Old 01-22-2014, 12:10 AM   #1
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
BRZ Headlight Running Light (the Boomerang) Schematic
EDIT: I have created a DIY for this. You can find it here.
I'm in the process of completely revamping my headlights with Luxeon Rebel turn signals, significantly brightening the boomerangs up, doing a lens swap, and washer modding the projectors. I created a schematic for the boomerang and wanted to share it with the forums.
Some readings I took tonight:
At 12.7v source voltage, the circuit pulls 154mA through each LED. The equivalent resistance of the parallel resistor circuit is 39 ohms. The dual capacitors in parallel with the Zener diode in reverse bias function as a pseudo-voltage regulator. The makes the boomerangs much less susceptible to dimming from voltage drops related to drops in engine idle rpm. The DRLs are really bad about this because there is no control circuitry or capacitor/Zener diode circuit on them. If you ever park your BRZ close to and facing a wall, keep your foot on the brake while slowly letting the clutch out, just enough to drop the engine rpm slightly, you'll see the DRLs dim, or even turn off. The boomerangs won't do this because of this circuit.
Information concerning the LEDs; they are Luxeon Rebel LEDs, just like the DRLs. They are considerably under-driven to eliminate the need for thermal management. Typically, these LEDs are designed to run at between 700-1000mA current, but those levels of current require considerable heat dissipation via the use of passive or active heat sinking.
Any questions, feel free to ask.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
The Following User Says Thank You to Acree For This Useful Post:
Wonderbar (03-07-2014)
Old 01-22-2014, 12:37 AM   #2
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
I have no clue what that sheet says, but if you can make a plug and play, or at least a starter kit for something like this, take my money now.
Subb'd, and very interested..
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
The Following User Says Thank You to BRZPDX For This Useful Post:
glorydays (01-27-2014)
Old 01-22-2014, 01:43 AM   #3
Acree
Acree's Avatar
What kind of a kit are you looking for? Running the boomerang brighter like I'm doing? That would require disassembly of your headlight. I could offer a plug and play kit, you'd have to take the headlights apart anyways.
Old 01-22-2014, 08:37 AM   #4
Drobinson1692
Drives: 2007 Honda S2000
what all would a plug and play kit include?
Drobinson1692 is offline   Reply With Quote
The Following User Says Thank You to Drobinson1692 For This Useful Post:
sirisvirus (04-05-2014)
Old 01-22-2014, 09:55 AM   #5
BRZPDX
Boosted Member
BRZPDX's Avatar
Yea making the boomerang lights brighter, I am planning on baking my lights this weekend so it will be disassembled..
That will be awesome if its plug and play!! Want to see how it turns out first though, when are you planning on doing this?
Old 01-22-2014, 01:52 PM   #6
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
I remember someone taking apart the headlight and seeing that there was only one LED to provide light for the boomerang. It may be possible to add more LED's to provide additional light. I agree that its too bad it isn't brighter in the first place.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 01-22-2014, 02:12 PM   #7
Acree
Acree's Avatar
I can assure you it's two LEDs, one on each end.
Cjymiller (01-23-2014)
Old 01-22-2014, 02:13 PM   #8
Acree
Acree's Avatar
I can make it plug and play but you would have to ship me both parking light assemblies as pictured above this post. Turn around time would be 24 hours.
Old 01-22-2014, 02:31 PM   #9
gt8613
I dream of BRZ
Drives: Prospective BRZ owner.
I now <3 Electric Engineers.
Sent from my RM-940_nam_att_200 using Tapatalk
gt8613 is offline   Reply With Quote
The Following User Says Thank You to gt8613 For This Useful Post:
ftc~brz (01-22-2014)
Old 01-22-2014, 02:40 PM   #10
gt8613
I dream of BRZ
Do you know why Subaru choose to not make them DRLs in the first place?
Old 01-22-2014, 03:11 PM   #11
Acree
Acree's Avatar
I can't really answer that one. The actual DRL's are pretty damn bright already and it would cost more in parts to make the boomerang as bright as them. My guess is it was a cost saving measure in the same way they didn't put any voltage or current regulating circuitry on the DRLs.
Old 01-22-2014, 03:27 PM   #12
fourvalleys
Howdy!
fourvalleys's Avatar
Drives: Party ST, Classic Mini
Whew, I thought I was going crazy.
fourvalleys is offline   Reply With Quote
Old 01-22-2014, 03:31 PM   #13
Travisty75
Travisty75's Avatar
Drives: 2015 Scion FR-S
I'm stupid and tried making the boomerang brighter by simply bypassing the circuit board they're on and applying 12v directly to them. I for some dumb reason assumed they had regulators built in and dropped to the ~5v they need at the actual LED itself.. Result? Blown LED of course.
I had to go buy a new SMD, and flash-solder it to the circuit board. That was my first and hopefully last time doing that.
Could you repair what I borked, and make them brighter? I can pull and bake apart the lights this weekend.
Travisty75 is offline   Reply With Quote
Old 01-22-2014, 03:35 PM   #14
B L U E S L A T E
Drives: BMW E84
Sub'd. Thanks for taking the time to do this.
B L U E S L A T E is offline   Reply With Quote
Daytime Running Light delete TSB! Memphis Issues | Warranty | Recalls / TSB 256 07-22-2017 10:55 PM
BRZ ‘s “boomerang” LED strip mystery DrakeM BRZ First-Gen (2012+) — General Topics 114 05-05-2015 12:00 PM
SCION FR-S LED DRL Daytime running light fog lamp cover GT/86 Cosmetic Modification (Interior/Exterior/Lighting) 12 07-20-2014 08:08 PM
Daytime Running Light/ Crystal Vision Ultra Memphis Cosmetic Modification (Interior/Exterior/Lighting) 14 02-08-2014 06:52 PM
scion led running light accents? Stryker Trailwood Scion FR-S / Toyota 86 GT86 General Forum 47 07-20-2013 09:48 PM
