#85 |
i don't think most people track their car like that, and the ones who do understand that they need cooling upgrades to do it.
just because a car cant go WOT around a track for 30 minutes without overheating doesn't mean that it's not perfectly fine for the street, autotcross or whatever else. if that were the case, just about every stock inexpensive sports car made (and most expensive ones) would be considered unsuitable for street use. it's very rare to find a box stock car that can be beat on like that in those conditions and not overheat. |
| The Following User Says Thank You to jamesm For This Useful Post: | Sportsguy83 (01-28-2014) |
#86 |
I plan on picking up another hood down the road to vent for the track if my temperatures aren't usable. But I don't have the skill to use the power my car has. I just plan on taking it to causal non competitive events to enjoy my car in a safe environment. For canyon driving I am sure with enough effort my car should enokay considering I primarily run e85. Though these concerns are why I did a supercharger originally. Now I will get an idea what it is like on the exact opposite with a top mounted turbo cooking my engine bay.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#87 | |
I Love custom Turbo kits
Drives: Limited BRZ
#88 |
Drives: UM86 - 6MT
@Sportsguy83 Since most people aren't going to track the car hard and will probably drive street mostly - what would your $5-6k FI build for a 'DD spec' include/look like?
#89 |
Supercharge. Then you don't have to worry about the hotside piping of a turbo, and all the radiant heat it adds.
| The Following User Says Thank You to CSG Mike For This Useful Post: | 86 South Africa (10-25-2015) |
#90 | |
While being able to do a quick street pull is nice, I want more than that. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | yo joshman (09-17-2015) |
#91 | ||
Drives: Limited BRZ
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | 1086 (01-28-2014) |
#92 | |
i definitely get your point though.. some cars have cooling/heat soak issues. if i had an innovate kit, that wouldn't happen lol. |
#93 | |
Junior
Drives: a car
#94 |
Drives: Limited BRZ
Ptuning has the best location heat wise, heat will flow completely away from the engine.
#95 |
You can, such as the P-tuning or STS, but that comes at the cost of transient response and spoolup time.
#96 | |
#97 |
Junior
Drives: a car
Damn. There really isn't a good compromise. Good spool time = high heat.
Low heat= more spool time... I got 99 problems, 86 of them in one lol
#98 | |
Drives: Limited BRZ
BUT for a true DD with the casual spirited run (as long as you are really really real with your goals and they don't change much) and considering this is FI out the door, (meaning everything else is stock or at the most some exhaust mods), my vote goes to AVO. I almost picked up a S/C but I don't like dealing with belts snapping, oil inside them replacement or them using engine power to move. I also did not pick other turbo kits because either quality is truly garbage or there are some heat issues for dd'ing (temps might go a little bit up on stuck traffic). My choice also disregards CARB certification. So my choice goes like this: AVO stg. 1 $4100 Includes basemap safe for 91 octane gas in California (easy to install yourself) BPV to recirculate turbo blow off $125 AEM Failsafe $300 One gauge pillar pod $50? FBM Oil Cooler $600 ECUTEK License/Cable ~$600 Brake pads/fluid/SS lines $300 Catch Can $300? Turbo blanket $100 Total: $6475 That is really as low as I would go. I would expect this setup to last, be fun, responsive, not overheat and be safe with stopping power. Some prices might vary (brakes might be only $200) so there is a little wiggle room to get it close to $6K and also the Catch Can is not life or death necessary on a 5 psi car, but I would add it because it helps extend the life of the motor.
| FT86 Buyer's Guide! FRS vs. BRZ Differences Detailed! [Video + High Res. Stills] | Rosso_Corsa | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 11-03-2013 04:10 PM |
| First time buyer - help! | chotemaamu | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 02-27-2013 12:21 PM |
| FRS as a Daily Driver? | Pake1 | Scion FR-S / Toyota 86 GT86 General Forum | 104 | 08-15-2012 11:48 PM |
| Will the BRZ be your daily driver | WRXGuy1 | BRZ First-Gen (2012+) — General Topics | 47 | 05-23-2012 12:15 PM |
| The daily driver | KiingDavid | CANADA | 25 | 02-06-2012 01:14 PM |
