguy83 (01-28-2014)
Old 01-28-2014, 04:00 PM   #18
Sportsguy83
Drives: Limited BRZ
We just finished up another P&L Motorsports Stage 1 Turbo Kit and our very own Flex Fuel kit on this Series 10 FRS. Jr was able to extract 467whp and 357wtq on E85 on only 18psi.
Modlist:
PERRIN Performance 3" Non Res Cat-Back
Injector Dynamics ID1000cc Fuel Injectors
DW65c Fuel Pump
Prime Motoring Flex Fuel
4 Bar Map Sensor
Grimmspeed EBCS
ACT HD Race Clutch Kit
@JuniorAWD
No fuel starvation issues whatsoever with the DW65 at those power levels at all?
No concern on running it past half a tank? Target AFR holds all the way to redline?
Old 01-28-2014, 04:08 PM   #19
PrimeMotoring
PrimeMotoring's Avatar
Drives: FRS with 2jz, 2015 STI 9.68@147
@JuniorAWD
Im sure Jr will chime in but we have installed the DW65c on 4 P&L cars running those power levels and about 15-20 lesser powerful kits and never had an issue.
PrimeMotoring is offline   Reply With Quote
The Following 2 Users Say Thank You to PrimeMotoring For This Useful Post:
Frs300 (01-28-2014), Sportsguy83 (01-28-2014)
Old 01-28-2014, 04:55 PM   #20
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
You are getting caught up with whats the "norm" for most dyno plots you see on other cars. Peak torque has more to do with characteristics of the engine and also gearing rather than when a turbo comes into full boost. This could also be Jr limited the way boost comes in to preserve the stock motor at these power levels. Im sure he will chime in here with an explanation and boost plot.
Look at the plots below, I searched others and could not find anything that suggests otherwise on these cars. Your car was turbo, by any chance do you have a dyno sheet that shows us what you are talking about exactly?
I do. This is my car with a GT2871R and note the flat torque band that corresponds with when max boost is reached:
Old 01-28-2014, 05:26 PM   #21
JuniorAWD
Drives: GTR 9.0@170_XT 10.8@130_GC 8.3@165
Another interesting dyno sheet. I am not understanding why you aren't getting peak torque as soon as the turbo hits max boost which should be in the 4000 to 4500 RPM range. Also it looks like the power was still increasing so why not rev it out to 7400 to 8000 RPM? Can we get a boost plot?
Whats interesting about it?
Where does it say that because a turbo hit max boost it needs to make max TQ at that same rpm? Where did it say that max boost was where you ASSUME it is?
Tuning strategy will play a huge roll in how the power is delivered.. That will also play a roll in longevity of the motor. I dont like windows in the block
RPM is off on the graph it seems, as the rev limiter is set to 7800 on this car and all P&L turbo kit cars I tune.
JuniorAWD is offline   Reply With Quote
The Following User Says Thank You to JuniorAWD For This Useful Post:
ecko04 (01-28-2014)
Old 01-28-2014, 05:39 PM   #22
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
care to answer the question about the fueling ? There is a shop that claims that the DW65 maxes out at 420whp
Old 01-28-2014, 06:29 PM   #23
JuniorAWD
Hmmm.. I would say that is inaccurate based on my data. I would agree that on e85 its not good for much over 480-500whp though.
Old 01-28-2014, 06:33 PM   #24
JuniorAWD
That is a small turbo making about 100ftlbs less then the posted car. You can manipulate TQ curves with boost delivery and timing. If the posted car was only making 250ftlbs I would have easily let it make TQ lower. For the safety of the rods on a car running 18psi I dont just let it hit hard down low... also for traction you dont want a huge hit of tq/power all down low.
Old 01-28-2014, 06:34 PM   #25
SmsAlSuwaidi
Boosted
Thanks, good info
Care to answer @sportguys83 questions about fuel delivery bellow half tank as thats another concern
Sent from my IBrick
Old 01-28-2014, 06:59 PM   #26
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
So then it must be still making power in that added band, the only thing I would attribute this to is limiting the boost down low so the tq and boost build by the end of the graph making it a much more user friendly and meaty powerband? Idk shot in the dark I guess. Either way, this is a proper turbo kit, good job!
Old 01-28-2014, 07:01 PM   #27
SmsAlSuwaidi
Boosted
I think the way trq kicks in the end is by the use of the ebcs
Sent from my IBrick
Old 01-28-2014, 08:14 PM   #28
JuniorAWD
Sent from my IBrick
Yep, i don't hit the motor with 18psi as soon as I can. It is slowly introduced to lesson wheel spin, or at least create spin with acceleration and not just utter tire destruction lol
As for the RPM, its off about 300-400rpm it would seem.
One other thing I want everyone to understand is that the shop is NEW to the dyno, and little things like rpm scale, smoothing etc is still being figured out.
With that said we have a few guys that will hit the track though, and it will verify the numbers for us. Im a big believer in actual performance not dyno numbers.
Jr
Anyone had any problems with Prime Motoring Frs300 User/Vendor/Sponsor Reviews, Feedback, Comments 40 01-19-2016 03:08 PM
Gauging interest in a Prime Motoring/Jrtuned Dyno Day in South Florida PrimeMotoring Software Tuning 13 05-26-2015 10:07 AM
Prime Motoring and JR Tuned....the best whitefrs User/Vendor/Sponsor Reviews, Feedback, Comments 25 02-12-2014 06:58 PM
Gauging interest in a Prime Motoring/Jrtuned Dyno Day in South Florida PrimeMotoring Southeast 0 01-22-2014 11:40 AM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
