Old 01-11-2014, 06:28 PM   #85
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Installed my Tundra stalk today for my fog lights. Couldn't find a proper write up on how to do that so it took a little longer than expected. Main problem was that the clock spring for the airbag came completely unraveled when I removed the steering wheel. That was a booger to put back together. All wiring is run from the factor to get the electrical signals from A to B. Makes this a fairly easy mod once you get everything disassembled.
Tundra stalk
Nothing on
Headlights only
Headlights and fogs
Turn on high beams and fog lights turn off
Both blinkers and hazards work as they should
Dustin is offline   Reply With Quote
Old 01-14-2014, 10:05 AM   #86
Dustin
Twin Screw You
Dustin's Avatar
My brother found some 6061 aluminum to make my carrier bushings.
Old 01-17-2014, 09:11 PM   #87
Dustin
Twin Screw You
Dustin's Avatar
I was gonna wait until tax time to order a header but........................
Nameless header....................ordered!!
Old 01-17-2014, 09:20 PM   #88
Dustin
Twin Screw You
Dustin's Avatar
Oh and just found out I got a big stack of shims coming my way. Should be here on tuesday. Hopefully I can finish my diff and ring and pinion swap.
Old 01-17-2014, 09:25 PM   #89
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Great DIY stuff going in here, well done!
Old 01-21-2014, 11:29 PM   #90
Dustin
Twin Screw You
Dustin's Avatar
Thank you. More DIY got done today.
Had to bang out the old carrier bushings. Used a hammer and an aluminum rod. Took some time but they eventually came out.
Then my brother, @Rue, machined the bottom portion of the bushings for me.
Finished product leaning up against the material for the top portion of the bushings.
They fit PERFECTLY. I wanted them to fit snugly in place without much force but also hold in place without falling out.
With the sleeves.
And the bolts.
Also got the backlash set on the differential.
We were able to get the last measurement needed for the upper portion of the bushing. Hopefully that and the rear end will be finished this weekend.
Old 01-23-2014, 05:50 PM   #91
Dustin
Twin Screw You
Dustin's Avatar
One bushing down, one to go.
And might be nit picking but I wasn't happy with how skinny the factory throttle pedal is. Makes heel/toe a little difficult. So a new pedal was in order. And by new I mean used. Wanted to see if it would work first. Will probably order a new one now that I see it will.
Old 01-23-2014, 07:18 PM   #92
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
DIY at it's best.
Touge Factory is offline   Reply With Quote
Old 01-24-2014, 06:22 PM   #93
Dustin
Twin Screw You
Dustin's Avatar
Last bushing is done. Rear end will be going in tomorrow.
Old 01-24-2014, 10:28 PM   #94
Rue
Rue's Avatar
Drives: Shoe Leather Limousine
Alright everyone... meet Boston Mike.
Making the upper bushings
All pressed together...
"Working on cars is not what I do... it's who I am." Steve Metcalf
Rue is offline   Reply With Quote
Old 01-25-2014, 05:24 PM   #95
Dustin
Twin Screw You
Dustin's Avatar
Carrier installed with new Tomei 2 way clutch type differential, 4.55 ring and pinion, and aluminum carrier bushings.
Getting sideways on the backroads near you!!
Anyone wanting to attempt this themselves, I have made a DIY. It is as detailed as I could make it.
Old 01-26-2014, 12:36 PM   #96
Dustin
Twin Screw You
Dustin's Avatar
Installed fog lights last night. I can't believe how easy they went in. Everything with the exception of 1 wire in the little subharness is already there from the factory. I'll post some pics after work today.
Added the 1 wire missing from the sub harness.
Then spliced into the factory ground wire.
Soldered and heat shirnked.
Terrible f*cking picture I know, but whatever.
Old 01-26-2014, 12:53 PM   #97
humanshield
Drives: bucket
quality shit right here.
humanshield is offline   Reply With Quote
Old 01-26-2014, 03:24 PM   #98
Dustin
Twin Screw You
Dustin's Avatar
Thanks, I try to do nice sh*t to my car. Only thing I regret so far is buying the springs. I did it mainly for looks for a car meet I was going to. Should of spent the money else where. Next thing on the list will be a supercharger. After that I'll be purchasing a nice set of coilovers.
My brother had a Cusco spin turn knob just laying around. Put it on just because.
BRZ Limited Backup Camera Step by Step (WARNING long post, many pictures) runny_yolk Electronics | Audio | NAV | Infotainment 120 01-29-2021 06:18 PM
step 1 :buy frs in phx, step 2: drive to pikes peak haymaker FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 15 08-21-2012 10:44 AM
[StreetFX] License Plate LED light upgrade, and DIY step by step guide (GT and GTS) WTF Australia Classifieds 0 07-11-2012 11:38 AM
[StreetFX] BRIGHT Boot/Trunk LED light upgrade & DIY step by step guide (GT and GTS) WTF Australia Classifieds 0 07-11-2012 11:27 AM
