Old 01-23-2014, 01:27 PM   #2843
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by xxscaxx View Post
Did you have any issues with clamps? I received all sprung clamps, but the bigger ones did not fit over the water pump connections and nipple connections on the front/back of the supercharger (or on the heat exchanger)
We had to substitute worm clamps for some of those, not sure if we had to for all though.
Old 01-23-2014, 02:00 PM   #2844
xxscaxx
Drives: 2013 SWP BRZ
I was given 6 larger clamps (two for on the water pump, two for those lines coming off the pump to the heat exchanger, then two for the inlet/outlet of the supercharger) and none fit. The rest were fine, but then again the only ones I used at that point was the one under the coolant bottle, and the 3/8 line).
xxscaxx is offline   Reply With Quote
Old 01-23-2014, 03:10 PM   #2845
xjohnx
Grip>Slip
xjohnx's Avatar
Radium dual catch can kits start shipping next week.
The Following 3 Users Say Thank You to xjohnx For This Useful Post:
Calum (01-23-2014), normancw (01-23-2014), xxscaxx (01-23-2014)
Old 01-23-2014, 03:50 PM   #2846
xxscaxx
Little more info, I reached out to Radium.
We are waiting for the final parts to come back from the powder coater, then we can do our product photos and installed photos. This should be happening next week.
The catch cans mount behind the strut towers. One can behind each strut tower. No relocation of any components is necessary. It is highly unlikely the location will interfere with any aftermarket mods, we paid close attention to that when designing them.
Pricing for the dual catch can kit will be $425USD which includes everything needed for install. We will also offer each catch can kit separately, since they are on separate brackets. That way a person can purchase just the PCV catch can kit or just the crank vent catch can kit.
Kind of like our offering for the S2000:
http://www.radiumauto.com/S2000-Catc...-LHD-P360.aspx
We have several other parts as well for the FR-S BRZ platform that will be released over the next several weeks.
Old 01-23-2014, 04:58 PM   #2847
lex tech
Drives: 2005 kia spectra 5, 2004ford tauras
Why are the catch cans $425 and the duel catch can kit for the s2000 only $254.00?
lex tech is offline   Reply With Quote
Old 01-23-2014, 05:03 PM   #2848
xjohnx
Grip>Slip
xjohnx's Avatar
the dual kit for the s2000 is 450. You have to select the dual can option in the dropdown. the $254 price is for a single S2000 can.
Old 01-23-2014, 05:13 PM   #2849
swift996
swift996's Avatar
Does anyone know the specs of the hose that runs out of the rear of the crank and into the supercharger?
EDIT - I found them:
http://www.ft86club.com/forums/showthread.php?p=588959
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 01-23-2014, 06:05 PM   #2850
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
It may have not been clear in my earlier post but the catch can I found is really similar to the radium catch can at less than half the cost. The little basket threads into the top. Air coming through the can passes through the basket, into the can and out the fitting at the top. I added part of a copper scrubber that you can get at a grocery store to help collect the suspended oil. Radium uses similar stuff on the S2000 can. All the oil falls into the cup and can be checked with the dip stick. I am not saying radium doesn't make an awesome product but I would rather spend $200 bucks on a track day and some fuel. You could even mount two side by side similar to how the post quoted did. I would buy two sealing washers and an o ring for the dipstick.
[IMG][/IMG]
If you want an easy install and are willing to pay for it by all means radium is the way to go.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
The Following User Says Thank You to calispec For This Useful Post:
CK_Bladesmith (01-23-2014)
Old 01-23-2014, 06:14 PM   #2851
calispec
calispec's Avatar
http://www.mcmaster.com/#93786a225/=qdqdwl
Sealing washer.. should be able to pick them up at a hardware store
www.GT86Mounts.com
Old 01-23-2014, 07:03 PM   #2852
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Also the 3/8 line provided does NOT fit well on the plastic fitting/coolant reservoir. I managed to get mine on there but it took heating it up, and lube to get it on enough. I should have just replaced this line, so thats another thing to check.
When we toss the robispec r/oc on @xjohnxs car, I'll be replacing that house with the correct size.
also, if you're installing the upgrade kit, taking off the elbow like @xxscaxx (i think it was you, anyway) suggested.
Holy crap, yes.
Yep, the only spring clamps supplied that we could use were the smaller ones on the way too small overflow tank hose. The others were one size too small.
Sent from my Nexus 4 using Tapatalk 2
Parting out HERE
civicdrivr is offline   Reply With Quote
The Following User Says Thank You to civicdrivr For This Useful Post:
xjohnx (01-23-2014)
Old 01-23-2014, 08:27 PM   #2853
swift996
swift996's Avatar
How many bolts are on the bottom of the elbow? I see 3 on the top.
Old 01-23-2014, 08:31 PM   #2854
xxscaxx
same as top, 3. follow the top bolts straight down, they are in the same spot.
6 total.
Are all of you guys still running the stock oil weight? Been meaning to ask this.
Old 01-23-2014, 09:29 PM   #2855
swift996
swift996's Avatar
6 total.
Getting to those lower bolts on the elbow is easier than the supercharger bolts? I'm not seeing how that makes it easier to remove.
Old 01-23-2014, 09:30 PM   #2856
xjohnx
Grip>Slip
xjohnx's Avatar
Like he said, 3. make sure you've got some long and standard sized wobble head hex keys (5mm, in particular). it will make everything much easier.
swift996 (01-23-2014)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
