Old 01-27-2014, 05:01 PM   #29
Indestruct
Drives: 2013 SWP Limited BRZ, MT
Phantom ESC... have some money left over too. Maybe w/the TQ300 and E85 and Headers, exhaust you might hit 250 whp
Indestruct is offline   Reply With Quote
Old 01-27-2014, 05:06 PM   #30
1086
1086's Avatar
Drives: UM86 - 6MT
Too awesome my man - Thank you providing thorough detail!
1086 is offline   Reply With Quote
Old 01-27-2014, 05:09 PM   #31
CSG Mike
CSG Mike's Avatar
Originally Posted by tendogy View Post
I'll chime in with a starter budget:
Supercharger
You can get Jackson and Vortech Tune-it-Yourself kits at this price no problem, and Innovate Intercooled for a couple hundred more. You could probably get one cheaper if you ask around and/or kept an eye out for deals or sales and whatnot.
Tune
This $700 amount is probably going to be a little high if you plan to dyno-tune at a nearby shop, and will probably be a little low if you plan to do a remote tune since you'll have to pick up the ECUTEK kit.
Installation
You'll be installing this yourself on this budget, bub. The Innovate has a good reputation for ease-of-installation, and the Jackson instructions look stupid simple. The Vortech instructions scare me, but each to his his/her own.
Dual Catch Can
For catching blow-by oil and what-not. Consensus is that this is a must if you want a prayer of your supercharged car making it to 100k miles.
Boost Gauge
Gotta keep an eye on that boost. Over-boosting with a supercharger isn't a big fear, but you still need to keep an eye out for boost leaks.
UEGO Wideband
Gotta keep an eye on those AFR readings, you don't want to pull a nelsmar (I kid I kid).
Gauge Pod
Gotta put the pods somewhere
Scangauge II
This fella will let you see your intake temps, coolant temps, and oil temp. The oil temp is especially important because you didn't want to spend the cash for an oil cooler. You need to know when the oil is getting hot so you can ease off.
Obviously there is a lot of wiggle room here, it's just a starter budget for the noobs who come a'callin.
I'd recommend adding an engine oil cooler
Deadpool_25 (04-23-2015)
Old 01-27-2014, 05:09 PM   #32
Gen
Drives: Scion FR-S
I have found you spend almost the same amount in supporting mods on a turbo as the turbo itself, particularly if you don't do the labor yourself. Also, some of the components in these kits aren't going to last longer than 10k miles--melt, break, etc.
Gen is offline   Reply With Quote
Old 01-27-2014, 05:58 PM   #33
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Clutch, gauges, oil cooler, ecutek cable and license are all expenses most people overlook and can cost half the price of the FI kit.
Old 01-27-2014, 06:09 PM   #34
CSG Mike
CSG Mike's Avatar
Clutch - Only necessary for big power. If you're making this much power... then you should be prepared to be spending. How much do 300whp cars cost from the factory?
Gauges - Use a OBD2 scanner instead. You don't need a boost gauge; you'll know if you're losing boost.
Ecutek/cable/license - Included in the CARB kits for $5k or so.
Oil cooler - typically the only other major cost, if you get a setup that includes a tune.
Old 01-27-2014, 06:12 PM   #35
1086
1086's Avatar
Drives: UM86 - 6MT
@CSG Mike - I don't want to go totally off topic, so this is directly just towards you. I currently have the OFT, if I were to go with a supercharger, and I got custom tuning through Shiv, would that still work? It should right? Or is EcuTek mandatory despite the fact I am focusing on a DD spec.
Old 01-27-2014, 06:12 PM   #36
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
No. Just no.
If you guys want to play with a nitrous shot equivalent, that's fine by me. But this is a pretty interesting thread and I would love it to stay focused on getting to higher power at a "near to or better than OEM" level of drivability and longevity.
Ralph Spoilsport is offline   Reply With Quote
The Following User Says Thank You to Ralph Spoilsport For This Useful Post:
1086 (01-27-2014)
Old 01-27-2014, 06:15 PM   #37
Ralph Spoilsport
This is absolutely on topic!
I have my suspicions about the answer....
Old 01-27-2014, 06:17 PM   #38
midnight23
dying bird under the hood
You can get the greddy kit installed and tuned for about 6k but you won't have any addons that will be needed if you want to push the kit past it's advertised stats.
Build Thread
Instagram
Old 01-27-2014, 06:17 PM   #39
Frs300
Frs300's Avatar
Drives: Pile of junk
Originally Posted by FR-S Matt View Post
I'm in the same boat as you, but my goal is 350 whp. I think 250 whp is a pretty obtainable goal without needing injectors. I figure a stage 1 kit + installation by a professional, then any accessories for the kit, might put you at about $5000 when its said and done. Don't forget to add in tuning and your license cost depending on the platform you choose.
My buddy did a P/L Stage 2 turbo kit, with new injectors, new clutch, tuning, gauges, etc and his final bill was $12k. High power is definitely not cheap.
one of the shops on here hit almost 400whp on stock fuel system i believe
Frs300 is offline   Reply With Quote
The Following User Says Thank You to Frs300 For This Useful Post:
1086 (01-27-2014)
Old 01-27-2014, 06:33 PM   #40
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
This thread would be more beneficial if the posts were from those who have done these FI builds with an itemized list like @tendogy has done.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
The Following User Says Thank You to ecko04 For This Useful Post:
1086 (01-27-2014)
Old 01-27-2014, 06:45 PM   #41
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
I'm going FI for under 5k otd...
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following User Says Thank You to OmarGC For This Useful Post:
Guff (11-18-2014)
Old 01-27-2014, 06:58 PM   #42
1086
1086's Avatar
Drives: UM86 - 6MT
Too vague! lol... Any more specific details? Invoice? :P
FT86 Buyer's Guide! FRS vs. BRZ Differences Detailed! [Video + High Res. Stills] Rosso_Corsa Scion FR-S / Toyota 86 GT86 General Forum 23 11-03-2013 04:10 PM
First time buyer - help! chotemaamu Scion FR-S / Toyota 86 GT86 General Forum 27 02-27-2013 12:21 PM
FRS as a Daily Driver? Pake1 Scion FR-S / Toyota 86 GT86 General Forum 104 08-15-2012 11:48 PM
Will the BRZ be your daily driver WRXGuy1 BRZ First-Gen (2012+) — General Topics 47 05-23-2012 12:15 PM
The daily driver KiingDavid CANADA 25 02-06-2012 01:14 PM
