Old 01-21-2014, 05:44 AM   #57
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
I've been waiting almost a year for this, the perfect price, and perfect timing.. At 1am this morning, a post feel into the screen of my iPad, and a hour later and 250$ a 2010 GTR spoiler was in my trunk, on the way home.. Now I need to get it molded.. @Kiske, wanna make another set of molds
In perfect condition, just missing three small screws for a cover in the underside.. Will order from Nissan tomorrow
And yes it's dark and can't see shit but I couldn't wait
Gixxersixxerman is offline   Reply With Quote
Old 01-21-2014, 08:39 AM   #58
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
When it is fully done I due a photo op. Assuming I can move the spoiler forward (all the bottom sides of my mounts are solid piece of 3m moulding attachment tape for added support. I can't pull it off, the decklid will bend first. I hope to leave it in the sun all day to make the take let loose a bit easier. Just needs to come forward 1/8: or so so all my posts will be in proper alignment.
Thanks, but, I will pass. I have worked from 4pm to 2am for the past 7 days on mine (not including a 45 hour work week.) I will help you out a bit. The center pillar will also need redone. I cut mind in half and filled it with abs plastic then re-drilled through the center, I ran my wiring through this. It was near impossible to feed the wiring through the side mounts after molding it in. If you don't want to run the 3rd brake light you can get a carbon fiber top half without it. But be warned the existing 3rd brake light will be perfectly blocked when the spoiler is on. I found it a requirement to run the center part. Mine is still removable but, when removed the spoiler wobbles and stresses when driving and extremely when moving the decklid. LMK if you need anymore pictures of the process I used.
Old 01-21-2014, 02:07 PM   #59
Gixxersixxerman
I will be sending you a PM and if I run into any issues let you know.. Most likely I'll get a shop to do it. My fiberglass skills are subpar at best
Old 01-21-2014, 02:36 PM   #60
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
@Kiske That's awesome that you were able to replicate that setup so well. Color me VERY VERY impressed.
denkigrve is offline   Reply With Quote
Old 02-08-2014, 07:27 PM   #61
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Well apparently mother nature (that bitch) won't let me have good weather too keep my work. Shitty pictures until spring will have to do. (sry)
Old 02-08-2014, 08:30 PM   #62
BadMoon
BadMoon's Avatar
Drives: 2014 GLI Autobahn/Nav
Originally Posted by Teh_Poop_Shoot View Post
http://www.ebay.com/itm/2012-2013-SU...31ac60&vxp=mtr
Ridiculous price, but none the less available.
Garaxy blue.
BadMoon is offline   Reply With Quote
Old 02-09-2014, 11:55 AM   #63
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
Drives: a machine :]
Thumbs up
Impressive work Kiske!
Drift&Drag is offline   Reply With Quote
Old 11-23-2014, 07:05 PM   #64
SubieBRZ
Senior member
Drives: swp 2013 brz
I just put on a gtr spoiler on my subaru brz
SubieBRZ is offline   Reply With Quote
Old 12-05-2014, 03:07 PM   #65
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
For all of you who were wondering where the $300 E-Bay wing went, here it is.
Lunatic is offline   Reply With Quote
Old 12-05-2014, 03:26 PM   #66
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Looks good!
Old 12-05-2014, 04:04 PM   #67
Lunatic
Lunatic's Avatar
I'm going to have to put the center support in, it flexes quite a bit with out it. On the GTR it will create about 1 lb of down force for every 1 mph. Not a lot, 100 lbs at 100 mph. The local Nisson dealer just down the road just happens to have a GTR on the floor so I'm going to take my digital level down and measure the angle, then tweak mine so my angle is greater, to give me more down force.
It's just on temp, with two bolts. It needs to taken apart and spacers made to increase the angle, painted, and the holes from the old spoiler plugged, all stuff for my paint guy.
Old 12-05-2014, 09:18 PM   #68
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Were you able to extend the wiring and run it down the side of the spoiler or did you just decided to exclude the brake light? You may want to try and make it functional. It is soooooo F'ing bright! I love it and easily lightup everything behind me!
Yeah whole thing shakes like mad when you open/close it. I really wish I made the front edge a bit lower. I went level with the decklid.
FYI MUST DOOOOOO
If your going to run the center support then have your body guy also tack in a brace on the inside of the decklid. Otherwise the leading edge (just above the toyo/scion/subaru emblem) will CRACK the paint. I had it happen twice when some kid leaned on the spoiler and another time after a track session. I love telling my buddies the wing on my little slow scoobaru has that much power at speed to crack it!
Just have them tack a small piece of plate 3inches long right where the middle spoiler hole is and you will be good.
Old 12-05-2014, 10:46 PM   #69
Lunatic
Lunatic's Avatar
FYI MUST DOOOOOO
Thanks for the tip, will do. Haven't decided on the light yet as the wing didn't come with it. I'll have to order one.
Old 12-06-2014, 11:55 AM   #70
FRSNewb
FRSNewb's Avatar
I'm curious to inquire with my local Nissan dlr how much this wing would cost. Does anyone have a part number I could take to them?
1993 Mazda MX-3 - *SCRAPPED* / 1999 Plymouth Neon - *WRECKED* / 2000 Chrysler Neon - sold / 2006 Honda CR-V - sold / 2019 Chevrolet Colorado - All Year Round Vehicle / 2013 Scion FR-S - Summer Car
FRSNewb is offline   Reply With Quote
gt-r spoiler, skyline spoiler
Show off your FR-S/BRZ/86 Spoiler! Mari0 Cosmetic Modification (Interior/Exterior/Lighting) 176 09-21-2017 05:23 AM
BRZ Spoiler Attachment SkullWorks BRZ First-Gen (2012+) — General Topics 40 06-21-2012 05:46 AM
Limited spoiler: better IRL than photos? Sport-Tech BRZ First-Gen (2012+) — General Topics 27 05-15-2012 01:31 AM
FRS With Lip Spoiler ryansb FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 42 04-21-2012 11:19 AM
Ugly Rear Spoiler - Spoiler Delete? iLuveKetchup BRZ First-Gen (2012+) — General Topics 31 02-01-2012 10:57 AM
