Old 01-14-2014, 10:51 PM   #169
TONYpepperon1
TONYpepperon1's Avatar
Drives: 2013 CBS BRZ
Originally Posted by ucsmfu View Post
haven't had time to finish painting since it's been raining almost everyday.
I didn't use plasti dip. I used duplicolor
Is duplicolor more of a permanent solution as compared to plastidip?
TONYpepperon1 is offline   Reply With Quote
Old 01-14-2014, 11:12 PM   #170
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Yes, it's paint.
Old 01-25-2014, 01:35 AM   #171
uEih
Drives: CBS Subaru BRZ Limited
It looks good, I need to paint my lip.. What was the process? Sand, alcohol, primer, paint? Or did you skip primer?
uEih is offline   Reply With Quote
Old 01-25-2014, 02:38 AM   #172
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
just alcohol and paint, haha
ucsmfu is offline   Reply With Quote
The Following User Says Thank You to ucsmfu For This Useful Post:
uEih (01-25-2014)
Old 01-25-2014, 06:49 AM   #173
uEih
Cool glad you said that because that's all I wanted to do haha. Actually I might sand it a bit since there are some weird imperfections on a corner of the lip. You got the matte black? Is there a light sheen to it? I want to get it close to the OEM STi one as possible and apparently that one is painted semi-gloss but most semi-gloss I see are too glossy.
Old 01-25-2014, 11:37 AM   #174
cslntuee
Drives: Subaru BRZ Limited
HI,
I am still debating getting the PU one or the ABS one.
The price are the same.
Ex. ABS
http://www.ebay.com/itm/12-14-Subaru...bff03e&vxp=mtr
PU
http://www.ebay.com/itm/2013-SUBARU-...b7aef4&vxp=mtr
Any comment or suggestions related to how you make your decision?
Thanks a lot.
cslntuee is offline   Reply With Quote
Old 01-25-2014, 11:53 AM   #175
Andrew025
Andrew025's Avatar
Originally Posted by cslntuee View Post
HI,
Ex. ABS
PU
Thanks a lot.
ABS will be less likely to recover from damage like the PU. Like if you pull up to far in a parking spot, the PU will just flex. The ABS would be more prone to cracking depending on how hard you come up on the curb.
Both will more than likely be destroyed with any significant impact to the bumper (my PU lip broke from hitting some dirt in a ditch).
FWIW I have the ABS version on my car now...
The Following User Says Thank You to Andrew025 For This Useful Post:
cslntuee (01-25-2014)
Old 01-25-2014, 11:57 AM   #176
sirsol66
Drives: 2013 FRS- Hot Lava
Anybody with additional photos of the skirts on any color other than WRB? I'm very curious to see it on white, red, or (if the stars align) Hot Lava.
sirsol66 is offline   Reply With Quote
Old 01-25-2014, 12:00 PM   #177
cslntuee
Why you are not choosing the PU one this time?
Thanks again.
Old 01-25-2014, 02:14 PM   #178
Andrew025
Andrew025's Avatar
Thanks again.
No real reason actually
Old 01-25-2014, 04:56 PM   #179
tbertran
tbertran's Avatar
Drives: Subaru BRZ (6027xx) Premium Manual
Have you considered painting the skirts/lip white/SWP?
Would probably be a hassle to try and keep the lip clean but I'm only considering the skirts right now (matching my SWP)...
Would sand/prime/paint even work with this type of material?
FT86SpeedFactory catted UEL Header / GReddy EVO3 Catback / Cosworth Drop-in air filter / Shifteck short throw shifter / Kartboy pulley / Rear bumper diffuser / Perrin shorty antenna / Raceseng Slammer knob / Carsmo armrest / Clear side markers / 10" CustomSubEnclosure|Rockford R500X1D|Rockford P3D4-10 / Perrin Inlet Hose / GrimmSpeed front strut bar / Valentine V1 with BlendMount / All LED Inside
tbertran is offline   Reply With Quote
Old 01-25-2014, 05:06 PM   #180
uEih
Thanks again.
I think ABS was available first and PU only recently popped up. I ordered a PU one a week ago and going to paint it today and install tomorrow.
The Following User Says Thank You to uEih For This Useful Post:
Old 01-25-2014, 07:52 PM   #181
cslntuee
HI,
I saw some bad review related to the PU one.
http://www.ft86club.com/forums/showp...8&postcount=28
http://www.ft86club.com/forums/showp...6&postcount=33
Could you comment on the quality that you get (PU one)?
Thanks.
Old 01-25-2014, 08:48 PM   #182
cslntuee
HI,
Any people plan or know which suitable rubber to add on for additional
protection, if I bought the ABS one?
I saw the STI genuine from lip has this design as below.
Thanks.
STi Style Carbon Fiber Front Lip/Side Skirts/Rear [BRZ] JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 31 12-03-2013 10:57 PM
CS Style Polyurethane Side Skirts Jive Turkey Exterior Parts (Aero, Lighting, Etc.) 14 11-04-2013 09:49 PM
WTB CHARGESPEED STYLE SIDE SKIRTS. bahanii Want-To-Buy Requests 1 10-18-2013 02:06 PM
FS: CS Style Side Skirts and Rear Spats FRS2000 Exterior Parts (Aero, Lighting, Etc.) 4 09-23-2013 12:15 PM
2013 SUBARU BRZ J STYLE PU SIDE SKIRTS JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 7 05-10-2013 11:29 AM
