Old 01-22-2014, 11:25 AM   #1
PrimeMotoring
PrimeMotoring's Avatar
Drives: FRS with 2jz, 2015 STI 9.68@147
Prime Motoring/Jr Tuned P&L Motorsports Stage 1 Turbo Kit/FlexFuel FRS 424Whp-324tq
Here is another FRS we put together recently for a customer. It features a P&L Motorsports Stage 1 Turbo Kit and our in house Flex Fuel kit. Power ranges from 290whp on 93 octane and as higher ethanol content is detected, it tops out at 16-17 psi and over 424whp and 324 wtq.
Difference between this setup and the last that made 480whp on the Hot Lava car is the slightly smaller exhaust system (2.75" vs 3") and also the use of a High Flow Cat.
The owner should be able to chime in here as well and speak of his experience with the car. So far from talking to him, he's having the time of his life
Mod List:
P&L Stage 1 Turbo Kit
ACT Heavy Duty Race Clutch Kit
Prime Motoring Flex Fuel Kit
Ultimate Racing 2.75" Exhaust System w/HFC
ID 1000cc Injectors
DW65c Fuel Pump
Crawford AOS
Feel free to ask any questions if you have any.
PrimeMotoring is offline   Reply With Quote
The Following 6 Users Say Thank You to PrimeMotoring For This Useful Post:
86 Dreams (02-27-2014), ebielat (01-22-2014), ftc~brz (01-23-2014), mack4477 (01-22-2014), P&L Motorsports (03-10-2014), sklimo (01-22-2014)
Old 01-22-2014, 12:01 PM   #2
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Awesome
The Following User Says Thank You to whitefrs For This Useful Post:
PrimeMotoring (01-22-2014)
Old 01-22-2014, 12:18 PM   #3
Michaeljp92
Drives: 2013 Scion FRS
Hello everyone, I'm the owner of the FRS posted above. Are you getting bored with 200 crank horsepower? Do you want to turn you FRS into a mental nut case on wheels? Give Prime Motoring a call!
The P&L Turbo kit has me speechless. Quality is absolute top notch! Turbo spools very quick and packs a mean punch. The ability to run ethanol has turned the car into something crazy, and the numbers I put down above were with my High Flow Cat and I was on winter blend of e55 fuel! With e80-85 fuel you could lay down 500whp+ no problem. Car pulls like hell at virtually any rpm point. On my way home from the shop I had attempted to do a 60mph pull in 3rd gear (we turned it down to 12-14psi too), and had clouds of tire smoke pouring out of the fenders. 4th gear and up you simply can't pull yourself out of the seat, although with better tires I'm sure the lower gears would be just as crazy. Despite the fact that my car is making well over double the wheel horsepower that it came from the factory with, it still is a very streetable car. It's smooth, responsive, and even when I was running on pump 93 with this turbo setup, I was averaging over 30mpg highway (Until the pedal dropped, then it went into the negatives, but who cares!).
I hope this small review helped anyone who is considering going boosted, and if you have any questions feel free to hit me up and I'd be more than glad to answer them.
Big Thanks to Prime Motoring and JR Tuned, they did a perfect job on my build and I couldn't be happier with it!
Michaeljp92 is offline   Reply With Quote
The Following 6 Users Say Thank You to Michaeljp92 For This Useful Post:
Anthony7515 (04-13-2014), connor_lol (01-22-2014), niceguy21 (01-22-2014), P&L Motorsports (03-10-2014), PrimeMotoring (01-22-2014), sklimo (01-22-2014)
Old 01-22-2014, 12:23 PM   #4
PrimeMotoring
The Following User Says Thank You to PrimeMotoring For This Useful Post:
nor cal frs (01-24-2014)
Old 01-22-2014, 12:35 PM   #5
sklimo
Awesome cuz I'm next!!!!!!!!!!!!!
Old 01-22-2014, 12:59 PM   #6
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Those two sentences don't really go together in my opinion.
Mathewgzlz (01-22-2014)
Old 01-22-2014, 01:02 PM   #7
PrimeMotoring
A car can still be smooth and very easy to drive off boost.
Old 01-22-2014, 01:06 PM   #8
King Tut
NASA SpecE30 Racer
King Tut's Avatar
What car wouldn't be? To me a "streetable" car should be able to put all of its power to the ground especially in a higher gear like 3rd, but that might just be me.
Old 01-22-2014, 01:09 PM   #9
PrimeMotoring
Im pretty sure thats what he meant by streetable though. Maybe a better way to put it is "Jeckyll and Hyde"
Old 01-22-2014, 01:11 PM   #10
Michaeljp92
By streetable I meant that it starts up like stock, drives smooth as stock, isn't even loud at lower rpm's, etc. Also the reason my spin issues are so bad is because I have 235-35-18's on the car right now. Definitely not the best tire choice for a car with this much power.
The Following User Says Thank You to Michaeljp92 For This Useful Post:
Old 01-22-2014, 01:14 PM   #11
onefitz
Drives: 13 GBS BRZ
"Jekyll and Hyde" is the exact words I use to describe my dad's stage 2+ GTI. This is a whole different level.
What size tires are on this thing?
Edit: Owner updated while I was typing.
235/35's aren't even close to enough.
onefitz is offline   Reply With Quote
Old 01-22-2014, 01:17 PM   #12
PrimeMotoring
Yea hes working on getting a wider setup now. the hot lava car we did has 265's out back and he's struggling as well lol
Old 01-22-2014, 01:20 PM   #13
Michaeljp92
Slicks are in my near future for track use, and I'll more than likely be grabbing a set of 265 or larger for street use. Lower gear traction issues don't bother me as 99% of my WOT usage is from a highway roll of 60mph or higher.
Old 01-22-2014, 01:22 PM   #14
xxscaxx
Drives: 2013 SWP BRZ
@PrimeMotoring - Great Job as always
Where did you place the flex fuel sensor that was originally bolted up on the driver side tower on the hot lava FRS? Just trying to get an idea of where i'll be installing mine when I get it I will be trying to "hide" it so this setup is going to be what I go with.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
P&L Motorsports BRZ / FR-S Stage 1 Turbo Kit P&L Motorsports Forced Induction 234 09-24-2015 05:45 PM
Prime Motoring and JR Tuned....the best whitefrs User/Vendor/Sponsor Reviews, Feedback, Comments 25 02-12-2014 07:58 PM
Prime Motoring/Jr Tuned 448whp & 346wtq P&L Motorsports Stage 1 Turbo Kit FRS PrimeMotoring Forced Induction 46 01-21-2014 03:58 PM
P&L Motorsports Stage 1 Turbo Kit Review (In Progress) Supermassive Forced Induction 66 02-07-2013 02:30 PM
P&L Motorsports BRZ / FR-S Stage 1 Turbo Kit P&L Motorsports Engine, Exhaust, Bolt-Ons 56 09-22-2012 04:28 PM
