Sam Strano
Old 01-27-2014, 01:06 PM   #561
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Yea... it's pretty obvious the street classes were cut off at the knees for the inaugural year, which is understandable since going too soft would upset the apple cart for the established classes. I expect we'll still be hurting for the next few years until there's enough data to adjust them more appropriately. In the meantime, placement amongst the other street classes and delta % to the top indexers will just have to be the gauge.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 01-27-2014, 01:37 PM   #562
Rexpelagi
Drives: 2013 Subaru BRZ
+1, may as well throw in the towel against any decent non-street drivers this year.
-John L.
2011 BMW M3 - 57 FS
2007 Ford SGT - 57 FS
2013 Subaru BRZ - Sold
Rexpelagi is offline   Reply With Quote
Old 01-27-2014, 01:51 PM   #563
mrazny
Drives: BMW 135i, soon to BRZ
Originally Posted by AustinTX View Post
I've got some pretty stiff competition down here, so I'm looking at this early lack of pace as an opportunity to excel. I'll claw back some of that time myself and hope to make up the rest with the bar and possibly race valved fronts. I'm trying to convince one of the locals with a 370Z to buy some top street tires and do a back to back comparison, but tires for a 370 are ridiculously expensive.
What kind of courses do you guys typically do? A STU tractor and a Twin drive courses very differently. Part of your time differential is a course difference too. That also could mean these are Twin courses in truth and the PAX is that much further off, but the variables are F'n immense.
mrazny is offline   Reply With Quote
Old 01-27-2014, 02:05 PM   #564
AustinTX
Pawn in game of life
AustinTX's Avatar
Drives: 19 STX BRZzz
Plenty of national level drivers down here (19 of the top 20 were at nats last year, and four are national champions), so course designs are as homogenous to national courses as we can fit into the sites. The event this weekend was more of a road course with only a couple slalom/transition sections and a tight hairpin. Speed range was 24-56 in my car. The car was constantly fighting for rear grip on throttle.
Autocross nut
AustinTX is offline   Reply With Quote
Old 01-27-2014, 02:18 PM   #565
AustinTX
AustinTX's Avatar
Video of my best run below. Please feel free to critique - I want to get this sorted as quickly as possible
[ame]http://youtu.be/nhFMyJgP5is[/ame]
Autocross nut
The Following User Says Thank You to AustinTX For This Useful Post:
u/Josh (01-28-2014)
Old 01-27-2014, 04:15 PM   #566
FastWhite
Drives: Subaru BRZ Limited M/T
I put a 20 mm front bar on and found the difference quite noticeable. MUCH better turn in. That and the rivals. Keep in mind I am not the preverbal expert. Or speller.
I could over power the car. Reference not an expert.
FastWhite is offline   Reply With Quote
The Following User Says Thank You to FastWhite For This Useful Post:
AustinTX (01-27-2014)
Old 01-27-2014, 04:39 PM   #567
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Here is why I am saying this:
CS: .821 1.58% slower than R-comp (Round to 1.6%)
CSR: .834
STX: .827 0.846% slower than R-comp (Round to 0.8%)
Based on this: they are telling us that the performance difference from street tires to R-comps is twice as great as the performance difference between the rest of the stock/street modifications to the allowances in STX.
So basically wider wheels/tires, brakes, diff, exhaust/intake, a tune, fancy coilovers, etc... all of that, only gets you about half the performance gain as a set of R-comps would. I don't think they are giving all those modifications enough credit.
Old 01-27-2014, 04:54 PM   #568
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
STX is fairly accurate. Its CS that's off. Because Rick Ruth admitted to kneecapping Street, afraid to upset if a street driver did too well (though he never did that any other time a new class was introduced)
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 01-27-2014, 05:10 PM   #569
piknockout
Drives: 2014 BRZ
Hale's clearly not slow, although sounds like the car still needs to be tweaked with some FSB action. But as stated, the Street PAX is fubared, but no need to keep crying about it. Probably the best way to guestimate where you "should" be and how the car is continuing to progress and how you're adapting to it vs. the Non-CS competion would be to do it the way it was done last year: CSR PAX times a .975 multiplier. Doing that puts the CS PAX at .813 and would have put you in 5th overall, about 0.5 PAX seconds out of first. Feel better now?
Another way I can tell the PAX is messed up: you got beat by Pomrenke and Irish.
piknockout is offline   Reply With Quote
Old 01-27-2014, 05:16 PM   #570
AustinTX
AustinTX's Avatar
That's just wrong - and right. :P I'll use the PAX number to my advantage and just get faster. There is nothing like losing to make you try harder...
Autocross nut
Old 01-27-2014, 06:51 PM   #571
Getagrip
Getagrip's Avatar
Drives: SWP BRZ
Can you take a pic of the sidewall on the 245 Rival? Should be interesting to see how well the tire squeezes into the wheel. The 235 Z2 looks pretty good considering how much wider it is than the wheel.
For comparison here is old StarSpecs 245/40-17 mounted on stock wheels.
In mounted tire is next to it. I mounted them up myself. Wasn't that bad.
SWP BRZ
Getagrip is offline   Reply With Quote
Old 01-27-2014, 07:03 PM   #572
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Still debating between the 235 and 215 ZIIs....
DylanFRS is offline   Reply With Quote
Old 01-28-2014, 09:16 AM   #573
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Yup, I agree, the point of my argument is the delta between CS and STX should be greater than the delta between STX and CSR.
Old 01-28-2014, 09:49 AM   #574
Kido1986
Dodging cones
Kido1986's Avatar
Yep, you're definitely correct.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 06:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 01:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 09:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 02:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 11:03 AM
