Old 01-23-2014, 03:27 PM   #1
Estey
Drives: Scion FR-S, Ultramarine
Negative front camber?
So my car is lowered on eibach springs and I was reading on the forums that it is a good idea to run negative camber. Why and how much camber should I have? Also will I need an alignment if I install camber bolts?
I noticed that my front tires are wearing a lot more on the edges from hard turning. So I was thinking the main reason was to get more of the tire in contact with the pavement when turning.
Estey is offline   Reply With Quote
Old 01-23-2014, 04:09 PM   #2
wparsons
wparsons's Avatar
The amount of camber you need depends on spring rate, how grippy your tires are and how hard you drive it.
If you're wearing the shoulder of the tires out, then you probably need some more negative camber. You're right on the reasoning too, more negative camber will put the tires flatter when cornering.
You can try running higher tire pressures up front, but if you go too high you'll start wearing the middle of the tire more than the rest.
flickr
The Following 3 Users Say Thank You to wparsons For This Useful Post:
Eric@ptuning (01-23-2014), Estey (01-23-2014), ftc~brz (01-23-2014)
Old 01-23-2014, 04:52 PM   #3
Estey
hmm, Ill try running a higher tire pressure in the front. I drive it fairly hard on and off and I have pretty grippy summer tires. So I guess the negative camber might require a bit of tweaking at first?
Old 01-23-2014, 05:07 PM   #4
car_roll
Drives: Nuisance BRZ
negative camber and summer tires go hand in hand.
#teamnuisance
I do like, YouTube or something, IDK.
Shameless Plug
car_roll is offline   Reply With Quote
Old 01-23-2014, 05:32 PM   #5
Estey
Awesome!
So now the question is, does changing two bolts affect my alignment?
Old 01-23-2014, 05:37 PM   #6
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
yes, most likely
If you are changing height yes. Bolts, hopefully they equally change the camber. Than maybe no if the camber is what you are trying to get.
DrDuquette is offline   Reply With Quote
Old 01-23-2014, 05:57 PM   #7
Estey
What do you mean by height? If youre referring to the springs, I installed them and aligned the car a while ago.
Im basically just trying to get camber in the front.
Old 01-23-2014, 06:04 PM   #8
Gunman
Drives: 2019 Mazda Miata RF
If you're installing camber bolts, you'll need some sort of alignment to get the camber the same from side to side, and to know how much camber you have.
Old 01-23-2014, 06:18 PM   #9
Eric@ptuning
Awesome!
Yes most definitely. Most camber bolts are designed with eccentric lobs which is how they change camber.
You turn one direction outer most part of lob pushes inward towards struct you get Negative camber. You turn in the opposite direction outer most part of lob pushes outward away from struct you get Positive camber
Cause the naked eye cant tell the difference down to the very exact degree its recommended to take the car in to get an alignment after installing any components that effect suspension
Eric@ptuning is offline   Reply With Quote
The Following 2 Users Say Thank You to Eric@ptuning For This Useful Post:
Estey (01-23-2014), wparsons (01-24-2014)
Old 01-23-2014, 06:30 PM   #10
Estey
alright thanks guys, this was helpful
Old 01-23-2014, 06:33 PM   #11
Eric@ptuning
Glad we can help
Question About Negative Camber: More Negative Camber == More Grip at Corner? Figo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 03-10-2019 02:08 PM
What are your opinions on negative camber, from a looks perspective? 86-tundra Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 12-26-2013 01:29 PM
Advice on negative rear camber Thongpocket Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 09-27-2013 10:38 PM
Excessive negative camber? MTeator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-22-2012 10:30 AM
