Old 01-27-2014, 03:43 PM   #29
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Here's the entire DIY.
Disclaimer: This tutorial requires proficiency with a soldering iron. I am not responsible for any damage you or these instructions cause to your vehicle. Proceed at your own risk. This tutorial assumes you are already planning to open your headlights. I would recommend having all the necessary parts and tools in hand before disassembling your headlights. And the most important thing, READ THE ENTIRE TUTORIAL BEFORE BEGINNING!
Parts List
4x 25mm Square x 15mm High Alpha Heat Sink - 15.6 °C/W
2x 700mA, Externally Dimmable, FlexBlock Wide Range DC Driver - With Leads
1x Arctic Silver Low Thermal Resistance Adhesive
Tools Needed
Exacto or Hobby Knife
Soldering Iron with a conical tip - 20W to 30W is plenty
Solder - Pb free is always preferable, smaller gauge is easier to work with
Disposable plastic plate or cardboard to mix thermal epoxy on
Disposable plastic silverware or something to mix epoxy with
Wire cutters
Wire strippers
Double sided adhesive strips/tape - DO NOT SKIMP ON THESE - can be found at home depot or any autoparts store
Digital Multimeter - to test for continuity
Ever since I first saw the BRZ running lights on with the DRLs, I hated it and wondered why Subaru didn't make them brighter. I wanted the boomerangs to be just as bright as the DRLs, or close to it. This tutorial properly addresses this issue, electrically and thermally.
The boomerangs are lit up by two Luxeon Rebel Neutral White LEDs. These LEDs are designed to be "driven" at 700mA typically and even up to 1000mA with the proper thermal management. From the factory, these LEDs aren't driven at all. That term typically means there is control circuitry acting as a current source to the LEDs. This means that no matter what the input voltage to the controller is, the controller maintains the proper amount of current going to the LEDs. This is the schematic for the stock circuit.
The stock circuit has nothing like a proper current source. It's much more simple and therefore much cheaper to manufacture. At 12.7v source voltage, the circuit pulls 154mA through each LED. The equivalent resistance of the parallel resistor circuit is 39 ohms. The dual capacitors in parallel with the Zener diode in reverse bias function as a pseudo-voltage regulator. The makes the boomerangs much less susceptible to dimming from voltage drops related to drops in engine idle rpm. The DRLs are really bad about this because there is no control circuitry or capacitor/Zener diode circuit on them. If you ever park your BRZ close to and facing a wall, keep your foot on the brake while slowly letting the clutch out, just enough to drop the engine rpm slightly, you'll see the DRLs dim, or even turn off. The boomerangs won't do this because of this circuit.
Because these LEDs are running at 154mA, they require zero thermal management. Luxeon provides recommended board layout and solder masking files freely on their website. This layout has "vias" in the board which are basically plated thru-holes. They help draw some of the heat away from the LED and dissipate it to the air. Running at such low current, these vias are all the LEDs need to remain cool. Once you start increasing the current to the LEDs, thermal management (read Heatsinks) is needed.
Let's start by addressing what changes need to be made to the stock circuit boards. You are basically rewiring the circuit boards to accommodate the current driver and getting rid of unnecessary components. I'm assuming you have already disassembled the headlights and you have the this piece sitting in front of you.
Step 1: Remove the 3 screws that hold the boards to the plastic piece.
Step 2: Cut the white wire at the red X, cut the red wire at the red x, and throw away the board with the huge resistors.
Step 3: Take the soldering iron and heat up one side of the Zener Diode. It should be marked "ZNR" on the board. Heat up one side and lift up with the soldering iron. Your goal is to lift the contact up off the board. When you have one contact separated, apply the soldering iron to the other contact. This should free the Zener diode from the board. Throw it away.
Step 4: Apply a good amount of new solder to the pads where the Zener diode used to sit. You will be soldering two wires directly to these pads.
Step 5: This is very very tricky so please take care as to which part of the board you are scoring. I'll start the description referencing the driver side headlight, but you can start with whichever side. You now need to "break" the copper trace leading from the negative side of the LED. In the following picture, you should see a red line directly in front of the blue wire. You need to take an exacto knife and SCORE the board, breaking the trace. This does take a good amount of pressure. Go slowly, and be very controlled. You do not want the blade to jump off the trace cutting something else on the board or yourself. After you cut the copper trace coming from the negative side (which is marked by the - symbols on the board) you need to check with the Digital Multimeter to make sure the now separate traces are no longer connected. If you do not ensure they DO NOT make contact, you will fry the LED as soon as you apply power. For the passenger side, do the same for both of the red lines. Score the board with the exacto knife until you are under the copper layer and well into the board material. Check for continuity and ensure there is none.
Driver Side
Passenger Side
Step 6: Now, you need to remove the white layer on top of the board in certain spots to be able to reconnect to the LEDs. This white layer is called the solder mask. You will need to take an exacto/hobby knife and lightly scrape the solder mask off until you see nice shiny bare copper. Take care to not scrape deeply into the copper. You are basically creating a new soldering pad on which you will solder the wires coming directly from the current source, so you will need a good amount of bare exposed copper. Refer to the above two photos. In the area you see the blue wire soldered, you need to expose that much copper. Do not scrape off the solder mask on adjacent copper layers!
Step 7: You will need to cut off one of the old supports for the resistor board so that the LED driver will lay flat on the assembly. I don't have any photos, but it is the plastic support in this photo circled in red.
Step 8: I will start by showing a photo of what you want your end result to look like. On the left is the modified assembly, on the right is the stock assembly. You will need to lay the board and current source in place on the plastic piece to determine how much of the leads coming from the LED Driver you will need to cut.
Once you figure out the correct wire lengths, strip the blue, red, white, and black wires. Cut the purple and gray wires completely off. You will not need them as you are not going to be dimming the LEDs.
Step 9: I highly recommend twisting the ends of the stripped wires to ensure you have no fraying or stray strands. Tin the tips of the black, red and blue wires. Referring to the photos in Step 5, solder the red, black, and blue leads on to the correct pads on the corresponding sides. This should be clear from the photos.
Step 10: Place the newly soldered LED driver and remaining 2 boards back on the plastic assembly. You should now have the white wire from the LED driver and the red wire from the second LED board free. Cut them down to the correct length, place a small piece of heat shrink tubing over one, twist them together, solder, and apply heat to the heatshrink over the exposed wires. It should look like this when completed.
Step 11: Now that the electrical part is finished, set the boards on the plastic assembly and screw them into place. Apply enough strips of the double sided adhesive to the back of the LED driver to cover it well, and press it into it's final position on the assembly.
Step 12: Now you need to secure the heat sinks onto the boards. Take the two-part thermal epoxy and measure out equal parts. There is a video on the purchase website that I recommend watching. Mix the epoxy and apply it to the bottom of the heatsinks. Set the heat sinks on each board in the same places as shown below. Press firmly for at least 30 seconds. Allow the epoxy to fully set.
And the final product:
Step 13: When remounting the entire assembly to the headlight housing, there won't be enough clearance for one of the heatsinks on each side. You will need to trim some of the fins down in order for the entire assembly to sit flush on the mounts. Be conservative when clipping some of the fins down as you only want to take off just enough to allow the assembly to sit flush. The more material you remove from the heatsinks, the hotter the LED is going to run which diminishes the LEDs life.
Results:
You're finished! Now do the other side...
Acree is offline   Reply With Quote
The Following 3 Users Say Thank You to Acree For This Useful Post:
Andrew025 (01-27-2014), Inextirpable (01-27-2014), sprintertrueno86 (02-01-2014)
Old 01-27-2014, 09:38 PM   #30
soundman98
ProCrastinationConsultant
soundman98's Avatar
just curious-- what is the reasoning for using the flexblock series over the buckpuck series?
either way really happy to see luxdrive drivers used for the how-to. some of the most reliable drivers i've used..
Old 01-27-2014, 10:13 PM   #31
Acree
Acree's Avatar
The flexblock series can run 7 rebels in series. That's what I needed for my turn signals. The buckpuck can only run up to 6. And in this case, the flexblock is slightly shorter in height. That and the leads coming out of the side really lent itself well for this project. The buckpuck would honestly work just fine here.
They really are great drivers.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Old 03-07-2014, 03:00 PM   #32
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
Originally Posted by Acree View Post
Left is stock. Right is modded. It's really difficult to capture how much brighter they are with an iPhone.
I am electrically competent. Could you teach me how to do this via email?
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
Old 03-07-2014, 03:01 PM   #33
Acree
Acree's Avatar
No sir. That's not possible. Literally.
Old 03-07-2014, 03:03 PM   #34
Wonderbar
Driveway labs.
Wonderbar's Avatar
I actually just found the walk through you posted.
The Following User Says Thank You to Wonderbar For This Useful Post:
Acree (03-07-2014)
Daytime Running Light delete TSB! Memphis Issues | Warranty | Recalls / TSB 256 07-22-2017 10:55 PM
BRZ ‘s “boomerang” LED strip mystery DrakeM BRZ First-Gen (2012+) — General Topics 114 05-05-2015 12:00 PM
SCION FR-S LED DRL Daytime running light fog lamp cover GT/86 Cosmetic Modification (Interior/Exterior/Lighting) 12 07-20-2014 08:08 PM
Daytime Running Light/ Crystal Vision Ultra Memphis Cosmetic Modification (Interior/Exterior/Lighting) 14 02-08-2014 06:52 PM
scion led running light accents? Stryker Trailwood Scion FR-S / Toyota 86 GT86 General Forum 47 07-20-2013 09:48 PM
