Old 01-12-2014, 02:51 PM   #1
Kodi
Kodi's Avatar
Drives: Asphalt FR-S
Basic STX build?
Hey. Im a relative newcomer to autocross, and I bought my Frs to get more involved. I already have some very mild mods on my car, ie: exhaust delete, 17x9 wheels/ RS-3s, Open Flash Tablet map, that would put me into STX in SCCA autocross. Could I get some suggestions as to what mods I should do to make the car "reasonably" competitive in this class. I have held off on suspension mods till now, but would like to pull the trigger. I am trying to avoid spending a fortune, but dont want to be so outclassed as to be a joke. I know seat time is the best investment, and I plan on getting lots of that (2-3 events a month for the rest of the year). Thanks!
Kodi is offline   Reply With Quote
Old 01-12-2014, 03:29 PM   #2
toeout
Shocks, springs and front bar, assuming you get the desired camber numbers from lowering.
I believe you can get good coilover kits around $1600-$1800 ( RaceComp Engineering and Ground Control ), but I'm not exactly sure what all they include ( top mounts/ camber plates etc.)
toeout is offline   Reply With Quote
The Following User Says Thank You to toeout For This Useful Post:
Kodi (01-12-2014)
Old 01-12-2014, 03:37 PM   #3
RedBRZ80
Drives: 2013 Red BRZ
Advice.. Lots of seat time without changing the car.. First year in..worst thing you can do is keep changing pArts on the car.
RedBRZ80 is offline   Reply With Quote
The Following 3 Users Say Thank You to RedBRZ80 For This Useful Post:
Kodi (01-12-2014), Propaganda (01-28-2014), stock (01-28-2014)
Old 01-12-2014, 03:38 PM   #4
fstlane
fstlane's Avatar
Drives: BRZ Limited
With a $300 set of performance springs your car will be very competitive at a club level. I'm running a similar setup to yours and placed 1st in STX, 3rd on PAX and 9th fastest raw time out out 97 entries for our last LVRSCCA event. My mods are 17x9 wheels, 245/40 Zll tires, RCE yellow springs, Openflash Tablet, Borla headers and some camber. I recently got involved in autocross myself last August so it really shows how good these cars are with minimal prep and experience. Good luck and have fun!
fstlane is offline   Reply With Quote
The Following 2 Users Say Thank You to fstlane For This Useful Post:
Kodi (01-12-2014), Racecomp Engineering (01-29-2014)
Old 01-12-2014, 04:06 PM   #5
Kodi
Kodi's Avatar
Thanks guys! Much appreciated! I was looking into RCE yellows, but my local shop is recommending Swift springs. Any thoughts? Also, are Koni sport shocks a worthwhile change?
Old 01-12-2014, 04:23 PM   #6
xwd
You could be competitive with your car as it sits now.
I think either one would work, the Swift if I recall have higher rates in the rear where the RCE have the same rates front and rear. I'd probably take the RCE's myself. I'd probably look into a way to adjust the front camber as well, either bolts or plates of some sort.
TIC had a thread about some new lower-cost coilovers from HVT which may be worth looking into. Feal also makes some fairly low cost nicer coilovers, two of the top 10 cars in STX at nationals last year were on them.
The Following 2 Users Say Thank You to xwd For This Useful Post:
fstlane (01-12-2014), Kodi (01-12-2014)
Old 01-27-2014, 10:42 AM   #7
PoorMansRacing
Anorexic
PoorMansRacing's Avatar
Drives: 2003 Honda S2000 Suzuka Blue
I'd also recommend RCE yellows. Crash bolts are a good investment too.
PoorMansRacing is offline   Reply With Quote
Old 01-27-2014, 01:44 PM   #8
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
I'm kinda in the same boat as OP. In the spring, I plan on getting tires (RS3s or Rivals), Shocks(Koni), Rear LCAs (SPC), crash bolts (SPC), and springs (RCE but still deciding between yellows or tarmacs).
Books is offline   Reply With Quote
Old 01-27-2014, 08:02 PM   #9
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
What is your budget??? That would be crucial info to what you can do. I can give some suggestions.. depending on what your willing to spend..
Bill
Scooby South is offline   Reply With Quote
The Following User Says Thank You to Scooby South For This Useful Post:
Kodi (02-03-2014)
Old 01-28-2014, 01:12 AM   #10
Kodi
Kodi's Avatar
Bill
I want to stay around 2k. I already have the tune and an axle-back exhaust, 17x 9 wheels anR-S3s. I also have a Whiteline front bar and ground- control coilover sleeves to install. I plan on using the stock shocks for a bit and see how they work out. I do use this car for my daily commute, so I dont want it to be too low or crazy stiff. Any guidance is much appreciated.
Jon
Old 01-28-2014, 10:20 AM   #11
piknockout
Drives: 2014 BRZ
If you want a better ride, better quality shocks are the answer. You can have a stiff setup that drives well if the shocks are good enough. Stock shocks with just springs could ride worse than a proper coilover setup. Just something to think about.
As far as suspension goes, my general belief is to do it right or don't do it at all. If you half ass it, you're just going to end up buying something else later. Do it right the first time.
piknockout is offline   Reply With Quote
The Following User Says Thank You to piknockout For This Useful Post:
Kodi (01-28-2014)
Old 01-28-2014, 12:43 PM   #12
stock
stock's Avatar
Drives: 2015 FRS Steel (manual)
Save your money and just race. Loads to learn.
stock is offline   Reply With Quote
The Following User Says Thank You to stock For This Useful Post:
Kodi (01-28-2014)
Old 01-28-2014, 12:51 PM   #13
blkwrxwag
Drives: DS FRS
Come out to Cal. Speedway for the next practice on Feb 8th. I have a full STX build, and we can chat.
Let me know if you need help signing up.
-Max H.
blkwrxwag is offline   Reply With Quote
The Following User Says Thank You to blkwrxwag For This Useful Post:
Kodi (01-28-2014)
Old 01-28-2014, 05:12 PM   #14
Scooby South
Conedancer
^^^ talk to Max.. he's a good one to have on your side.. ....especially since your in SoCal.. also great level of competition there.
Bill
Kodi (01-28-2014)
Borla UEL basic thoughts/ review loogs Engine, Exhaust, Transmission 39 09-28-2013 01:18 PM
What basic tool set to get? ZionsWrath Off-Topic Lounge [WARNING: NO POLITICS] 5 09-05-2013 11:46 AM
Visual Basic and SQL Trashed675 Off-Topic Lounge [WARNING: NO POLITICS] 10 06-10-2013 12:18 PM
GC basic coilovers / Cusco Strut bar Evilbrz151 Brakes, Suspension, Chassis 3 03-29-2013 09:35 PM
