Old 01-21-2014, 08:32 AM   #1
brillo
Drives: 2013 Firestorm FR-S
Trip Computer / Odometer Accuracy
I was cruising along the highway and decided to see how accurate our odometer / trip computer was via the mile markers to kill some time. Over several observations, my trip computer was consistently below by ~.1 miles compared the mile markers as I was driving. Can that be correct? I would think that the trip computer would be dead on accurate as far as calculating mileage. I have different tires than stock but they are the same size (225/45/17). The area was quite flat as well.
Are mile markers accurate? 10% seems too high in terms of inaccuracy.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 01-21-2014, 08:51 AM   #2
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Check Tire Rack to see how many revolutions per mile your new tire has compared to the original. Even tires of the same size can vary on revs per mile. Also, it could be an air pressure difference could cause that as well.
Grimlock is offline   Reply With Quote
Old 01-21-2014, 09:04 AM   #3
brillo
revolutions are the same for both and the tires are pressurized to 35psi.
Old 01-21-2014, 09:20 AM   #4
DarkSunrise
DarkSunrise's Avatar
225/45/17 is not stock size. Stock is 215/45/17.
2022 BRZ Build
2013 FR-S Build
Old 01-21-2014, 09:22 AM   #5
brillo
that was a mis type on my part (not enough coffee). my tires are 215/45/17.
Old 01-21-2014, 09:33 AM   #6
DarkSunrise
Ah ok, I see it's in your signature too. I'm out of ideas then, although I did hear manufacturers tend to set their odometers conservatively bc they had gotten sued in the past for odometers that recorded too many miles.
2022 BRZ Build
2013 FR-S Build
Old 01-21-2014, 10:18 AM   #7
IronSean
Drives: 2006 Toyota Camry
Did you just check one mile at a time? Or did you get a total over multiple miles to be a bit more accurate? I'd be more concerned if it said 9.0 miles after 10. If it's just showing 0.9 every time you hit the mile marker it could actually be something like 0.98 miles per mile marker which isn't as bad.
IronSean is offline   Reply With Quote
Old 01-21-2014, 11:02 AM   #8
993Fan
993Fan's Avatar
Drives: 2014 DGM BRZ MT
I wouldn't be surprised if the road markers themselves are in error. I doubt they used GPS coordinates to locate them, especially if it's an older road. More likely, they were located by somebody using the odo in his pickup truck with worn tires...
993Fan is offline   Reply With Quote
Old 01-21-2014, 11:12 AM   #9
I agree.
I think you would need a longer distance (larger sampling) to get an accurate reading......
Old 01-21-2014, 11:20 AM   #10
wrxneffect
wrxneffect's Avatar
Drives: 13 BRZ Ltd 6MT(sold), 03 WRX (RIP)
There is always going to be some error with any measurement device. I have no idea what the specs are for the trip computer. Maybe +/- 10% is to be expected, I hope not though. Plus there is also the error associated with the measurement of the mile markers themselves as others have mentioned.
Sounds like you should drive more awesome miles in the car to find out.
wrxneffect is offline   Reply With Quote
What 18 and 19 in tire sizes will not mess with odometer Frs32907 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-07-2013 03:59 PM
BRZ Navigation accuracy and features Don_SA BRZ First-Gen (2012+) — General Topics 41 05-06-2013 12:55 PM
Computer for my Frs help Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 22 09-28-2012 04:51 PM
Speedometer Accuracy MTeator Scion FR-S / Toyota 86 GT86 General Forum 16 08-22-2012 08:39 AM
An example of rumour accuracy. Dimman Scion FR-S / Toyota 86 GT86 General Forum 7 01-04-2011 08:53 PM
