#3123 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
Good info. So driving at sustained wide-open throttle with the ESC still fully installed, but boost disarmed for periods of time should be safe as well.
#3124 | |
You tuned the WOT load cells so that they have the proper AFR and timing. When you aren't WOT it just uses the standard NA load AFR and timing. This is the reason that the system actually works without a tune as well. |
#3125 |
Drives: 2013 FR-S, 2012 MCS
I've been creeping this thread since I wanna say Octoberish. Are we any closer to a release date?
#3126 | |
Drives: GBS BRZ
What I was trying to say was I would be switching the sc from one vehicle (brz with tune) to another (impreza without tune) in the winter. It sounds like the physical sensor could simply be removed and the boost limit would also be removed, if that ends up being the method to limit the boost. Sent from my iPhone using Tapatalk |
#3127 | |
Can I get you to clarify what you meant by WOT load cells? Does it actually move to the next engine load column at their respective rpm? I haven't seen any logs yet, are you aware of any? |
#3128 | |
These he estimated delivery on Jan 26th. Once he gets the compressor wheels he has to assemble and test everything to ensure they meet his specifications. |
| The Following User Says Thank You to fenton For This Useful Post: | zc06_kisstherain (01-26-2014) |
#3129 | |
Now if you were to go WOT without the charger on the load on the engine is less.... lets say 1 to 2.... during load cells 1 - 2 the engine runs as if it were just NA. Try not to think of this as only one number however... instead thing of it as like 1.01 - 1.99. If the engine see's more load it puts in more fuel(calculated by the MAF). In this case we inject more fuel when there is more flow and when the charger is not engaged we inject the standard amount of fuel. I am not a tuner by any means but i have a basic understanding of how the engine calculates required fuel and ignition timing required. Rememember that on the top end we arent boost that much so the tune is very close to what it would be NA anyways.... Somebody like @shiv@vishnu should be able to describe this better than I
#3130 | |
Sent from my HTC One using Tapatalk |
#3131 | |
Drives: DGM BRZ 6MT
I'm super excited for the Spring! |
#3132 |
#3133 |
Well put me on the preorder list! No but seriously can't wait for this!
#3135 |
#3136 | |
are you Jeff Vader?
Drives: Black BRZ Limited
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
