Old 01-17-2014, 04:34 PM   #15
NickFRS
Drives: 2013 Asphalt FRS
Originally Posted by ramiram1984 View Post
With his uel header, you see it made more torque down low and did better job in dip area...
This is still impressive. Why did I spend LOTS of $$?
Lol
Vid will be up later tonight. My tunner actually reduced the timing under 3.5k RPMs so there wold be less knock. Look at the top end though. With the last set up the car was loosing power at 7k. Now it holds HP strong till redline.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 01-17-2014, 05:02 PM   #16
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by FR-S Matt View Post
Stock header should be of thicker sidewalling than an aftermarket one.
Also the stock stuff has a slightly smaller ID than the aftermarket parts... larger dia = more volume.
Old 01-17-2014, 06:12 PM   #17
NickFRS
True dat. But honestly it's not that much smaller. Power feels great for smaller parts.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
Old 01-17-2014, 06:32 PM   #18
utekineir
blowhard
Drives: frs, project forester
Some people prefer smaller parts
utekineir is offline   Reply With Quote
Old 01-23-2014, 05:22 AM   #19
NickFRS
https://www.facebook.com/photo.php?v=10201443074615894
sound clip
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
Old 01-23-2014, 06:21 AM   #20
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
This probably is the case here since you can't easily turn up the boost to compensate for reduced back pressure or increased scavenging from a free flowing exhaust.
industrial is offline   Reply With Quote
Old 01-24-2014, 05:15 AM   #21
NickFRS
boost is dependent on pulley size. Charger ftw.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
Old 01-24-2014, 08:18 AM   #22
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Not really that simple. If you unbolted your supercharger from the engine and just ran it into open air it would generate 0 boost. Likewise, changes to engine VE like reducing back pressure or improving scavenging will decrease boost pressure since a non-waste gated supercharge just pushes a fixed cfm.
Old 01-24-2014, 08:27 AM   #23
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
1 pull in July, 1 pull in January. In Portland, right? What is that, 30-35 degrees F difference in temp and a huge change in atmospheric moisture (humidity)?
I'd honestly like to see what they look like with weather correction.
Good to see, but let's not start making conclusions just yet...
Sellout is offline   Reply With Quote
Old 01-24-2014, 05:53 PM   #24
NickFRS
Are you for real? You do understand the innovate supercharger is a intake manifold replacement twinscrew charger right? If you removed the charger the car wouldn't start. The charger is dependent on pulley size for boost. You can't just make it magically generate more or less boost w.o altering the pulley size.
If you put a more free flowing exhaust or intake all you will be doing is changing the AFR's. In which case you can pull more power. Adding an exhaust to a charger doesn't make it generate more boost. Twinscrews work way differently then turbo's.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
Old 01-24-2014, 08:53 PM   #25
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I don't think we are on the same anything... Page/wavelength/physics.
Reread what I'm saying. If you open up the exhaust on a non-wastegated/clutched supercharger system like the innovate, you will LOSE psi but gain VE. That maybe why it seems like exhaust mods aren't worthwhile on these systems. You may have to add a smaller pulley to make up for the lost boost.
I will not respond again here...I know where science isn't wanted.
Old 01-24-2014, 09:31 PM   #26
NickFRS
You fail to see what i'm saying.
It is as simple as installing a smaller pulley to create more boost? Maybe I should have been more clear. Science is fact. The smaller the pulley the faster the charger spins = more air being compressed = more boost.
I'm not disagreeing with you. Lol.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
Old 01-24-2014, 10:11 PM   #27
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
how did you gut the stock header?
garfull is offline   Reply With Quote
Old 01-25-2014, 03:48 AM   #28
clintavo
True, but given the same pulley size, breathing mods will marginally reduce boost pressure because more gas escapes the combustion chamber.
How does the drone compare to the previous setup?
Thanks for posting your results.
clintavo is offline   Reply With Quote
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
Gains from aftermarket catted front pipe vs stock front pipe? Vmax911 Engine, Exhaust, Transmission 4 01-20-2014 01:42 PM
FS: Tsudo header back exhaust w/catted front pipe Opposed Engine, Exhaust, Bolt-Ons 4 11-19-2013 01:01 PM
Revworks UEL header + Nameless OP/DP combo BRZPDX Engine, Exhaust, Transmission 5 10-11-2013 08:00 PM
P&L Catted headers and Nameless catted Front pipe. Also is this cricket noise? Xdragonxb0i Engine, Exhaust, Transmission 23 04-24-2013 12:29 PM
