Old 01-21-2014, 03:58 PM   #197
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
Originally Posted by DC2R View Post
Seems drop-in is the way to go. I'm between K&N or HKS. Seems HKS is more restrictive but people seem to believe K&N don't filter enough particles.
Take a look at the Apexi drop-in. I think it was as good as, and it doesn't need to be oiled.
http://www.ft86club.com/forums/showt...ghlight=filter
oldpueblo is offline
The Following User Says Thank You to oldpueblo For This Useful Post:
DC2R (01-21-2014)
Old 01-21-2014, 06:00 PM   #198
DC2R
Drives: 2014 Scion FR-S
That chart is awesome! I'd get it if it wasn't disposable. I like having a filter that I can run for life of car. Seems like next best hp per dollar upgrade is a muffler delete
Sent from my SM-N900T using Tapatalk
DC2R is offline
Old 01-21-2014, 06:21 PM   #199
oldpueblo
oldpueblo's Avatar
I figured no filter is disposable or at least will have a longish life as long as you clean it, what filter wouldn't require replacement/cleaning?
Old 01-21-2014, 06:27 PM   #200
DC2R
I'm with you on periodic cleaning but not down to buy one that you throw away at 15k miles
Sent from my GT-N5110 using Tapatalk
DC2R is offline
Old 01-21-2014, 09:03 PM   #201
oldpueblo
oldpueblo's Avatar
Out of curiosity, where does it say to throw it after 15k? This is the closest I've found and it doesn't actually say that:
Filter life has been tested to operate over 25,000km (15,000mi) under normal street driving conditions. Filter maintenance and overall life differs depending upon conditions under which the filter is used. Inspect for wear and tear, use best judgment, and replace if damage is suspected.
The filter can be cleaned by blowing compressed air through the filter, opposite the direction of inbound airstream. This filter is designed for use as a dry-type filter. Do not apply filter oil to this filter as it was not designed to utilize such oils. Water, cleaning solvents, and other liquids may damage the filter and must not be used to clean the filter.
Old 01-21-2014, 11:05 PM   #202
DC2R
Guess I didn't read enough. My bad. Looks like you just blow it out until it breaks
DC2R is offline
Old 01-22-2014, 02:27 AM   #203
oldpueblo
oldpueblo's Avatar
No worries, just wanted to be sure I wasn't going to get a nasty surprise after 15k.
Old 08-11-2014, 04:32 AM   #204
86Limited
Drives: 2014 Toyota 86 Limited Edition
just dropped in a K&N filter, its epic, much more induction noise,more response, well worth the money
2014 Toyota 86 Limited Edition (Crystal Pearl White)
86Limited is offline
Old 12-06-2014, 08:29 PM   #205
Lonewolf
Lonewolf's Avatar
Drives: Moped
Any updates on testing other drop-ins for filtration effectiveness and air flow gains?
Lonewolf is offline
Old 12-06-2014, 09:08 PM   #206
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Went with a K&N a few months back. Not sure if it was placebo but it did feel a bit better over the crappy stock filter.
hmong337 is offline
Old 12-07-2014, 02:27 AM   #207
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by FT-86 SpeedFactory View Post
***Reserved for photos of me messing with your corn if you post horrible things!***
I couldn't resist.
Do you know the difference between Des Moines and yogurt?
Yogurt has an active culture.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline
The Following User Says Thank You to mid_life_crisis For This Useful Post:
N234 (02-04-2015)
Old 04-04-2015, 05:14 PM   #208
BaBaFlyingSheep
Drives: 2015 BRZ Ltd 6MT
We have the K&N in our Red FR-S and the aFe Dry element in our Silver FR-S for long term studies, ok well medium term until more upgrades are done.
Any updates regarding the mid-long term studies on the K&N and aFe?
Also, does anyone have information regarding the TRD filter?
BaBaFlyingSheep is offline
The Following User Says Thank You to BaBaFlyingSheep For This Useful Post:
funwheeldrive (12-23-2016)
Old 04-04-2015, 06:45 PM   #209
churchx
churchx's Avatar
Drives: 2014 GT86
Wasn't TRD almost same as drop in filters performance wise, except that for higher price one also gets sound tube delete & keeps warranty?
churchx is offline
Old 04-06-2015, 02:47 AM   #210
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Any1 seen any tests for the UPGR8 brand?
Bonburner is offline
AT/MT Dyno Results with/without Mods blackfireball5 Engine, Exhaust, Transmission 0 07-04-2012 02:34 PM
My Fr-s Dyno Results!! Surprising if you ask me track_warrior Engine, Exhaust, Transmission 36 07-02-2012 10:15 PM
K&N Drop-In Filter for BRZ/FR-S in stock! Mach V Dan Engine, Exhaust, Bolt-Ons 0 06-27-2012 02:41 PM
Dyno results for the Nameless Performance street package! John@Nameless Announcements, Contests, Giveaways 31 06-26-2012 04:37 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
