Old 02-28-2013, 10:51 PM   #1
Hardrock4445
Hardrock4445's Avatar
DIY: Oxygen sensor spacer
Ok guys, I had to make this up tonight so I decided to make a DIY for anyone that needs to make this. Will be needed to keep P0420 codes from vehicles with removed cats, and to prevent it from vehicles with a bad cat. ie: your winter beater with 175k that has a bad cat. You will need, 18mm spark plug non foulers X2 - available at any local parts store. 1/2" drill bit, a way to drill safely. Ok here we go
New spark plug non-foulers:
A way to drill:
[IMG]http://i797.photobucket.com/albums/yy258/hardrock4445/0***B854-DF28-420D-B809-D84447C70776-1845-00000231181E1D18_zps8ffa2ae0.jpg[/IMG]
Drill only one non-fouler:
Install drilled non-fouler onto oxygen sensor:
Install second non drilled non-fouler: (note, in this picture, I have the gasket on, do not use the gasket, you will get better results that way)
Install into catless header, you could also use this for vehicles throwing P0420 codes:
Hope this comes in handy for some people. You can buy spacers made specific to your application, but this is cheap, available at local auto stores and can be put together in less than 15 minutes if you have the tools.
I take no responsibility for your actions on your cars, or your safety if trying this DIY, please work safe and smart.
Mods: Perrin CAI, JDL EL header, DC sports Catless front pipe, top speed auto pro-1 cat-back, H&R sport line springs, Headlight blackout, "Demon eyes"
Hardrock4445 is offline   Reply With Quote
The Following 8 Users Say Thank You to Hardrock4445 For This Useful Post:
cobrabyte (07-29-2013), HRTROB (03-05-2013), JDLAutoDesign (12-06-2013), johnb831 (01-24-2014), Nikuku (05-30-2013), ort895 (03-22-2016), ProjectD (03-01-2013), Tujin (06-12-2013)
Old 03-02-2013, 02:52 PM   #2
RWD-boxer
RWD-boxer's Avatar
Drives: Black
Works great did it back in the day on my turbo tc
Thenittis.com
RWD-boxer is offline   Reply With Quote
Old 07-07-2013, 09:39 AM   #3
jdm-az-fuk
Drives: 2013 Fr-S
Can you confirm that this mod doesn't bring up and o2 codes ?
jdm-az-fuk is offline   Reply With Quote
Old 07-08-2013, 07:13 PM   #4
Hardrock4445
It will keep codes away once sensor is spaced properly. I had to play with some washers to get the correct depth. Too far out will set a secondary o2 lean code and too far in will still set p0420 code. As it sits right now I get p0420 every maybe 500-1000 miles. So I just clear it. Waiting on tune pending FI purchase.
Old 07-29-2013, 12:59 PM   #5
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
FYI, I performed this mod about 600 miles ago and got a code (P2096-Post Catalyst Fuel Trim System Too Lean). I'll be checking for leaks near the header shortly.
Perhaps the spacer is working too well? I wonder if drilling the small hole on the anti-fouler slightly would fix this.
Nitro22 is offline   Reply With Quote
The Following User Says Thank You to Nitro22 For This Useful Post:
Hardrock4445 (07-29-2013)
Old 07-29-2013, 04:40 PM   #6
Hardrock4445
I've been trying spacers to get it dialed in, but I fear with these newer OBD systems that a tune will be the only true way to go.
Old 12-26-2013, 12:19 AM   #7
iDerek
iDerek's Avatar
Drives: Subaru BRZ
Send a message via MSN to iDerek
spacers are only a temporary fix for our vehicles. only a tune can make it stay off
An idea should be like a skirt, long enough to cover the details and short enough to keep everyone's attention.
iDerek is offline   Reply With Quote
Old 01-24-2014, 04:47 AM   #8
OmarYasin
OmarYasin's Avatar
So how many sparkplug spacers did u use? 2? Im about to do the same thing weird didnt think anyone on the forum used this old trick.i have 2 SP spacers both drilled and both have washers.any tips?
Sent from my LG-MS840 using Tapatalk 2
OmarYasin is offline   Reply With Quote
Old 01-24-2014, 02:00 PM   #9
foney_email
foney_email's Avatar
Some guys in the Houston club swear by the vibrant spacer with the medium insert. They claim 5000 miles with no cel.
Anyone know what thread pitch to order?
foney_email is offline   Reply With Quote
Old 01-24-2014, 06:35 PM   #10
Hardrock4445
I wound up using just the one drilled spacer and the two washers used in the kit.
Old 01-24-2014, 09:11 PM   #11
OmarYasin
OmarYasin's Avatar
And what header system r u on?this is what u used for the best results?
Old 01-24-2014, 11:20 PM   #12
Hardrock4445
JDL EL header. Every 1-1.5k miles I may get c.e.l. So infrequent I just clear it and carry on. If you space it too far you will get post-cat lean code. Really gotta play with the spacers and washers to get why works best for your setup
Old 01-25-2014, 12:35 PM   #13
OmarYasin
OmarYasin's Avatar
I see wont be on the spacer to long anyways this is just temporary till.my tax return comes in and i get a tune
Old 07-11-2015, 12:43 PM   #14
poolboy54
Drives: Scion FRS. Silver with black badges
Part number
Do you have the part number for that oxygen sensor spacer?
poolboy54 is offline   Reply With Quote
Wheel Spacer Size?? tonytduc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 52 11-03-2018 04:36 AM
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 03:20 PM
Spacer how to right in your driveway. F3dzo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 10-22-2013 08:31 PM
fluid dynamics, venturi effect, and oxygen sensors. EZWood Engine, Exhaust, Transmission 8 10-25-2012 07:21 AM
wheel spacer to 5x114 derka-derka AUSTRALIA 12 07-03-2012 12:27 AM
