#29 |
Drives: Pavement MT GR86
I think the stock afr is a bit rich...so a few tenths leaner should be fine. * input from tuners appreciated
GR86 MT premium
#30 |
Drives: 2014 SWP BRZ LIMITED
Forgive my ignorance, but would it be possible that the afr's might correct a little bit with some more pulls? Don't these fuel computers learn over time to correct to a certain extent for lack of fuel delivery, or to make better afr numbers. What would happen if you did the old disconnect the battery, hold the brake and make the car relearn? You know start it back up with the new setup. Let it idle for at least 30 minutes and then do some pulls.
Granted you would be looking at a possible change in ambient temps, and enviornment after too long, and therefore not being being able to replicate runs over and over. Not really being well versed in how these cars handle changes in setups this may not be how things work any more. Just curious if it might help? I'm just going back to my old 2.2L accord days. So again please forgive my ignorance. |
#31 | |
Matt Beenen Engineering |
#32 |
So being that I did not unhook and drain the power from the ecu after I put my drop in K&N in. Would it even make a difference at this point, lets say a thousand miles later to actually do this? I gather the car has made the appropriate changes already, and learned the new filters characteristics?
#33 | |
We're definitely not trying to scare anyone away from their drop in filters, that is absolutely not what we're implying. I wouldn't be worried at all. Chase Engineering |
#34 |
Thanks guys. I appreciate the fact that you are doing the research.
#35 |
How much does a stock snorkel cost? The mod seems similar to the HKS intake duct, but I'm sure a stock snorkel is a little bit cheaper.
#36 |
Drives: 2013 Scion FR-S 10 Series MT
I'm not sure what the problem is? It looks like the average gains from the drop-in was roughly 5 whp and 2 wtq. $40 for 5 whp equals $8 per whp. That's an insane bang for the buck, albeit it's only a small gain.
EDIT: Also, I didn't mean to Thanks your post, I misclicked when I tried to Quote it. Oops.
Mods: K&N Air Filter - Open Flash Tablet (Stage 1 v1.55) - more to come!
#37 |
Drives: 2010 MS3
Just received the K&N drop in and installed it.
I'll use this til you guys release the intake system. ![]() Thanks for all the information, Grimmspeed. |
#38 |
Drives: 2013 SWP BRZ
So would you venture to say the drop-in filter may be detrimental in the long term with the AFR readings, or is the change in AFR still acceptable for a NA application?
2013 SWP BRZ Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781 |
#39 | |
Chase Engineering |
#40 | |
Drives: 2013 BRZ Limited SWP
http://www.ft86club.com/forums/showp...&postcount=504 |
#41 |
Drives: 2013 Scion FRS 10 Series
This mod may help slightly up top but will definitely kill performance off the line. Especially in AT where wot is needed to get moving quick. Lift the break and go wot, you will be left dead in the water until you slowly climb to 2k rpms when the car will finally get moving. In NA configurations it needs to scavenge a bit for air to get combustion going. Velocity vs volume. If you have already done this mod and have experienced this problem just cover the modded snorkel inlet until you get the same surface area as before. I found that my Frs actually responds better with slightly less surface area than the original stock inlet. I am running E85 on the oft stage 2 tune.
#42 | |
Drives: 2013 Asphalt Fr-S
Brings me to my questions -- If you left the snorkle in tact, but heated the tip and stuffed in the pop bottle to expand it, will it have a benefit? What if you angle cut the tip, but left the two resonators in place? What about one resonator? has anyone had successful results running a different shape?
| Has anyone deleted the resonator in the stock airbox? or made a larger snorkel? | NickFRS | Engine, Exhaust, Transmission | 305 | 03-31-2021 02:34 AM |
| Zeta Performance - Silicone Intake Pipings & Drop-in Replacement Air Filters | ZetaPerformance | Engine, Exhaust, Transmission | 95 | 11-05-2014 07:42 PM |
| Zeta Performance - Silicone Intake Pipings & Drop-in Replacement Air Filters | ZetaPerformance | Engine, Exhaust, Bolt-Ons | 41 | 05-13-2013 02:00 PM |
| WTB Stock OEM Airbox/snorkel | brichard0625 | Engine, Exhaust, Bolt-Ons | 1 | 10-20-2012 09:21 AM |
