Old 06-11-2012, 03:54 AM   #15
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
My favorite car to heel-toe in was my Ford Festiva when I was in college. I bought it so my nice car wouldn't get banged up on campus. That festiva got a 5 speed swap from the newer aspire... I drove it every day like the Italian Job. I miss that old piece of crap.
Coheed is offline   Reply With Quote
Old 01-09-2013, 01:47 PM   #16
roflcopter
Gold Member
roflcopter's Avatar
Drives: 2013 Whiteout FR-S
So, sorry in advance to bring this thread back from the dead, but I figured it was better than creating a new one for the same question. I am not new to driving manual, but I have always just double clutched to downshift (not exactly a need to race going to work in the morning). My question really is if I sign up for NASA and do a local HPDE event, will my instructor have time/be able to show me how to heel-toe? I know I will need to practice a lot but I want to be shown in person the correct way to do something before I develop a bad habit teaching myself the wrong way. Thanks!
roflcopter is offline   Reply With Quote
Old 01-09-2013, 02:17 PM   #17
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
He could show you how he does it (people have different methods), but you probably won't be able to apply it, as it takes plenty of practice to do it correctly in the heat of battle, and the consequences of doing it improperly on track could be, uh.... Not good... Lol
GTB/ZR-1 is offline   Reply With Quote
Old 01-09-2013, 03:58 PM   #18
xwd
On a track I'm pretty good with actually swinging my heel over since I have time to prepare and it's repetitive doing multiple laps.
I need more practice with autocross, I usually end up screwing something up like braking too much.
Old 01-09-2013, 06:35 PM   #19
Amadeus
Amadeus's Avatar
Drives: White MT FR-S
This wider gas pedal helps a lot:
http://www.srpracing.com/cat-fr-s.cfm
There was a thread on the forum but it's not active anymore.
Amadeus is offline   Reply With Quote
Old 01-09-2013, 07:27 PM   #20
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
You are not double clutching like you should newbie lol. I keed I keed.
I actually find the FR-S to be one of the easiest cars to heel & toe with. Now the Evo X was a pain in the ass to heel & toe with because of the tiny accelerator and how spaced apart the pedals were and the huge throttle delay, trust me man you are in heaven compared to many other cars.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
Old 01-11-2013, 03:41 PM   #21
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Originally Posted by lordtakuban View Post
I also use the outside portion of my foot rather than an actual heel and a toe. Practice with it is all you need. Just keep working on it.
This came up on another forum.. copying & pasting my response.
While there is no one-way to heel toe, I really have to discourage people from braking with just the side/edge of their foot. Your foot can easily slip and it would be in the worst possible situation -- corner entry. IMO, braking takes priority so you should have as much footing on the pedal as possible. Just IMHO.
Here's video of my heel toe (0:34) at a local autocross.
[ame="http://www.youtube.com/watch?v=ndMP_Nvbikc&feature=g-upl"]NNJR PCA 8/19/12 - 60.936 - YouTube[/ame]
iLuveKetchup is offline   Reply With Quote
Old 01-11-2013, 04:06 PM   #22
ST185RC
Drives: White Out FR-S
Agreed 100%, favoring brake over smooth rev-matches. I don't "heel-toe" per se, I plant the ball of my foot on the brake so I get a good solid brake pedal contact and use it as my pivot. However else you can blip the throttle do it so that it's comfortable. For me, it's the right side of my foot. You can almost say I fat-foot the brake and gas. I barely twist my leg to blip the throttle for rev matching.
All I have to say about "heel-toe'ing" in the FR-S requires a bit more throttle as there's a very slight delay or deadspot in the accelerator travel so I have to mash it a tiny bit harder. When I first got the FR-S I noticed this right away when I had to blip the throttle a second time to have the RPMs climb enough.
Not something I was used to coming from all my previous cars driven by throttle cable. Now that I've driven the car a while, it's more natural and I can heel-toe rev-match perfectly 99% of the time. When I switch back to my Rav4 and I heel-toe, I slightly over-rev due to habit of driving the FR-S and direct throttle response vs DBW.
Love my first gen Rav4 btw.
ST185RC is offline   Reply With Quote
Old 01-11-2013, 04:31 PM   #23
gmookher
Adjust brake pedal height, problem solved. Was it a 17mm wrench? Takes two minutes, makes life so much better for the toe in heel toe...
Old 01-11-2013, 04:50 PM   #24
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
I like the fact that my auto does it for me
That said.. I never could do a proper heel toe, close but like the op, I never quite got the revs high enough
Gixxersixxerman is offline   Reply With Quote
Old 01-11-2013, 05:27 PM   #25
GTB/ZR-1
GTB/ZR-1's Avatar
Good footwork, ketchup--I only LFB 2 pedal cars.
My heel/toe varies per car, it seems. If the pedals are well-spaced/even height @ max braking, I do the method of 'straddling' the gas & brake. If the pedals aren't ideal, I use ketchups method. I drive all different types of cars @ some events, so it pays to be flexible lol
Old 01-26-2014, 11:00 PM   #26
Howardwei
I have been getting better on heel toe and rev match. but usually i would be missing 2-300 rpm over and under. should i stop doing it? because occasionally i smelled something like a hot burning metal but then it goes away very first its happened twice before
Howardwei is offline   Reply With Quote
Where to buy "heel/toe" shaped gas pedal? dookie11 Scion FR-S / Toyota 86 GT86 General Forum 56 01-22-2019 11:24 AM
brake override DOES NOT diminish heel & toe 4agze Scion FR-S / Toyota 86 GT86 General Forum 31 09-17-2012 04:43 AM
Heel toe #87 Other Vehicles & General Automotive Discussions 21 08-25-2012 05:39 AM
Heel and Toe ichitaka05 Other Vehicles & General Automotive Discussions 13 04-02-2010 02:28 AM
How much do you like heel-toeing or left foot braking? USMCMike Other Vehicles & General Automotive Discussions 20 01-15-2010 04:20 PM
