Old 01-21-2014, 10:08 PM   #15
Ozzman
Drives: old
Originally Posted by Moe23 View Post
I will try to get a video of it knocking, and i got an oil change two days before it starting knocking, and oil level is fine
You sure they used the right oil?
Ozzman is offline   Reply With Quote
Old 01-21-2014, 10:54 PM   #16
Moe23
Drives: 2014 Scion FRS MT
they should of, but how would i check what type of oil they used?
Moe23 is offline   Reply With Quote
Old 01-22-2014, 01:01 AM   #17
You might check your work order or call whoever changed the oil.
No oil (except maybe 3in1 oil) would cause an engine to knock under light use.....
Moe23 (01-22-2014)
Old 01-22-2014, 01:58 AM   #18
Razz
Razz's Avatar
Drives: Fast
Is it the fuel injectors leaking air, then causing knock?
There is concern about the reliability of the seals and the design/quality of the system.
Razz is offline   Reply With Quote
Old 01-22-2014, 08:44 AM   #19
Moe23
well i checked the oil level, called in about the type of oil they used and they claim that they used the right type
Old 01-22-2014, 10:39 AM   #20
Well, I reckon it's time to post a movie ....
strat61caster (01-22-2014)
Old 01-22-2014, 11:57 AM   #21
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I've noticed my engine doesn't sound quite right when cold either. I was going to chalk it up to a Subaru quirk but the more I think about it the more I'm worried. Would love to hear a video, I'll try to get one of my own if I can replicate.
ineedyourdiddly
Old 01-22-2014, 02:22 PM   #22
Moe23
Ive tried taking a video of the noise, but my phone wont capture the sound
Old 01-22-2014, 02:24 PM   #23
Moe23
tried taking a video but i cant capture the sound
if you could take a video and post it, it would really help just to see if we both have the same problem
Old 01-22-2014, 02:47 PM   #24
strat61caster
Not sure if I can get it either, it isn't consistent and it doesn't sound like the engine is falling apart, it just sounds kind of truck like and unrefined. Honestly wasn't going to post anything about it, chalk it up to normal noises cheap sports cars make.
I'm 95% sure that a dealership won't do anything without a CEL or ECU code. So that leaves us paranoid guys in a tight spot.
ineedyourdiddly
Old 01-22-2014, 04:47 PM   #25
Moe23
LOL ya your right, I'm heading to the dealership tomorrow to replace my tail lights because water is leaking inside. so I'm going to inform them about it. Hopefully the knocking starts when they see it
Old 01-22-2014, 04:52 PM   #26
chas3wba0
chas3wba0's Avatar
Drives: Yes
Is it like a rhythmic "marching" or "chugging" kind of sound?
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 01-22-2014, 05:08 PM   #27
Moe23
its more of marching sound
Old 01-22-2014, 05:09 PM   #28
chas3wba0
chas3wba0's Avatar
Drives: Yes
I hear it too, ever since the car was new. I figured it was something to do with the fluids not being warmed to optimal temps yet. Will try to get a video of it when I cold start my car after work for reference
Knocking sound from what sounds like rear suspension husker741 Issues | Warranty | Recalls / TSB 12 04-24-2017 05:26 AM
Cold weather knocking during start ups. JDMenrique Issues | Warranty | Recalls / TSB 38 01-12-2015 11:53 PM
Knocking/Rattle on start up. jimbobrand Issues | Warranty | Recalls / TSB 18 01-13-2014 11:34 AM
Bubbling/knocking (but not liquid) sound aside from chirping mike_ekim1024 Issues | Warranty | Recalls / TSB 22 05-05-2013 03:20 PM
Knocking sounds from lowering springs? bbaik Issues | Warranty | Recalls / TSB 7 03-07-2013 11:50 PM
