Old 01-20-2014, 06:56 PM   #43
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
Originally Posted by Kelbyat07 View Post
Great build, loving the exhaust and rear diffuser.
Do I need to make an appointment for exhaust installation?
@Kelbyat07 Thanks!
Yeah, just give us a call to make an appointment.
Touge Factory is offline   Reply With Quote
Old 01-20-2014, 07:11 PM   #44
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
With the diff cover, can you still use the diff as a jacking point?
Ryaquinn is offline   Reply With Quote
Old 01-21-2014, 01:21 PM   #45
Touge Factory
Drives: ZN6
We wouldn't recommend you use the Greddy cover as the jacking point, although I'm sure it can support the weight. Over time I wouldn't be shocked if your it leaked fluid between the cover and the diff.
If your car has the clearance for the jack to go past the cover and under the actual diff, then yes.
at our ride height, we could get a low profile jack past the cover, but by the time we get about 1/4 inch away from lifting the car, the arm of the jack hits the cover.
The Following User Says Thank You to Touge Factory For This Useful Post:
Ryaquinn (01-21-2014)
Old 01-21-2014, 01:23 PM   #46
Touge Factory
Drives: ZN6
Fast forward a little bit....
We'll get back to getting the car up to this point shortly.
Old 01-21-2014, 07:45 PM   #47
Touge Factory
Drives: ZN6
Originally Posted by Dezoris View Post
Who is doing your ecutek tuning?
Missed your post...sorry.
We're running the Carb Legal tune by J.R for now.
Old 01-21-2014, 08:16 PM   #48
Touge Factory
Drives: ZN6
and here we go... starting the removal process.
Old 01-22-2014, 03:33 PM   #49
Touge Factory
Drives: ZN6
Koyo Radiator going in with Koyo High pressure radiator cap.
Buttoned back up after install. You can see the Perrin silicone radiator hoses.
Pulley removed to install Rotrex Compressor mounts:
Compressor Mounted:
Intercooler piping routed
Intake pipe going in:
TADA!
The Following 3 Users Say Thank You to Touge Factory For This Useful Post:
ATL BRZ (01-24-2014), clickfiveZ (01-24-2014), SkAsphalt (01-22-2014)
Old 01-23-2014, 07:36 AM   #50
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Game. Over.
The Following User Says Thank You to TylerLieberman For This Useful Post:
Touge Factory (01-23-2014)
Old 01-23-2014, 01:48 PM   #51
Touge Factory
Drives: ZN6
Here is our Oil Cooler setup:
The fake grill thing was removed to allow ample air flow to the cooler.
Look from under the car.
This is with the fender liner removed. Tight fit.
Only thing we needed to do to make this fit was to pivot the factor horn to the side.
Another view of the cooler with custom made brackets.
There are two small brackets and one large one. Mounted rock solid!
*you can also see the horn in this picture.
The Following 2 Users Say Thank You to Touge Factory For This Useful Post:
clickfiveZ (01-24-2014), Scottemad123 (01-23-2014)
Old 01-24-2014, 04:20 PM   #52
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Ah, we did not take pics.
However, you cannot use the ducts, but there is enough hose to loop around the piping on the passenger side.
When we get a chance, we'll try to take some pics.
Going FI?
Oh ffffuuuuu I need to stay out of this thread. Some dangerously tempting stuff going on in here with all these Rotrex installs.
That said, I'm curious how one would adapt the TF brake cooling kit to a JR SC kit while retaining the fender liners but deleting the OEM washer fluid tank entirely; because race car. Would it be easy as getting the APR carbon ducts for the fog light housings and possibly getting longer hoses? Or would the existing hoses be long enough? Either way I understand that I'd have to ditch the plastic ducts provided in your kit for something else in another location. The fog light housings seem to be the best alternative, but they have the caveat of being difficult to run hoses to on the driver's side with the washer fluid tank present. My tank is currently empty as I never use the sprayer anyways, so deleting it wouldn't be an issue.
Pics would be great.
Old 01-24-2014, 04:54 PM   #53
Touge Factory
Drives: ZN6
Originally Posted by ATL BRZ View Post
Oh ffffuuuuu I need to stay out of this thread. Some dangerously tempting shit going on in here with all these Rotrex installs going on.
For the white BRZ, we did ditch the plastic ducts.
We even removed the silicone coupler and used just the aluminum joiner (drilled two small holes enough for zipties to fit through), and ziptied that straight to the grill. Fits without much tweaking, just have to snake over one of the intercooler pipes.
Just for shits and giggles we mocked up the hose behind the fog light to see if the hose would reach, and sure enough - the hose reaches.
Without the washer fluid tank, it is much easier to route the hose.
Old 01-24-2014, 05:05 PM   #54
Chase Bays
Chase Bays's Avatar
Drives: FR-S | 335i | S13
I had the same problem you did on the front tires scrubbing causing the front to "brake" mid drift. It was horrible, didn't realize it until the end of the entire day. I thought I had just lost all my skills.
Enjoyed reading this! Interested to see how much power you make.
Chase Bays is offline   Reply With Quote
Old 01-24-2014, 05:19 PM   #55
Touge Factory
Drives: ZN6
I know the feeling...
Old 02-03-2014, 06:42 PM   #56
mike@vossen
Drives: GS F-sport | LS F-Sport
WHAT A BUILD! Amazing!
mike@vossen is offline   Reply With Quote
The Following User Says Thank You to mike@vossen For This Useful Post:
Touge Factory (02-04-2014)
Hyper-BRZ Build Journal hypermax Member's Car Journals 62 06-10-2016 11:39 PM
Gopherboy's WRB BRZ Limited - Build Journal Gopherboy6956 Member's Car Journals 41 03-22-2015 01:28 AM
The Ongoing FR SPORT BRZ Build Journal FRSport.com Member's Car Journals 13 01-27-2014 07:32 PM
1 SIK FRS Raven FRS Build Journal 1SIKFRS Member's Car Journals 20 01-19-2014 02:58 AM
Build Journal for Koigataki (6MT Argento FR-S) Koigataki Member's Car Journals 25 10-10-2013 02:09 AM
