Old 01-13-2014, 06:35 PM   #29
GuerillaRacing
GuerillaRacing's Avatar
Drives: Scion FR-S
Nicely documented buildup, keep it coming!!
GuerillaRacing is offline   Reply With Quote
The Following User Says Thank You to GuerillaRacing For This Useful Post:
Touge Factory (01-13-2014)
Old 01-14-2014, 01:07 PM   #30
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
Competition Clutch and flywheel was the choice for our customer's car with the Jackson Racing Supercharger kit.
We went with Stage 3 Segmented disk and lightweight flywheel.
We have used the Stage 3 for various applications for mixed driving between daily and track use. Can take some abuse without sacrificing driveability.
Torque capacity for the Stage 3 is rated at 300ft/lbs at the wheels. Peddle pressure is moderately firmer then stock, nothing that will annoy you while driving in the city. You could easily drive this car through Chicago rush hour traffic without getting a let workout.
First drive out with this clutch was a cinch. Engagement is quick and grabby but feels very solid. Peddle feel is right on par with the way it grabs. Easy to drive.
You can notice how much more responsive the engine is with the new flywheel.
***For our shop car, we'll be sticking with stock clutch and flywheel to see what kind of abuse it can take with the Jackson Racing sc kit. We already know J.R's car has 15,000 miles on their stock clutch. Let's see what few clutch kicks will do with the added power.***
Now for the pics.
Here is the kit laid out.
In goes the flywheel.
In goes the Segmented Disk.
In goes the pressure plate.
Touge Factory is offline   Reply With Quote
The Following User Says Thank You to Touge Factory For This Useful Post:
Scottemad123 (01-14-2014)
Old 01-16-2014, 03:12 PM   #31
Touge Factory
Drives: ZN6
We wanted to give more cooling capacity for the Tomei 2-way LSD.
Greddy Diff cover
If need be, making an external cooler with a pump should be easy with this diff cover.
This diff cover sits approximately 1.2" lower then stock, something to consider if you're planning on substantially lowering your car.
Old 01-17-2014, 11:31 AM   #32
Touge Factory
Drives: ZN6
buttoned up this thing just in time for SpeedHunters.
mrk1 (01-17-2014)
Old 01-17-2014, 12:00 PM   #33
mrk1
Drives: Sterling BRZ Ltd
Comp clutch looks nice, do you know the weight of the flywheel ?
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 01-17-2014, 12:28 PM   #34
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Any chatter/noise with that clutch??
Old 01-17-2014, 03:05 PM   #35
Touge Factory
Drives: ZN6
12.9 pounds
Old 01-17-2014, 03:06 PM   #36
Touge Factory
Drives: ZN6
None so far.
On our Evo X, we have the same type of clutch with a lightened flywheel, and no chatter.
Old 01-17-2014, 07:19 PM   #37
Touge Factory
Drives: ZN6
The Following 2 Users Say Thank You to Touge Factory For This Useful Post:
Chase Bays (01-24-2014), Goya (01-18-2014)
Old 01-17-2014, 08:03 PM   #38
Dezoris
Dezoris's Avatar
Who is doing your ecutek tuning?
Old 01-17-2014, 08:32 PM   #39
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Do you have any more pics of how you routed the brake ducts around the Jackson Racing intercooler?
Old 01-20-2014, 04:58 PM   #40
Touge Factory
Drives: ZN6
Ah, we did not take pics.
However, you cannot use the ducts, but there is enough hose to loop around the piping on the passenger side.
When we get a chance, we'll try to take some pics.
Going FI?
Old 01-20-2014, 04:59 PM   #41
Touge Factory
Drives: ZN6
Old 01-20-2014, 05:17 PM   #42
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
Great build, loving the exhaust and rear diffuser.
Do I need to make an appointment for exhaust installation?
Kelbyat07 is offline   Reply With Quote
The Following User Says Thank You to Kelbyat07 For This Useful Post:
Touge Factory (01-20-2014)
Hyper-BRZ Build Journal hypermax Member's Car Journals 62 06-10-2016 11:39 PM
Gopherboy's WRB BRZ Limited - Build Journal Gopherboy6956 Member's Car Journals 41 03-22-2015 01:28 AM
The Ongoing FR SPORT BRZ Build Journal FRSport.com Member's Car Journals 13 01-27-2014 07:32 PM
1 SIK FRS Raven FRS Build Journal 1SIKFRS Member's Car Journals 20 01-19-2014 02:58 AM
Build Journal for Koigataki (6MT Argento FR-S) Koigataki Member's Car Journals 25 10-10-2013 02:09 AM
