Old 01-20-2014, 06:27 PM   #15
Carolina Dyno
Carolina Dyno's Avatar
Drives: 2013
The prototype is finished and actually already sold... I really didn't even want to take it off my car but I can't complain about selling them faster than I thought. Hopefully CSG Mike will have a review as well as fitment feedback on a RobiSpec radiator.
Wiring is done with Raychem, Tefzel, and Deutsch DT Series connectors.
The seals came in today as well, they are a perfect fit against the radiator all the way around.
We added this clip to help keep the rubber compressed all the way across. You can see how much more room is gained for a turbo setup.
I had to at least take a picture of it fully installed before I pulled it back out to ship.
Carolina Dyno is offline   Reply With Quote
The Following 5 Users Say Thank You to Carolina Dyno For This Useful Post:
Anthonytpt (01-24-2014), johnb831 (01-20-2014), mad_sb (01-24-2014), mrk1 (01-20-2014), Sportsguy83 (10-20-2016)
Old 01-20-2014, 10:41 PM   #16
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
Originally Posted by Carolina Dyno View Post
Lower CFM but lower amperage draw as well. They are definitely a less efficient blade design because of the shallow fitment. Spal makes hands down the best aftermarket fans out there and they are very efficient for their size. These will provide adequate cooling for any conditions with a Koyo radiator. I probably wouldn't recommend going on track with a stock radiator and these fans but then again I wouldn't go on the track with the stock radiator in the first place.
So with the Koyo rad and this fan, will it be a cooling upgrade overall compared to the OEM setup? My custom turbo kits hot pipe does run very close to the OEM fans, just like the FB kits do.
If this doesn't compromise the cooling, I am very interested so my fans don't melt..
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 01-21-2014, 07:50 AM   #17
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
How much are you selling the combo for?
(Fans and shroud)?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 01-21-2014, 08:55 AM   #18
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Will you be offering this with a thicker SPAL fan? I'm not going to be going the turbo route so I have some extra room and would like the extra air movement. I like what you guys are doing. Keep up the innovative work.
Dustin is offline   Reply With Quote
The Following User Says Thank You to Dustin For This Useful Post:
diss7 (01-25-2014)
Old 01-21-2014, 01:03 PM   #19
Carolina Dyno
Drives: 2013
Yes, this will definitely be an overall cooling upgrade. I would also recommend a low temp thermostat to complete the setup if it is a track car. If it's just a daily/weekend warrior the stock thermostat is better.
(Fans and shroud)?
We are selling the whole combo for $400.
We definitely could, there are a number of SPAL fans with identical mounting points. Most of the larger fans are almost double the price but we could definitely put a package together for you if you're interested. Feel free to email me at ben@carolinadyno.com or PM me if you're interested. For the turbo guys you could also run a thin fan on the turbo side and a large fan on the open side. Honestly though there wouldn't really be any reason to increase the fan size, there should be no cooling issue regardless of climate or use with this setup so all you would be doing is adding draw on the alternator.
The Following 2 Users Say Thank You to Carolina Dyno For This Useful Post:
CSG Mike (01-21-2014), Dustin (01-21-2014)
Old 01-21-2014, 01:05 PM   #20
CSG Mike
CSG Mike's Avatar
Oops
Anthonytpt (01-24-2014), DriftEightSix (01-21-2014)
Old 01-23-2014, 03:42 PM   #21
taylork057
Drives: 2013
When will these be available?
taylork057 is offline   Reply With Quote
Old 01-23-2014, 06:00 PM   #22
CSG Mike
CSG Mike's Avatar
@Carolina Dyno: Ben, do you know the CFM of the stock fans?
Old 01-23-2014, 06:03 PM   #23
MMorganFRS
MMorganFRS's Avatar
Drives: 2013 Scion FRS
Wow great deal!! I will for sure jump on buying one of these!
2013 Scion FRS (Whiteout) 6-Speed Manual
Zex Wet Nitrous Kit (Not Installed)
www.morgansfrs.com
"Nitrous is like a hot girl with and STD, you want to hit it but you are afraid of the consequences"
MMorganFRS is offline   Reply With Quote
Old 01-23-2014, 10:39 PM   #24
Carolina Dyno
Drives: 2013
I wish I did. I assume it's a good bit higher than any slim fan just by looking at the OEM profile but that's just an assumption. I don't know of anyway to find out besides having one tested by a third party which probably isn't worth it, there's not much we can do with that info although I'd love to know as well.
Thanks, we should have them available within the next week. Our online store will be up shortly as well.
The Following User Says Thank You to Carolina Dyno For This Useful Post:
Brzzee (03-20-2014)
Old 01-24-2014, 12:27 AM   #25
CSG Mike
CSG Mike's Avatar
I'm happy to report that the shroud fit on the Robispec radiator. We did have to supply our own hardware, but that's our fault for being in a rush to purchase the prototype...
Anthonytpt (01-24-2014), Draco_PR23 (03-18-2014)
Old 01-24-2014, 12:33 AM   #26
ft86me
ft86me's Avatar
Drives: 2013 FRS
can you please post when they are readily available for sale? i am interested!
ft86me is offline   Reply With Quote
Old 01-24-2014, 08:17 AM   #27
MMorganFRS
MMorganFRS's Avatar
This gives me plenty of room for LSX swap and room for little spooling action!
www.morgansfrs.com
Old 01-24-2014, 01:44 PM   #28
Carolina Dyno
Drives: 2013
Sorry about that, I could have thrown some in if I knew you needed it. Glad to hear it fits well, was the seal properly pressed up against the core? There isn't much wiggle room with the seal we had to use.
Absolutely, they should be ready around Wednesday next week. Our online store will go live at the same time. Ill post the minute it happens. Thanks for your interest
Have you already started the swap? There should be tons of room I'm interested to see the finished swap.
ft86me (01-24-2014)
new koyo radiator autobrz Engine, Exhaust, Bolt-Ons 1 12-25-2013 08:42 AM
Frs/brz koyo radiator F-T Engine, Exhaust, Bolt-Ons 16 12-02-2013 02:48 PM
Koyo Radiator SALE!!! Powerhouse Racing Engine, Exhaust, Bolt-Ons 1 10-07-2013 10:22 AM
KOYO Radiator In-Stock!!! Free Shipping!!! Titanmotorsports Engine, Exhaust, Bolt-Ons 24 07-09-2013 05:55 PM
Koyo Radiator vs Oil Cooler Captain Snooze Engine, Exhaust, Transmission 54 06-21-2013 11:18 PM
