Old 01-23-2014, 05:25 PM   #15
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by jamesm View Post
it's just really weird that you see the exact same thing at two very different boost levels... but like i said i've seen others with the same issue, mostly superchargers.
It would make sense if it was something in the way the boost level is being controlled and it is doing the same thing regardless of what the max PSI is set to. What is this car running for boost control?
Old 01-23-2014, 05:29 PM   #16
jamesm
it looks like it's pulling timing. these cars are pretty knock-sensitive above 7k, and i have to pull a bit to keep knock at bay on my turbo setup above 7k. i assumed it was noise at first, but sure enough pulling 1.3 deg or so up made it go away, and netted me power to redline.
Old 01-24-2014, 01:40 AM   #17
JuniorAWD
Drives: GTR 9.0@170_XT 10.8@130_GC 8.3@165
Its none of the things mentioned. These were not the finished run files, what you are seeing in both graphs was tq/throttle table related as well as some speed/traction based boost control I was messing with. Its not on the finished file. I'm sure if the car left my hands like that the owner would not be happy lol.. That would be VERY noticeable on the street.
As for UEL/EL... I don't like the UEL design on the turbo cars. All the kits can and will make power up around 75-7800rpm, obviously the ones with smaller turbos will peak a little earlier. IMO the head/cams in OEM form seem to be working very very good for making top end power and flat TQ curves.
Hope this helps clear stuff up
I will also agree about the knock on these cars past 6500 if you leave certain tables untouched, or not setup for the extra airflow ( cam tables )
JuniorAWD is offline   Reply With Quote
FA20CLUB Tuned 400+whp Automatic Andy@FA20Club Forced Induction 27 10-28-2013 09:43 PM
FA20CLUB Tuned Flex Fuel Kit N/A FR-S 204whp 156tq Andy@FA20Club Engine, Exhaust, Transmission 31 10-16-2013 09:42 AM
FA20Club tuned Vortech kit 93 octane draggin_az Forced Induction 58 05-29-2013 03:45 PM
Legacy low-mounted turbo oil pump aspera Engine, Exhaust, Transmission 0 06-16-2010 03:41 PM
