Old 01-27-2014, 12:59 AM   #85
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
+60whp NA cams please
*ignorant request* I admit lol
fooddude is offline   Reply With Quote
Old 01-27-2014, 02:34 AM   #86
shaunsweeney
shaunsweeney's Avatar
Drives: 2014 FR-S MT Asphalt Grey
This isn't an LSx
shaunsweeney is offline   Reply With Quote
Old 01-27-2014, 09:24 AM   #87
CajunFRS
Drives: Challenger R/T, CRX SI,
Originally Posted by shaunsweeney View Post
This isn't an LSx
Don't kill his dreams!
CajunFRS is offline   Reply With Quote
Old 01-27-2014, 12:21 PM   #88
CajunFRS
If it isn't at least 25whp with supporting mods. I don't see how its worth cracking open the heads.
Time will tell.
Old 01-27-2014, 12:45 PM   #89
350matt
Drives: toyota mr2/ Toyota GT86
Trouble is it all looks a bit expensive for even 20 bhp doesn't it?
mainly because you've got to drop the motor out
so there's $1000 bill right there plus $600 - 1400 for cams & springs plus someones time to fit them its goiing to be getting on for $3K by the time your done which is nearly the price of a FI kit
350matt is offline   Reply With Quote
Old 01-27-2014, 01:03 PM   #90
fooddude
I don't think anyone would shell out $2-3k for 20whp. 40'ish whp would def be worth it though (that's already similar to a mild FI setup's power); but I think even 30-40 whp from cams would be very hard to attain. I remember the NA honda days, it would be difficult to get anything over 20whp from a 1.6-2.0 dohc vtec.
Old 01-27-2014, 01:06 PM   #91
Dephective
Drives: '13 Whiteout FRS
^ yes there are lots of things that cost much less in relation to cost/horsepower gained, but 20WHP on an n/a motor for 3k? that's nothing to scoff at if you have already maxed out your bolt on breather mods.
Also, the power gained on a FI motor will certainly be much higher than gains on an N/A motor. Being able to move more gases in a single cycle is paramount to making more power, now if you pressurize that gas and give it more "time" to breathe, then you will be making much more power indeed.
Previous:
'01 Accord-daily
'93 Rx7-fire breathing track monster 545hp 397tq 2300lb.
'06 Mazdaspeed6 one helluva love-hate relationship
Dephective is offline   Reply With Quote
Old 01-27-2014, 01:15 PM   #92
Dephective
I don't think anyone would shell out $2-3k for 20whp. 40'ish whp would def be worth it though; but I think even 30-40 whp from cams would be very hard to attain. I remember the NA honda days, it would be difficult to get anything over 20whp from a 1.6-2.0 dohc vtec.
Wrong, you get a lot out of cams from Honda because of their VTEC cam profiles having the ability to alter exhaust as well as intake. Unfortunately we don't have this ability, so we won't see AS MUCH of a gain. I've got my flame suit on already, but K series motors make incredible power from cams and breather mods on N/A. Even B series motors are pretty surprising.
Daily drivability is subjective. One person that says a lobe-y idle is a no-no, one person embraces it. Some people like a lot of low-end to putt around town, some people don't mind keeping in it a lower gear than what previously would have been called for while cruising.
I'm not saying it will for sure be beneficial to run n/a for a non-race application, but I am saying that power is achievable. It's just a question of how aggressive does your profile have to be to get there. If those numbers are in fact the stock specs, I suspect a 272 cam (like so many EJ's run) or even 280's for FI folks would work wonders. 272's are perfectly streetable and I wouldn't be surprised if that's what they are using for their "Stage 1" in this application.
Previous:
'01 Accord-daily
Old 01-27-2014, 01:23 PM   #93
wparsons
wparsons's Avatar
Woah woah woah...
VTEC does nothing for independence of intake and exhaust, even a SOHC non VTEC engine can have the intake and exhaust lobes altered independently when the cam is being ground.
Any DOHC engine can adjust the cam phasing between intake and exhaust, if it doesn't have variable valve timing you do this manually with adjustable cam sprockets.
Our engines do have independent variable valve timing on the intake and exhaust cams, so the ECU can (and does) adjust them independently.
What VTEC does do that we can't do is give two different cam profiles for different lift and duration. It lets you run a very different grind for higher RPM use than the low RPM grind, that's why they can run much more aggressive cams and still be very streetable. I don't doubt that an FA20 could make more power than a K20, but the K20 will be way more civilized at low revs.
flickr
Old 01-27-2014, 01:33 PM   #94
OrbitalEllipses
Drives: Attitude
Those figures are wonky.
They look like full duration (big numbers) and duration @ .050".
I don't think they are .26x" max lift.
@Calum Brian Crower =/= Crower. BC, as @Dimman has pointed out, grossly overrates their cams. Take a look at a BC 272 EJ cam...it's much closer to a Kelford 264 than it is to 272.
Old 01-27-2014, 01:36 PM   #95
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Finally, a set of aftermarket cams! Anxious to see further developement with this.
hmong337 is offline   Reply With Quote
Old 01-27-2014, 02:27 PM   #96
Dimman
Kuruma Otaku
Dimman's Avatar
The method of total duration vs duration @ .050" is pretty standard. I wouldn't say BC is any different than the industry norm. Always look at the .050" lift duration when comparing between companies figures. Only if they don't provide duration @ .050" would I say they are deliberately trying to mask the figures. BC does so I don't have a problem with their numbers.
I think these guys just mislabeled duration @ .050" as 'lift'.
But as @arghx7 mentioned the full profile is the only thing that shows the whole cam story.
Because titanium.
Old 01-27-2014, 03:37 PM   #97
arghx7
Drives: car
Well here's where it gets tricky. .050" is about 1.25mm . That's a lot of lift to be rating your duration at. You're ignoring possibly many degrees of valve opening time. 0.05" may be standard for measuring duration for aftermarket performance cams but it's not necessarily that way in other applications of camshaft manufacturing.
Now, you might say, why should I care about duration at 0.5mm lift? or at 1mm lift? The answer is simple: overlap volume. Let's look at this picture again:
The area under the curve where the two profiles meet at a given cam phasing (cam centerlines) could be referred to as the overlap volume. This is important... if we're overlapping at say 0.5mm of lift, and the valve is actually open (not just some lash or whatever), that affects flow in the cylinder. It affects for example residual gas (knock sensitivity) affects fresh air blowthrough (scavenging), and it can affect dethrottling for pumping loss.
That's why it's important to know the full grind of the cam. You need it so you can understand the overlap volume. There's more to cams than arguing over who has the biggest number (some nominal valve lift or duration).
Old 01-27-2014, 04:32 PM   #98
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
what material are these gonna be made from? i know they were saying the di cam has to be stronger then average. aggressive na cams would be nice
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Introducing Bad Luck Brian: 86 Owner Anthony Off-Topic Lounge [WARNING: NO POLITICS] 23 01-31-2014 11:42 PM
Brian (PradiG)'s Ratchet FRS Photo Journal PradiG Member's Car Journals 13 09-11-2013 01:01 AM
Anyone choose zeta stage 1 over stage 2? BlackyRose Engine, Exhaust, Transmission 2 07-06-2013 01:32 PM
>> EcuTek << STAGE 1 / STAGE 2 / E85 - Tunes Available FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 133 05-21-2013 01:39 AM
