Old 01-27-2014, 09:26 PM   #57
jamesm
Everyone arguing against electric FI is on the wrong side of history. It's an inevitability. Might not be there yet, but one day it will rule all. It's just not today.
Old 01-27-2014, 09:51 PM   #58
1086
1086's Avatar
Drives: UM86 - 6MT
I'm going to be down there in about 3 weeks can I get a ride along ?
1086 is offline   Reply With Quote
Old 01-27-2014, 09:55 PM   #59
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
I've priced out some options too and I'm sorta along the lines like you. But from what I've priced, you're looking closer to $7000 out the door. That's for an fa20club 60trim kit with all the ecutek stuff and a tune. Unless you can weld, you won't be able to go turbo under $5000. You may be able to swing an Innovate SC kit for under $5000 but that kit just won't get me to where I want to be hp wise. As well, there's not much head room for making lots of power with that kit so turbo is definitely the only option. I too would like a 260-280whp on 94 octane and be super safe and conservative. Ultimately, ~400whp is where I'd wanna be and going turbo will definitely make it easier.
hmong337 is offline   Reply With Quote
Old 01-27-2014, 10:07 PM   #60
CSG David
CSG David's Avatar
I want 94 octane.
Old 01-27-2014, 10:09 PM   #61
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
Feel free to explain how this is relevant to someone shopping FI options in 2014. Really, I'm all ears.
Ralph Spoilsport is offline   Reply With Quote
Old 01-27-2014, 10:13 PM   #62
1086
1086's Avatar
Drives: UM86 - 6MT
I don't think anyone is trying to challenge superiority. Its clear its not competing with anything, rather, the P-ESC is creating a new tier in FI options, at least in 2014 that is. Whose to say the potential in the next year+ ... could be great
Old 01-27-2014, 10:44 PM   #63
jamesm
it's not.. that's kinda the point of my post. just stating that everyone poo-pooing the people who are breaking the ground are going to feel like idiots some day soon.
Old 01-27-2014, 10:57 PM   #64
nelsmar
It can be done for the 5-6k range.
Here is a low end turbo build:
JDL EL Precision 48mm Billet Wheel Journal Bearing Turbo $3349
Omni 3 bar MAP $95
Ecutek License & Cable $650
Innovate LC-2 Wideband + Display (if desired) $165
Dyno time & Tuning fee's $600
Exedy Stage 1 Clutch + Flyhweel $400
Koyo Radiator $329
Total: $5580.00
Sure there are more things you could add like a fan shroud, exhaust upgrades, gauges if you wanted, etc. Mind you this is all at going rates, a lot of places may cut you a deal if you are buying a bunch of stuff at once.
My flickr - Canibeat
Local magazine scout
Old 01-27-2014, 11:01 PM   #65
nelsmar
Also if running lower boost you could go without the Omni 3 bar and the clutch... That saves $495 making the total $5085. Although this depends on the driver. I had 360WHP/260WTQ and it took a while before my clutch started to slip. I had ordered a new one and finally started pushing it to see what it would take to make it slip and I was quite surprised how it held up. But I don't do the whole drag racing thing my self.
Old 01-27-2014, 11:33 PM   #66
jamesm
radiator isn't necessary unless you're tracking the car. i live in florida, drive like an asshole (sometimes), and my car doesn't overheat. the wideband however is not optional. you'll need a boost gauge as well.
supporting mods really depend on how you plan to use the car. when i first did my turbo the car was 100% stock, and it worked well that way until the clutch went. the most beneficial thing i've done so far has been the full exhaust.
Old 01-27-2014, 11:34 PM   #67
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Care to expand on full exhaust beneficence
Sent from my IBrick
Old 01-27-2014, 11:35 PM   #68
nelsmar
I am stuck in the phoenix mindset. Pavement hits 150+F in the summer. LOL when you get IAT's of 120-130 and think "Damn thats good"! You know its warm.
So Boom there you have it. 5k 250HP kit right there. I also figured you would jump in the boat for no boost gauge by using boost cut. I recommend having gauges personally.
Old 01-27-2014, 11:37 PM   #69
jamesm
Sent from my IBrick
sure. my first upgrade after the turbo was a j2 catless front pipe, which was the only one bigger than 2.5" available at the time. it helped spool a bit, but wasn't that dramatic. next came the motiv overpipe, which aside from being beautiful didn't really do anything at all. lastly i added the perrin 3", and everything changed. it was like a whole new car. spool was faster, noticeably more power. it seems from my experience that the exhaust mods really don't do much until you get rid of all the stock bits and free it up. kinda makes sense when you think about it.
Old 01-27-2014, 11:38 PM   #70
jamesm
true you could always log boost.. but i've definitely had a wastegate line pop off and without a gauge, my motor would've blown up. it can happen, and gauges are cheap. zip ties and hose clamps are also cheap insurance, perhaps replacing said boost gauge once everything is dialed in lol.
FT86 Buyer's Guide! FRS vs. BRZ Differences Detailed! [Video + High Res. Stills] Rosso_Corsa Scion FR-S / Toyota 86 GT86 General Forum 23 11-03-2013 04:10 PM
First time buyer - help! chotemaamu Scion FR-S / Toyota 86 GT86 General Forum 27 02-27-2013 12:21 PM
FRS as a Daily Driver? Pake1 Scion FR-S / Toyota 86 GT86 General Forum 104 08-15-2012 11:48 PM
Will the BRZ be your daily driver WRXGuy1 BRZ First-Gen (2012+) — General Topics 47 05-23-2012 12:15 PM
The daily driver KiingDavid CANADA 25 02-06-2012 01:14 PM
