#2815 | |
Road Warrior
Drives: Toyota 86 Satin Pearl White
Hot or cold won't matter. Top up to max line, run car and keep an eye on the coolant, if you find you drop back down to low mark, look for signs of a leak. |
#2816 | |
Drives: 2013 SWP BRZ
I'm pretty certain I don't have a leak. Coolant smells horrible and even a pindrop burning off somewhere is so easily identifiable once you pop the hood. If I was losing that much coolant, i'd definitely smell it. I will check it out though, thanks @Ryan86. |
#2817 |
Drives: Raven FR-S
What if it's leaking down into the manifold from the laminova core?
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
#2818 |
#2819 | |
Drives: 2013 Scion FR-S in Ultramarine
Okay, back to the "Innovate" tunes. What HP/Torque are they providing? Naturally, I'm curious since I haven't seen any numbers for this SC other than "Tuner" numbers. Plus, if I need to get the SC/engine tuned then I want to make sure that I find a great tuner who knows what he/she is doing and not some kind of "Frankenstein" Mad Scientist that will blow up my car.
Currently driving a Sprintex Supercharged FR-S in Ultramarine with an Invidia N1 Catback with Catless Front Pipe, Invidia Over Pipe, Injen Catless 4:1 EL Headers, Perrin Aluminum Drive Pulley & Driveshaft Shop Aluminum Driveshaft. Also, looking to upgrade wheels someday to Enkei PF01's (17x8's).
#2820 | |
Road Warrior
How you pick this up is you will notice coolant dropping each time you drive and give hard pulls. Should see coolant which came out the bottle cap. Also the car will feel very jerky down low. |
#2821 | |
Grip>Slip
#2822 | |
I know mine were definitely in place. Also, I don't ever get on the car, because i'm in the process of getting some issues tuned out, so I am driving very easy. Plus, no jerkiness down low of any kind. Or coolant coming out the bottle cap. |
#2823 | |
Road Warrior
#2824 | |
Road Warrior
Dyno showing the gains from stock to Suprcharged on 91Oct |
#2825 |
Drives: Raven FR-S
Innovate Supercharger Owners Topic
Ryan yours was leaking into the manifold correct? Disregard this post. Page didn't refresh for me
#2826 | |
Road Warrior
This is worse case scenario Top up and run car again if you notice coolant dropped again to low mark you may have a leak or you did not top enough coolant causing air lock. |
#2827 |
I don't remember fittings going into the actual core, unless I'm misunderstanding lol. Either way I'll just top off and go from there.
#2828 |
Road Warrior
If you open up the core these are the o rings sealing the coolant running through the core. Look at the condition on my o rings, can understand why they did not seal, causing it to leak into the manifold.
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
