#57 |
Drives: 2023 WRB BRZ (MT)
#58 |
That Guy
Drives: 2013 asphalt FRS MT
*puts on flame suit*
I'm guessing it'll be at least late summer/early fall before we see any reliable numbers. As it is, these numbers aren't at all reliable. For the numbers posted in this thread; the heads were swapped (we don't know if there was a casting issue with originals), the heads were ported, the tuner had a ton more experience with this platform, and the cams were added. For all we know these cams may loose power over stock and the other changes could be enough to offset. I'm elated to see cams are coming to the market, and DA seems to be doing what they can to give us all information possible. I just think we need to keep things in perspective. At this point all we know is that the stock DI cam profile was maintained, and the cams were made by Brian Crower. |
#59 |
I'm in no rush, I don't plan on cracking open my engine until the warranty is up (which at my current pace is another ~1.5 years).
#60 | |
Drives: 2013 Scion FRS "Raven"
To clear up the above bold print, We pulled our motor out of the car to check clearances and determine what if any internal parts we want to replace in the near future. Tolerances are tight and he did not like the stock valve springs. With the heads off we took the time to port and polish them along with upgrading the springs. The heads were never replaced. During the reassemble process we installed the cams. The cams have a different profile as it pertains to the valves. The DI pump is run off the intake cam on the left bank (See the photo of the cams, right cam is the intake on the left bank). The cam has a separate triangular lobe for running the DI pump (top most poration of the cam). They did not change the DI lobes. When testing new part for a motor it only makes sense to us a tuner that is experienced with this platform. If we used a different tuner (less knowledgeable) one would say that we could have found more power or done something different. The fact is we spoke with Bill and he was given the car to create the maps. All of the above maps where built by Bill, as he was our tuner from day one. So the number you see are all his work. The only thing not apples to apples is the head porting. |
#61 |
Boosted Member
Oh, definitely interested. Good to see options starting to appear finally..
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG 2011 Honda CBR1000RR 2010 Subaru Impreza WRX PRM SSM |
#62 | |
That Guy
I wasn't trying to say you went with a different tuner, but that Bill had gained experience with this platform. He is an awesome tuner, and made some huge improvements in my car. Full respect to you and him, it's just that the posted results aren't conclusive. Someone can't drop these in, get a tune, and expect the same results. Are you able to give info on the stock valve springs and the aftermarket valve springs you used. |
#63 |
Drives: '13 BRZ
Can't wait to hear this cam!
#64 |
That Guy
I just had a chance to look at these numbers, my god those are tiny! Unless Crower is measuring these at a very high starting lift point, I can't believe We're getting 200 hp from these cams.
#65 |
Drives: Whiteout FRS
Higher compression and cams...mmmm
life's greatest stories usually start with the words, "fuck it!".
#66 | |
The stock springs really suck if you plan to run high RPMs. They have an install pressure of 33LBS and at .05 lift they are 55LBS. The rocker arm design is similar to the TC. Which worried us as the TC is known to throw rockers and wiping out the head. So we contacted Supertech and obtained a set of their springs. Their upgraded springs have and install of 75LBS and 105 @.50 |
#67 |
#68 | ||
Drives: car
There's more to a cam than a duration--the duration is only the length of the event. The timing is critical. Remember, with dual AVCS we can retard intake closing timing for higher volumetric efficiency, and adjust the exhaust valve timing for either earlier blowdown (advance cam) or later evacuation of gases (retard cam). In most cases for an n/a engine the number one determining factor of high speed performance for a cam is closing timing of the intake valve. It sets the trapped mass (effective volume), the pressure drop across the intake valve (filling capability and dynamic effect), filling time, and effective compression. Quote:
Also, for everyone else: brake torque (and thus power) = indicated torque - pumping - friction . Friction is basically a catch-all for anything that isn't related to combustion or gas exchange. Friction screws you over in everything. It kills fuel economy, it kills torque and power. Last edited by arghx7; 01-21-2014 at 09:34 PM. |
#69 |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
I wonder if decent NA cams would make more or less horsepower than headers. All these dyno sheets of aftermarket headers these days are honestly very impressive (compared to the mid 90s); almost to a point of being unbelievable. Just curious if cams + tuning would be up to par or make even more than 20hp, or maybe even 30hp or more.
If the cams can only make an extra 10'ish hp on NA, I'm not sure if it would be even worth it, especially with all the install costs/hassles and all the required replacements parts during install (maybe new intake/tb gaskets, fuel lines, bushings, etc, if maybe needing to remove the lines and such to get at the top of the heads.) |
#70 |
Depends on where you want the power. Adding 40hp is doable if you're willing to shift the powerband up higher and rev to 9k rpm (with supporting mods, valve springs, etc), but for just dropping in cams I don't know that you're going to see huge gains.
| Introducing Bad Luck Brian: 86 Owner | Anthony | Off-Topic Lounge [WARNING: NO POLITICS] | 23 | 01-31-2014 11:42 PM |
| Brian (PradiG)'s Ratchet FRS Photo Journal | PradiG | Member's Car Journals | 13 | 09-11-2013 01:01 AM |
| Anyone choose zeta stage 1 over stage 2? | BlackyRose | Engine, Exhaust, Transmission | 2 | 07-06-2013 01:32 PM |
| >> EcuTek << STAGE 1 / STAGE 2 / E85 - Tunes Available | FT-86 SpeedFactory | Engine, Exhaust, Bolt-Ons | 133 | 05-21-2013 01:39 AM |
