Old 01-06-2014, 11:22 AM   #1
sid3way5
Drives: 13 wrb brz greddy evo3 catback.....
what oil are you boosted guys using
when mrp installed my kit they switched my oil to rotella 15-40
fa20 kit
303/250
sid3way5 is offline   Reply With Quote
Old 01-06-2014, 11:25 AM   #2
Synack
Boosted
Synack's Avatar
Drives: Sideways
Currently using Valvoline VR-1 10W-30.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 01-06-2014, 02:08 PM   #3
bluesubie
Drives: 2004 Subaru Forester 2.5XT
Originally Posted by sid3way5 View Post
when mrp installed my kit they switched my oil to rotella 10-40
Do you mean Rotella 5W-40, 10W-30, or 15W-40?
http://www.shell.com/rotella/products.html
A 40 grade oil is too thick, unless you have built internals, IMO. Rotella 10W-30 is probably a good choice for break-in though. Some boosted guys are using 0W-20. They're just using oils with robust base stock and additive packages instead of jumping up two viscosity grades and experiencing unnecessary drag.
http://www.ft86club.com/forums/showthread.php?p=1180901
-Dennis
bluesubie is offline   Reply With Quote
The Following User Says Thank You to bluesubie For This Useful Post:
sid3way5 (02-09-2014)
Old 01-06-2014, 05:28 PM   #4
carlossanchez89
2Supras1FR-S
Drives: 13 Scion FR-S, 87 Supra
Im using Mobil 1 Synthetic 5W-30 but once I reach the 3000 miles I'll be changing to Motul or Purol.
carlossanchez89 is offline   Reply With Quote
Old 01-06-2014, 05:54 PM   #5
CSG Mike
CSG Mike's Avatar
Motul 300V 5W30.
I wouldn't recommend a 40 weight at all.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
Chad86 (03-17-2018), charged86 (02-19-2014), Sportsguy83 (01-21-2014)
Old 01-07-2014, 05:39 AM   #6
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
@CSG Mike
Where peak summer temps reach maybe 90-95 degrees max for say a week would 300V in 0-20w be sufficient for FI setups?? Avg ambients daytime summer being 75-85f and 35-55f at night.
Old 01-07-2014, 09:00 AM   #7
swift996
swift996's Avatar
I've been running Motul 300V 0W-20, it got pretty dark after 4-5k miles. Should I run something a little heavier?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 01-07-2014, 11:20 AM   #8
bluesubie
That's just the detergents/dispersents (along with the ester base stocks) doing their job cleaning and holding contaminants in suspension. If you have sufficient oil pressure, then you shouldn't need to go any thicker based on the oil getting dark at 4-5k miles.
-Dennis
Old 01-15-2014, 10:40 PM   #9
Dezoris
Dezoris's Avatar
Redline 0w20, perfect UOA after hard track time.
The Following User Says Thank You to Dezoris For This Useful Post:
504 (02-10-2014)
Old 01-21-2014, 08:01 AM   #10
lexusb3
Drives: FRS
Mobile 10-40 25,000 boosted and strong
lexusb3 is offline   Reply With Quote
Old 01-21-2014, 09:57 AM   #11
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Motul 8100 0w-30
The Following User Says Thank You to Sportsguy83 For This Useful Post:
sklimo (01-21-2014)
Old 01-26-2014, 03:58 PM   #12
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Motul 8100 0w-30
Which 8100 exactly ?
Old 01-26-2014, 04:14 PM   #13
Sportsguy83
Drives: Limited BRZ
X lite
Old 01-26-2014, 04:34 PM   #14
Dipstik-sportech
Dipstik-sportech's Avatar
Amsoil 10w30
The Frozen North
Boosted's BRZ Boosted Member's Car Journals 41 11-05-2018 09:32 PM
How reliable is a boosted FRS/BRZ? wootwoot Forced Induction 123 07-22-2016 03:18 PM
BC Coilover settings you guys guys ride on g0lden Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-06-2014 06:56 PM
Boosted BRZ mike the snake Member's Car Journals 3 12-28-2013 11:11 AM
AU Boosted club nix AUSTRALIA 18 01-19-2013 12:50 AM
