Old 01-27-2014, 03:04 PM   #1
Starscream15
Starscream15's Avatar
Drives: 2013 Subaru BRZ - DGM
Youtube Video Conversion for 86 Head Unit
As I live in Minnesota, I find I have very few *fun* car-related things to do during the winter time as my BRZ hangs out in the garage.
I decided to create a how-to for ripping Youtube videos and also for using Handbrake to convert the files to the correct format while also maintaining the best quality. These videos HAVE TO be played from USB. Our head units to not support video from the SD Card (At least according to the manual). I have not tried playing from the SD personally. There are many ways to download videos from Youtube but this is the easiest I could come up with for those who are not A/V nerds
Reasons for using 640x368..
I realize the maximum resolution is 720x480, but 4:3 looks like shit, IMO. 640x368 is the largest 16:9 format I could get to work and the quality is near flawless. If you dig very large black boxes on the side of your video then use that setting. The quality will still be great.
Let me know if I've missed anything and I will fix it promptly. I suppose this could be moved to the DIY section but since it's Audio related I put it here.
1.) Get Handbrake, install Handbrake!
http://handbrake.fr/
2.) Pick a youtube video
Go to the video that you want and add "ss" after http://www. in the url.
3.) Download the 720p option
When you get to the download page (You will be warned that it's a fishy site, continue past the warning. The site is fine). Chose the 720p option.
4.) Once the video is downloaded, open Handbrake and select the video from the "Source" option.
5.) Rename the file output correctly. Sometimes by default, Handbrake will name the file with a .mkv extension. Make sure to change it to .mp4 before continuing. Under the picture tab make sure to change anamorphic to "None" and change the resolution to 640x368 (See top of post for reason).
6.) Under the Video tab, change the video format to MPEG-4 and choose Constant Framerate, set it to 30. Most youtube videos are 30fps but some are 23fps, you will not notice the difference with the finished product. Also, set Constant Quality to 1 if it isnt already.
7.) Under the Audio tab, change the codec to be Auto-Passthru
8.) Hit start and the video will convert quickly. Things to note here, the final video is usually about 100 meg but can be as low as 30. If the quality is bad for some reason, try converting it again. I did have a couple that went low-res for an unknown reason and they should be perfect quality.
Enjoy!
Starscream15 is offline   Reply With Quote
The Following 3 Users Say Thank You to Starscream15 For This Useful Post:
FRSHBRZ (01-27-2014), kalamitykode (07-06-2014), woode (07-06-2014)
Old 01-27-2014, 03:31 PM   #2
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
i'm sure a lot of people will find this useful. thanks for writing it up!
phanguy is offline   Reply With Quote
The Following User Says Thank You to phanguy For This Useful Post:
Starscream15 (01-27-2014)
Old 01-27-2014, 06:08 PM   #3
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I should try this later
Old 01-27-2014, 10:18 PM   #4
FRSHBRZ
Drives: 2014 Subaru BRZ LTD 6MT SWP
Great write up!
FRSHBRZ is offline   Reply With Quote
The Following User Says Thank You to FRSHBRZ For This Useful Post:
Starscream15 (01-28-2014)
Old 01-27-2014, 10:37 PM   #5
dbrandt01
Drives: none
Good write up, just saying another option for downloading videos from any site, even Facebook is Video Download Helper it's an Add on for Firefox. If they video is uploaded in 720p or 1080p there is usually an option for downloading it in that quality. I won't post a link to it though a simple google search brings it up as the first result.
dbrandt01 is offline   Reply With Quote
The Following User Says Thank You to dbrandt01 For This Useful Post:
Old 01-28-2014, 12:42 AM   #6
Starscream15
Yeah, lots of ways to download though. The reason I don't download the 1080p version is that it (1080p nor 480p version) doesn't include an audio stream. Perhaps the other helpers out there are able to grab the audio stream as well?
It needs to be spliced together making much more work and other applications will be needed.
EDIT: I got un-lazy and uploaded the attachments so I could insert them correctly. Yay for easier to read!
Old 01-28-2014, 05:33 AM   #7
Tamoor
Tamoor's Avatar
Drives: Frs- white out
does this work with bespoke on frs?
Tamoor is offline   Reply With Quote
Old 01-28-2014, 02:15 PM   #8
Starscream15
Good question.
I don't know anything about the Bespoke unit but if it supports .mp4 video, my guess is this tutorial will work with some tweaks to the resolution you set on the output video.
Old 07-06-2014, 11:48 AM   #9
woode
Boosted Member
woode's Avatar
Send a message via MSN to woode
Bumping an old thread because I was getting frustrated with the "Resolution Not Supported" with every common resolution.. thanks!
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
The Following 2 Users Say Thank You to woode For This Useful Post:
kalamitykode (07-06-2014), Starscream15 (07-30-2014)
Old 07-06-2014, 12:27 PM   #10
kalamitykode
I draiv de cah
kalamitykode's Avatar
Drives: 2022 BRZ Limited MT
Thanks for the bump, missed this thread the first time around. Awesome stuff.
2022SubaruBRZ/CrystalWhitePearl/Limited
kalamitykode is offline   Reply With Quote
The Following User Says Thank You to kalamitykode For This Useful Post:
Pinout for FRS Bespoke head unit - video inputs? ATSAaron Electronics | Audio | NAV | Infotainment 2 12-09-2014 11:59 PM
what kind of video connection does the stock BRZ head unit have? NYCsubaruBRZ Electronics | Audio | NAV | Infotainment 33 10-23-2013 12:08 PM
BRZ head lights -> JDM 86 head light conversion BRZPDX Cosmetic Modification (Interior/Exterior/Lighting) 6 08-02-2013 11:47 AM
Scion FR-S vs Mazda MX-5 Club Head-to-Head (Review and Video) M-17 FR-S / BRZ vs.... 96 03-05-2013 03:40 PM
Video on FR-S head unit? wparsons Electronics | Audio | NAV | Infotainment 2 12-18-2012 04:31 PM
