Drives: 2013 Subaru BRZ & 99' Ford Explorer
what kind of video connection does the stock BRZ head unit have?
what kind of video connection does the stock brz head unit have? is it rca? vga? 4pin?
THANKS |
Drives: 2013 BRZ GBS
Ive been looking into this as well, if no one answer by Thursday (next chance i have) ill take a look and let you know
Drives: 2013 Subaru BRZ (Galaxy Blue)
ummm... its confusing to me lol. i guess i would NEED a 16pin harness like they sell.. but 20bucks + shipping??? wtf. it should be $5.
can i grab one at a junk yard from a wrx or something? im guessing the one i need is for the white connection next to the gray one |
There are now 2 carseats!
Drives: 2013 DGM BRZ
It has an RCA connection for the rear video camera and will plaster a "be aware of your surroundings message" on whatever you pipe into it.
#6 | |
SLO NO MO
Sent from my Nexus 4 using Tapatalk 4 |
News to me...good news. What dongle is needed to access this aux in and how do we select it in the gui?
#8 | |
SLO NO MO
Not sure on selecting the input, but I suspect that it becomes an option once a signal is connected, sort of how USB becomes available when you plug in a USB thumb drive. Also, this signal is subject to the vehicle speed inhibitor. I have mine disabled by grounding the e-brake feed and putting in a switch on the VSS line, but I understand that some newer versions of the HU firmware will go one further and use GPS signal to determine the vehicle in motion and cut out the video signal in that case. |
Drives: 13 BRZ Limited 6MT GBS
It should be noted that it's a composite video input. RCA is typically used to carry composite video, but there's no RCA input on the HU itself, you need to fabricate a RCA female connector that inserts into the pins in the 16-pin (for backup camera) or the 28-pin (for aux) connectors on the HU.
Find an old computer case, and chop off the wires that go from the power/reset switches, speaker, and LEDs to the motherboard. Take the pins out, and they can be inserted into the factory connectors.
#10 | |
#11 |
Ok, I decided to give this a try. I just ordered a $30 hdmi to composite device. It is usb powered. It comes with a usb cable.
I also ordered a mini hdmi to hdmi cable because my Atrix HD has an hdmi mini output. Other phones would need a usb to hdmi and you'd have to check compatibility. Now I have to make a wire the is female rca to the two pins on the back of the HU. I think for starters I'll just set it up using insulated female spade connectors. I have a bunch of spsd switches. So, I don't need those. I have RCA cables somewhere as well that I can hack up. |
#12 |
I got all the parts (after screwing up and buying the wrong hdmi adapter).I'll test them out soon. Maybe even tonight. Then when I have it all up and running I'll make a DIY. Also, I've been working on writing a Tasker plugin so you can autostart Torque when you plug in the hdmi cable. http://forum.xda-developers.com/show....php?t=2439287 Any android devs want to help me out? |
#13 |
Did some tinkering tonight. Unfortunately you can't seem to get rid of the parking guidelines. I even tried adjusting them so they were off screen, but that didn't work. In the "line diag" hidden menu you can select a couple of presets for 4 door or 5 door or SUV, but you can't select the other buttons (I guess they are disabled).
The good news is that the input works just fine. Does someone have the pinout for the aux in (28 pin) connector? Last edited by robot; 10-02-2013 at 02:06 AM. |
#14 |
Drives: limited brz
If you can post any pictures I would be so happy! Haha
| Pinout for FRS Bespoke head unit - video inputs? | ATSAaron | Electronics | Audio | NAV | Infotainment | 2 | 12-09-2014 10:59 PM |
| FS: Stock FR-S head unit | ghost86 | Audio/Visual, Electronics, Infotainment, NAV | 4 | 11-09-2013 01:49 AM |
| Stock head unit. | Flawless22 | Audio/Visual, Electronics, Infotainment, NAV | 1 | 03-27-2013 02:39 AM |
| Stock head unit | fitcious | Electronics | Audio | NAV | Infotainment | 1 | 01-16-2013 05:57 PM |
| Video on FR-S head unit? | wparsons | Electronics | Audio | NAV | Infotainment | 2 | 12-18-2012 03:31 PM |
