Southern California SoCal
Old 01-20-2014, 12:41 AM   #85
retrosmiths
Drives: Scion FR-S Whiteout
Had tons of fun! Thanks for organizing this!
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
The Following 2 Users Say Thank You to retrosmiths For This Useful Post:
ImperiousRex (01-20-2014), WillRacer1jz (01-20-2014)
Old 01-20-2014, 02:13 AM   #86
ImperiousRex
Track Junkie
ImperiousRex's Avatar
Drives: 2013 Subaru BRZ Limited, 2005 S2000
Thanks again for coming out to the event everyone! Here are the results from yesterday if you'd like to take another look at your laptimes and how they stacked up with everyone!
ImperiousRex is offline   Reply With Quote
The Following 2 Users Say Thank You to ImperiousRex For This Useful Post:
MyRx (01-20-2014), WillRacer1jz (01-20-2014)
Old 01-20-2014, 02:19 AM   #87
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by schmearcampain View Post
Only bummer of the day was leaving with the transponder and having to turn around 40 miles later to return it.
Could be worse... you could've done what Mike did in the morning.
-alex
CSG Mike (01-20-2014)
Old 01-20-2014, 02:22 AM   #88
mav1178
mav1178's Avatar
Originally Posted by MyRx View Post
Didn't seem like a time-competition since I ran in the blue group until we got called to the clubhouse, then I said "shoot, I just came to learn the track...I coulda taken it more seriously haha".
The best advice I was given years ago, was that track days are the best (and the fastest) when you're out having fun without trying to push yourself.
That's when you drive the smoothest and can fine-tune your lines, your entry, exit, and work on improving small things.
We all were "learning" the track; I've run Streets CW about 20 times total, but have never run it CCW until Saturday. A lot of us were rookies, gotta start somewhere!
-alex
The Following 3 Users Say Thank You to mav1178 For This Useful Post:
CSG Mike (01-20-2014), JS + BRZ (01-20-2014), MyRx (01-20-2014)
Old 01-20-2014, 01:11 PM   #89
MyRx
MyRx's Avatar
-alex
Oh definitely fun regardless. Great company, great hosts, and even our surrounding (non86) cars were welcoming. Haha strange how even some of the familiar-to-SOW drivers around us never ran it CCW. Nonetheless, it still would have been a learning experience if it ran CW. It always is.
The Following User Says Thank You to MyRx For This Useful Post:
Old 01-20-2014, 01:15 PM   #90
JS + BRZ
Drives: 2010 MS3
I'm just so glad that I didn't spin out.
By the way, my car hit 1,000 miles during my first session. LOL
The Following 2 Users Say Thank You to JS + BRZ For This Useful Post:
Lonewolf (01-20-2014), WillRacer1jz (01-20-2014)
Old 01-20-2014, 01:31 PM   #91
JS + BRZ
Drives: 2010 MS3
I don't know if this is the right place to ask, but did you guys use 2nd gear at all during the lap? I did talk to another member about this but he seemed to be using 3rd and 4th only.
The only time I wanted to use 2nd gear is the two last turns before the front straight. But I just couldn't do it for some reason. Maybe because I don't know how to heel toe?
Was just curious. If this is not the thread to ask, please let me know. I'll just delete it.
Thank you!
By the way, my car is completely stock.
Old 01-20-2014, 01:37 PM   #92
CSG David
CSG David's Avatar
Thank you!
In CCW, I use 2nd at the last corner before the front straight. Sometimes 2nd at the end of the straight, but severely dependent if I put the car into the skidpad properly.
The Following User Says Thank You to CSG David For This Useful Post:
Old 01-20-2014, 01:49 PM   #93
mav1178
mav1178's Avatar
^^ depends on how you drive, how you shift, etc.
On the front straight if I have a clean exit out the top, I can get into 5th for about 3-4 seconds. That would require a 5-4-3-2 downshift... or, I downshift 5-4-3 and run a slightly wider line to have a straighter line into the first couple of esses.
Ultimately it will depend on your experience and skill. The car without electronic nannies is easy to slide in 2nd... I lit up the tires even just getting out of the pit lane and sliding into the skid pad...
-alex
Old 01-20-2014, 01:56 PM   #94
JS + BRZ
Drives: 2010 MS3
Makes a lot of sense. Thank you guys for the feedback.
Old 01-20-2014, 02:01 PM   #95
CSG Mike
CSG Mike's Avatar
Thank you!
Focus on driving, not shifting.
If I'm trying to do a REALLY hot lap, I'll use 2nd in 6 places, but normally, including yesterday, I'll just sit in 3rd, 4th, and 5th.
turns 14, 11, 8, 4, 3, 2.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
JS + BRZ (01-20-2014), Kakawate (01-21-2014), MyRx (01-20-2014)
Old 01-20-2014, 02:03 PM   #96
mav1178
mav1178's Avatar
No problem!
Keep in mind that track days, while fun to talk trash about who is slowest, is about improving yourself as a driver.
Unless you're trying to become a professional driver, the best thing you can learn at the track is proper technique, driving line, and etiquette.
Take the skidpad question for example: 2nd gear entry is great, but what is the point if you have to brake-check yourself halfway into the corner because you went in too hot? I like to use 3rd gear there to start, then go up to 2nd if I wanted to push myself or put down a faster lap. I know of a few friends who worry all day about what gear to drive what corner, but they can't even heel/toe downshift properly...
And whatever you were running in the first session (super cold) would change as the day progressed... track temps were above 80 by our 3rd session, a huge change from the 30-something when we started.
The end goal is to be consistent and improve as your day progresses. And you'll know when you're consistent, because the laps start becoming "boring" and the "same old thing".
Not a bad problem to have
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
Old 01-20-2014, 08:52 PM   #97
schmearcampain
Drives: 2014 Argento FRS 6MT
For the second and third sessions I tried downshifting to 2nd on the second to last turn before the final straightaway. The problem I was having, even being able to heel toe, was that the lateral G's were making it hard for me to shift and maintain speed, so I found that I ended up slowing down too much just to compensate.
So for the 4th and final session I ran that day, I made an effort to hit that corner fast enough to keep it in 3rd @ around 4k rpm (above the dreaded torque dip). That helped me drop my best time to 1:39.612, 2 seconds better than my official 86cup time.
I think my favorite part of the track day was just learning how far I can push the car at each turn. Each session I'd push the envelope a bit further. I don't know if I would have improved my time with another session, but I'm pretty sure I wouldn't have hit 1:34 like the winner of the stock class did.
schmearcampain is offline   Reply With Quote
The Following User Says Thank You to schmearcampain For This Useful Post:
CSG Mike (01-21-2014)
Old 01-20-2014, 08:54 PM   #98
JS + BRZ
Drives: 2010 MS3
Jeff! What's up man!
2014 86CUP #1 - Streets of Willow Springs - Jan 18, 2014 CSG Mike Tracking / Autocross / HPDE / Drifting 21 01-25-2014 10:58 PM
Night Event at Willow Springs-Streets of Willow -August 24-25 SoCal Louie Southern California 9 08-21-2013 02:42 AM
$90 Track day at Willow Springs- Streets of Willow- August 12th Socal Louie Southern California 2 08-10-2012 01:13 AM
Night Event at Willow Springs-Streets of Willow -July-7-8 SoCal Louie Southern California 3 07-03-2012 02:16 AM
$95 Track day at Willow Springs- Streets of Willow- April 14-15 Socal Louie Southern California 0 03-30-2012 03:23 PM
