Old 01-21-2014, 01:34 AM   #309
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Originally Posted by TrogDor the Burninator View Post
I thought I had read on the Kraftwerks thread that with their kit at 7400 RPM the Rotrex was spinning closer to the max rpm suggested by Rotrex than 90% ...
Is it different on the Jackson Racking kit? I understand the belt systems are different, but at 7400 RPMs with the JR pulley in the kit - is it spinning the Rotrex at 90% of suggested maximum RPMs?
KW kit is aprox 93% and the JR is closer to 90% I believe. Forgot specific percentages
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following User Says Thank You to OmarGC For This Useful Post:
TrogDor the Burninator (01-21-2014)
Old 01-21-2014, 01:38 AM   #310
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Stock kits:
JR impeller speed @7400: 7400x1.29x9.49 = 90,591 rpm = 90.6% rated capacity
KW impeller speed @7800: 7800x1.33x9.49 = 98,696 rpm (KW's tune redlines at 7800) = 98.7% rated capacity
Vortech impeller speed @7400 : 41,588 rpm = 83.2% rated capacity
Kits as pictured in graphs:
Jackson Racing: 90.6% - 90,591 rpm (100k max)
Kraftwerks: 93.4% - 93,401 rpm (100k max)
Vortech: 86.0% - 43,022 rpm (50k max)
Bottom %'s are what you should be more focused on.
Omar GC
Instagram: 2jzus
Old 01-21-2014, 02:18 AM   #311
CSG David
CSG David's Avatar
It is based on the level of boost and how efficient the system is in producing those boost levels. Think of a balanced package where every component effects each other but needs to be optimized in order to produce an efficient output.
The Following User Says Thank You to CSG David For This Useful Post:
Old 01-21-2014, 05:05 PM   #312
sklimo
Look what showed up at my installer!!!! Can't wait for next month!!
PRORICAN (01-21-2014)
Old 01-21-2014, 05:09 PM   #313
D K
Stig's dark passenger
Rotrex can go to 120k
D K is offline   Reply With Quote
Old 01-21-2014, 05:18 PM   #314
CSG Mike
CSG Mike's Avatar
Hmmmm what do we have here? More information at: http://www.ft86club.com/forums/showthread.php?t=56229
sklimo (01-21-2014)
Old 01-22-2014, 10:51 AM   #315
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
So I had an opportunity to experience this kit last night and I'm sold. The whole experience was great! The car has some nice kit, but it was soooo smooth throughout the power band. I was really impressed!
I've been researching for several months, following build threads, reading reviews, and I keep coming back to this kit.
Might be time to pull the trigger and get this bad boy installed! Uncle Sam owes me some money and I know where it's going!
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
The Following 3 Users Say Thank You to *LongFella For This Useful Post:
CSG Mike (01-22-2014), Jackson Racing (01-29-2014), ramiram1984 (01-27-2014)
Old 01-23-2014, 03:59 PM   #316
sklimo
My kit is going in this weekend!!!!!
The Following 4 Users Say Thank You to sklimo For This Useful Post:
*LongFella (01-23-2014), CSG David (01-23-2014), PRORICAN (01-23-2014), ramiram1984 (01-27-2014)
Old 01-24-2014, 07:45 PM   #317
*LongFella
*LongFella's Avatar
Question for the experienced folks...
Will the JR SC Tune you get with the kit be thrown off so much so were you need a new tune if you add a bolt one (catted) header?
Reason I ask: I really like the work being put into the ft86sf catted UEL header, but I know I'm 100% on this kit too. Should I get the non-tune sc kit or will jr's tune work with the bolt on catted header?
Sorry for the noob question!
Old 01-24-2014, 09:32 PM   #318
phun-ky
Drives: Nothing right now :O
Can anybody comment on how much headroom there is in the JR SC kit? Say I have rebuilt the engine to 9:1 or 10:1 compression ratio. Would the kit be able to take an advantage of it?
phun-ky is offline   Reply With Quote
Old 01-24-2014, 11:34 PM   #319
Calum
That Guy
Drives: 2013 asphalt FRS MT
no
Old 01-25-2014, 01:02 AM   #320
CSG David
CSG David's Avatar
If you plan to change the OEM emission equipment in any way such as adding a HFC into the system, the tune will not be optimal for the setup. You will need to tune to that particular setup. This goes for the same for any CARB legal supercharger kits on the market. If you plan to change the stock emission systems, go with a custom tuned setup, otherwise CARB configuration can only work with CARB legal setup (OEM).
*LongFella (01-25-2014)
Old 01-25-2014, 11:52 AM   #321
*LongFella
*LongFella's Avatar
Thank you sir!
I guess I need to find out more details about the cat they plan to use. Apparently, it's a bolt on header that doesn't throw CEL codes or needs a tune to optimize... just bolt on and use... might be nice for us CA folks!
Can't wait for damn Uncle Sam did give me my money! I want my sc kit now!!!!
Old 01-25-2014, 12:04 PM   #322
CSG Mike
CSG Mike's Avatar
Thank you sir!
If it changes so little that you can bolt-on and use, then it also means that it changes the parameters so little, that it effectively is equivalent to the stock header.
Remember, we have a MAF based car that works off of volumetric efficiency tables. Volumetric efficiency changes if flow significantly changes, which is what throws off the tune.
jackson racing, jrsc, rotrex, supercharger, track
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
HKS GT Supercharger (Rotrex) in development! madfast Engine, Exhaust, Transmission 206 12-14-2012 04:28 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 03:29 PM
