go_a_way1, MisterSheep
Old 01-25-2014, 01:15 PM   #5195
roddy
roddy's Avatar
Drives: '13 Ultramarine
Installed the frameless rearview mirror...so easy. It took 5 minutes including the time to pull the car in and out of the garage. Nice visual upgrade from the stocker, and not a bad price from my local dealer (~$70).
Part # SU003-03183.
Old 01-25-2014, 04:33 PM   #5196
ATESIX
Drives: '13 Scion FR-S Whiteout
ATESIX is offline   Reply With Quote
Old 01-25-2014, 04:46 PM   #5197
Rio
Rio's Avatar
Drives: 2014 Scion FR-S ハチ
Traded my Primacy HPs for a new set of Michelin*Pilot Super Sports 225/45RZ17XL 94Y B to go with my H&R Super Sport springs :-)
Sent from my SGH-T999 using Tapatalk
Rio is offline   Reply With Quote
Old 01-25-2014, 05:05 PM   #5198
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
Rear aprons installed...Name:  ImageUploadedByTapatalk1390683919.104722.jpg
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 01-25-2014, 07:25 PM   #5199
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
Nameless 2.5" Axleback with 5" Mufflers.
[ame="https://www.youtube.com/watch?v=X5Jbq5qJc2E"]Nameless Axleback - YouTube[/ame]
Black Rally Armor Flaps.
OFT!
leicaboss is offline   Reply With Quote
Old 01-25-2014, 07:46 PM   #5200
fazm
Drives: 2014 FR-S
Originally Posted by fazm View Post
Depends if you want to go race car, or street car.
My own mods to date:
BRZ Trunk liner
Dyna mat installed in trunk, backseat and roof
Perrin crank pulley (not really worth it, but it looks cool)
Sound tube delete
OEM Armrest
Rexspeed wide angle mirrors
Trunk lid swap (to get rid of scion wing)
Scion all weather mats
front plate relocator
rear shift rod bushing
Items in my garage I need to install:
aluminum steering rack bushings
transmission mount support
items I plan to purchase and install soonish:
ft86 speed factory catted header
nameless front/overpipe (catted)
Aluminum driveshaft
dynamat the rest of the cabin
Future plans:
Lightweight exhaust system
diffuser
wheels and tires (likely RPF1s and Pilot A/S/3)
lightweight battery
tom's taillights
injen headlights
lightweight clutch/flywheel
oil cooler
oil catch can
daydream mods:
Electric super charger
final drive
rear diff cooler
My car is a daily driver that may see the track 2-3 times a year.
Got under the car to install the rear shift rod bushing today. Had to drop the driveshaft! Shifting is a lot smoother now. I think a lot of what people call notchiness could be cured with this mod. Took about 45 minutes to lift the car, get my bearings and get to it. I installed the perrin part and am very pleased. Definitely had to use some elbow grease to get it seated, glad the instructions gave me a heads up that it's a tight fit.
fazm is offline   Reply With Quote
Old 01-25-2014, 07:55 PM   #5201
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Installed JPM Coachworks alcantara shift and e-brake boots. Also got new subs for my car today: 2 PHD 12" SQ subs.
kmbkk is offline   Reply With Quote
Old 01-25-2014, 10:53 PM   #5202
FatFree
FatFree's Avatar
Drives: 2013 Asphalt FR-S
Washed it and installed a Beatsonic shark fin antenna and semi-smoked side markers. Looks sooo much better.
FatFree is offline   Reply With Quote
Old 01-25-2014, 10:59 PM   #5203
Juvenile
Juvenile's Avatar
Drives: 86 GTS
Fitted replacement dash panel
The Following 4 Users Say Thank You to Juvenile For This Useful Post:
Evil Jesus (01-26-2014), jflogerzi (01-25-2014), N_A (01-25-2014), Rio (01-26-2014)
Old 01-25-2014, 11:38 PM   #5204
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Why were you replacing yours again? Was it because it was coming loose?
Old 01-25-2014, 11:44 PM   #5205
Juvenile
Juvenile's Avatar
Drives: 86 GTS
Umm no, because someone had written all over it, to preserve it.
Old 01-25-2014, 11:55 PM   #5206
Astroboy
Astroboy's Avatar
Drives: None
Damn, if couldn't be washed off?
Sent from my LG-D800 using Tapatalk
Astroboy is offline   Reply With Quote
Old 01-26-2014, 12:18 AM   #5207
Rio
Rio's Avatar
Tetsuya Tada signed your car? WOW!
The Following User Says Thank You to Rio For This Useful Post:
Juvenile (01-26-2014)
Old 01-26-2014, 12:35 AM   #5208
Evil Jesus
Evil Jesus's Avatar
Drives: '13 FR-S Raven 6MT
OFT!
Careful, wouldn't want to rev past 2,500RPM or anything.
Evil Jesus is offline   Reply With Quote
